Technical How often do you change the oil?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, May 16, 2019.
  1. HOTRODPRIMER
    HOTRODPRIMER
    Back when I was running a Flathead without a oil filter I changed the oil religiously ever 800 miles.
    When I added a auxiliary oil filer to the flathead I stretched it to 1,500 to 2,000 miles at the most.
    With the sbc/sbf with the oil filters I have always change the oil every 3000 miles and still do.
    I have heard some people with new engines are actually waiting until they travel 5000 miles before they change oil.
    How often do you change your oil and what is the engine? HRP
  2. primed34
    primed34
    Yearly or around 6000 miles.
    AHotRod and 3W JOHN like this.
  3. DIYGUY
    DIYGUY
    from West, TX
    Yep, 5000 on both my dd. For years and years.
    Gotta brother in law that changes at 3000. He thinks I’m crazy and visa versa.
    3W JOHN and HOTRODPRIMER like this.
  4. tub1
    tub1
    from tasmania
    Mmm maybe I've been doing something wrong a couple of years ago I changed the oil in my 35 tub thought the oil was a bit black when I checked the service sticker it was 10 year's
    nochop, 3W JOHN and firstinsteele like this.
  5. 56don
    56don
    5K But with my first car, a Yblock FOrd, I never had to change it, it changed itself. I just had to keep adding it. Don't ever remember changing the filter more than once in 4 years!
    427 sleeper, 3W JOHN and AVater like this.
  6. David Gersic
    David Gersic
    from DeKalb, IL
    SBC every 3000, earlier if I have to take it apart again.
    DD Dakota pickup 3x a year. I work from home, so “daily” is really more like “weekly”.
    DD (SWMBO’s) Camry specifies a much longer change interval, with fancy oil and special filter.
    3W JOHN likes this.
  7. David Gersic
    David Gersic
    from DeKalb, IL
    Mom had a Studebaker like that. My grandfather kept a barrel of oil in the garage to refill the Stude every time she came home. They’d know when she was coming, the cloud of smoke was easy to see from blocks away.
    3W JOHN likes this.
  8. jimmy six
    jimmy six
    Once a year on my 56. about 2000 miles
    3W JOHN likes this.
  9. HOTRODPRIMER
    HOTRODPRIMER
    I remember working at a Shell station and the old mechanic named Milton told me oil don't go bad it just gets dirty, he drove a old Plymouth Cranbrook and would drain his oil and save it, replace the filter and put the old oil back in the car.
    He changed the filter every month and I questioned him many times about his odd practice, he just repeated what he had said in the past, oil gets dirty but the filter keeps it clean.
    He would add oil if it was needed but never changed it.
    When he p***ed away Marvin, the station owner, took possession of the old Plymouth and he told my dad that he dropped the oil pan on the old car and it was clean as a pin and there was absolutely no metal in the pan. HRP
    LOU WELLS, TomT, 48fordnut and 5 others like this.
  10. das858
    das858
    Every 3000 miles on daily drivers , ever 1500 miles or less on hot rods , and every 10 p***es on our alcohol fueled dragster .
    48fordnut, 3W JOHN and HOTRODPRIMER like this.
  11. deathrowdave
    deathrowdave
    from NKy
    Synthetic in everything I own . Royal Purple in my 32 . 10000miles on changes . ***mins Diesels at 7500 . I know , you think way too long . My wife’s past Toyota , had 340k on it and never had the valve cover off . Oil looked as clean exiting as what I was pouring in new . I think raising the operating temp has a big factor on engine life . Seems to be the new norm is around 200* , I just run my Hot Rod at that temp yet .
  12. CME1
    CME1
    My flathead motors, I change the oil and filter every 1500 miles. My DD F150, every 5000 miles as suggested in my owners manual.
    3340, 3W JOHN and HOTRODPRIMER like this.
  13. Jalopy Joker
    Jalopy Joker
    as often as needed - depends on how oil looks & smells when checking the level - sometimes due to lack of use of your ride, especially during winter months, condensation can show up - your carb may leak gas into oil, especially if you have the habit of reving up your motor before turning it off - or just for the exercise of crawling under your car
    ct1932ford, 3W JOHN and HOTRODPRIMER like this.
  14. Rocky
    Rocky
    Classified Editor
    HHR gets Mobile 1 synthetic every 8000 miles as per manual.
    Changed oil and filter in the 34, 100 miles after break in...then before putting away for winter...maybe 1500 miles. Changed it again when dropping pan last week to rebuild my oil pump..had maybe 1000 miles on it. Soon I will install a working speedometer to keep better track.
  15. 4 pedals
    4 pedals
    from Nor Cal
    Somehow I seem to rebuild engines sooner than they need oil changes.....
    ffr1222k, 3W JOHN and HOTRODPRIMER like this.
  16. 29moonshine
    29moonshine
    every 3000 on my hot rods 5000 on my 20016 dodge
  17. I try and change oil about every 2500 miles, at least that's what I tell everyone. I seldom go past 3K though.
  18. Garpo
    Garpo
    Some of the decision is how you drive it;
    Short runs = severe service .-Change the oil more often
    Long runs are easier on the engine (and everything else) Can do more miles per change.
    Oil is much cheaper than parts.
    I tend to bet conservative and change earlier rather than later.
    Garpo
  19. Hemiman 426
    Hemiman 426
    from Tulsa, Ok.
    Running Synthetic in my DD's. Oil change at 6k and filters at 3k.
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No odometer in the 56 but the date on the oil filter I pulled down last Saturday read 5-24-17 :oops:
  21. Hombre
    Hombre
    My Hot Rod's every 1,500 miles but often I will change it at 1,000 depends if I need something to do. My Dodge 1 ton ***mins every 3,000, old lady's Chrysler about the same 3,000.
  22. partsdawg
    partsdawg
    from Minnesota
    Change filter twice a year on daily drivers and add a fresh quart.
    330,000 on one,302,000 on another. Wifes daily gets a new filter and a fresh quart once a year.
    My hot rods in the past got a new filter every Spring. Never had a oil related issue in 35 years.
    I believe the frequent oil changers do so for peace of mind.
    Oil doesn't go bad,it just gets dirty.
    Frankie47, 3W JOHN and HOTRODPRIMER like this.
  23. I never go by the miles.
    Go by the smell and how it looks.
    nochop, ct1932ford and HOTRODPRIMER like this.
  24. I changed the oil in Debbies Jeep Grand Cherokee today . 6 cyl with205000 miles. use 15-40 shell rotellat . it had a bit over 5000 miles on the oil. fuel injected engines stay cleaner and last longer than a carb engine.
  25. squirrel
    Whatever the owner's manual for the car the engine came from says. Except the Hemi, which gets it every day on Drag Week.
    the late models, I let go 7500 or whenever the light comes on.
  26. My flathead has no filter, but the oil stays pretty clean. I change it with the seasons - every three months.
  27. Flathead Dave
    Flathead Dave
    from So. Cal.
    My flathead w/filter is changed about three times a year at maybe 2000 miles. My regular cars are twice a year at 10K to 12K miles.
  28. 56don
    56don
    I do not recall where I read it, but I was reading an article somewhere about oil and the author stated this very same thing, i.e. oil only gets dirty and does not wear out.
  29. OLDSMAN
    OLDSMAN
    I have changed oil in all my cars around 2,000 miles on the oil. Daily drivers , hot rods too. My convertible has a 455 Olds engine in it
  30. TERPU
    TERPU
    I just pour it through my flathead Never need to use the plug. :p
    nochop, clem, 3W JOHN and 2 others like this.
