Projects East Coast Hustler 30 coupe AV8
Discussion in 'Traditional Hot Rods' started by Phil55Kratz, Mar 24, 2019.
  1. Phil55Kratz
    Phil55Kratz
    catdad49 and Stogy like this.
  2. Phil55Kratz
    Phil55Kratz
    Thanks! Yeah I dig it!
    Dino 64 likes this.
  3. Phil55Kratz
    Phil55Kratz
    [​IMG][​IMG]
    Been broke lately so I’m findin little stuff I can do with stuff I have layin around.. today I made a bracket for the original model a ebrake handle. And made a floor board( eventually I’ll use some better looking wood. Just had this piece for now. The kick board part I’m prob gonna make out of metal. Not real sure yet. Sorry for some of the boring posts I realize a lot of this stuff has been done a million times probably, but hopefully someone will find this helpful.
    brEad, Rathbone, Tim and 5 others like this.
  4. Dino 64
    Dino 64
    from Virginia
    Do what you can with what you’ve got ;)
    OLSKOOL57 and Phil55Kratz like this.
  5. nunattax
    nunattax
    Phil55Kratz likes this.
  6. nunattax
    nunattax
    nice nice like the colour on the wheel.
    Stogy and Phil55Kratz like this.
  7. Phil55Kratz
    Phil55Kratz
    Thank you[emoji106]
  8. Phil55Kratz
    Phil55Kratz
    I didn’t really like the way the pedals were so I cut em up. Got em where I like em but still not 100% sure on the clutch throw. I have had it all apart and changed angles like 30 times in the last couple nights. If anything I may just make the clutch arm a little longer cause it seems pretty stiff. ..[​IMG][​IMG]
    barrnone50, brEad, catdad49 and 2 others like this.
  9. Phil55Kratz
    Phil55Kratz
    Well, changed my mind and decided to take 4 inches off the top. Got sick of ****ing around with fenders and said screw it. Now she looks like a hustler.
  10. fourspd2quad
    fourspd2quad
    And a fine looking hustler at that! I am a fan of unchopped coupes but your's came out really nice.
    akoutlaw, nunattax and Phil55Kratz like this.
  11. Phil55Kratz
    Phil55Kratz
    All welded up just some metal finishing to do. And then gotta cut the windows down. 20288104-AF83-438C-BBDC-5674ED80D172.jpeg
    ct1932ford, akoutlaw, dwollam and 7 others like this.
  12. catdad49
    catdad49
    Kind of a bulldog look, I like!
  13. Dino 64
    Dino 64
    from Virginia
    Got some at***ude now ! :)
    Stogy, Phil55Kratz and lothiandon1940 like this.
  14. nunattax
    nunattax
    what type of gl*** is in there standard.if it was mine id prefer laminated windscreen and toughened door gl***
  15. Dino 64
    Dino 64
    from Virginia
    I agree, don’t use the original gl***, safety gl*** is cheap insurance.
    Stogy, nunattax and Phil55Kratz like this.
  16. Phil55Kratz
    Phil55Kratz
    Yeah I think it’s actually safely gl*** but if not I’ll definitely swap it.
    Stogy likes this.
  17. nunattax
    nunattax
    when I got mine done I cut templates very accurately with a jig saw out of 1/4" mdf and sanded and planed the edges for an accurate template the machine scaned the templates and they were cut on a cnc cutter that polished and bevelled the edges for a production quality finish.it wasn't as expensive as I expected.gl*** slides perfectly in the runners.however I had to wait a few days while the gl*** was sent out to be toughened.
  18. Phil55Kratz
    Phil55Kratz
    Got the chop finished up an some paint blended in. Also wiped the car down with some penetrol.. I couldn’t be happier with it right now. I didn’t spend a ton of time to make it perfect but it’s pretty straight and no BS. If I ever decide to pull it apart and give it a real paint job I’ll worry about it then but let’s keep it movin. now I can get back on to mechanical stuff I think I have mostly everything I need to to finish brakes and complete the engine. I really need to figure what I’m doing for wiring. I have a brand new stock model a wiring harness.. thinking about using that but adding a fuse panel than branch off from there. Keeping it 6 volt too since I have a new battery and my generator and stuff is the 6 v stuff. Any suggestions on wiring? Or any good schematics from a later ford I can follow? [​IMG][​IMG] my wife approves [emoji41]
    ct1932ford, brEad, deadbeat and 8 others like this.
  19. catdad49
    catdad49
    I hear engine noises! Great job, why the Penetrol?
    Stogy, Dino 64, OLSKOOL57 and 2 others like this.
  20. nunattax
    nunattax
    suggestion id go 12v alternator in a generator conversion
  21. Phil55Kratz
    Phil55Kratz
    I will
    Eventually but the budget is holding
    Me Back on that ahha
    Stogy and Dino 64 like this.
  22. nunattax
    nunattax
    universal problem
  23. Phil55Kratz
    Phil55Kratz
    The paint has a lot of heavy cracks and it really
    Seals in there and give the old patina a shine. Just seems a little better then water getting in behind it all. If I ever get around to painting the car I’ll have to strip it all completely down ... trying to avoid that for a little while.
    Stogy, nunattax and catdad49 like this.
  24. Dino 64
    Dino 64
    from Virginia
    Man you’ve been busy !
    Looks great
  25. Phil55Kratz
    Phil55Kratz
    Yeah kinda haha thanks!
  26. Crookshanks
    Crookshanks
    Inspiring build and props on doing what you can with what you got. Got a great stance now!
  27. Johnny Nitro
    Johnny Nitro
    from Chicago
    How did you go about applying the penetrol?
  28. Phil55Kratz
    Phil55Kratz
    Wiped the car down with mineral spirits first thanks just soaked(heavily) a rag with the penetrol and wiped it down and it really made a huge difference.
  29. Phil55Kratz
    Phil55Kratz
  30. Phil55Kratz
    Phil55Kratz
    [​IMG] I cut the windshield down and got it back in also got some of the garnishes cut and fit . Working on my seat now. My steering wheel is way up there... it feels so wrong and so right at the same time. It’s definitely different but I kinda like it. Lookin through the wheel for sure..maybe change up a little I dunno.
    brEad, Stogy, Dino 64 and 1 other person like this.
