Hot Rods M/T valve covers seem kinda cool again.
Discussion in 'The Hokey Ass Message Board' started by Rocky, Apr 13, 2019.
  1. Dyce
    Dyce
    The early ones are cool, but the later sbc have the breather holes located over rocker arms. If you run a pcv valve the engine WILL burn about a quart to every 50 miles. I plan on running the early covers on my model a since the pcv will go to the rear of the block.
    Deuces, loudbang and enloe like this.
  2. Dooley
    Dooley
    from Buffalo NY
    You realize the new ones come with baffles or you can make them to fix this?
    loudbang, Deuces and enloe like this.
  3. Dyce
    Dyce
    The ones I had bad experiences with had only a plate to act as a baffle. The plate is common to all of the aftermarket covers I've had, m/t just put the pcv in a bad spot. I try to use the lt1 z28/corvette covers on all of my engines because the baffles in the original covers are hard to beat.
  4. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    There were 3 different style baffles MT/Holley used in covers. There were 2 different width rectangular with lips on the edges and a flat round one. The rectangular with the larger lips work best. I think I still have NOS baffles around here somewhere......
    loudbang and Deuces like this.
  5. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Dug some old stuff out to show the differences. What you're looking at are original replacement parts for the SBC and BBC covers (241-217, rear) and everything else (241-216, front). However, throughout production the main differences (regardless of application) was the width of the baffle and the lip height. I've had the best luck with oil control by using the narrow baffle with the taller lips (241-216). Though it's narrower it seems to shroud the PCV better than the wider one with a shorter lip.
    BTW, the main difference fit-wise is the Chevy cover baffles had slightly narrower mounting screw centers than the others. You can use non-Chevy baffles if you take a rat tail file to the slots.
  6. saltflats
    saltflats
    from Missouri
    Going to restore these Chevy covers for my dragster.
  7. quick85
    quick85
    While I agree with Blue One (I always preferred the finned Z-28 covers), I had to buy
    these special "350 LT-1" covers. They were $25.00 for the pair. Like most everyone
    else, he just wanted them gone.
  8. CudaChick1968
    CudaChick1968
    I've restored and customized a bunch of those over the years! So many in fact ...
    .... that Indeed, Inc. (an employee headhunter) thinks he works at my shop LOL!!!!
    Deuces, egads, kidcampbell71 and 6 others like this.
  9. Gasser 57
    Gasser 57
    from New Jersey
    I can't think of a time when M/T valve covers weren't cool.
  10. hrm2k
    hrm2k
    My MT valve covers in action in the back seat of my 65 Corvair
  11. The HellyDid
    The HellyDid
    from Florida
    Like to see the Corvair it's in. I'm in love with my 20190510_140527.jpeg Mr. Gaskets
  12. 53olds
    53olds
  13. Stephen Barrett
    Stephen Barrett
    Those are sweet!
    Deuces, 31hotrodguy and CudaChick1968 like this.
  14. swade41
    swade41
    from Buffalo,NY
    Anyone ever see a set of big block chevys like these ?
    I've seen all finned without knockouts, but never seen knockouts without the M/T, Mickey Thompson cast underneath with a # 3376397
  15. Pass The Torch
    Pass The Torch
    I have a pair for a Pontiac that need a new home...
    Deuces and loudbang like this.
  16. Deuces
    Deuces
    Yep! I had a set for a 402 big block.... Sold those along with the motor.... :(:rolleyes:
  17. swade41
    swade41
    from Buffalo,NY
    Where do you think they fit in the timeline, pre M/T ???
  18. CudaChick1968
    CudaChick1968
    I just restored these old beasties for a BB Mopar a few months back, along with the Weiand six pack EFI intake. My customer had the bungs welded in. They needed a lot of clean up; I had to dig the ribs out to get the definition back. He's happy so I am too.
    B535F782-F768-4507-BAD1-A882B5EFF89B.jpeg E5ACF270-57AC-4B94-A1A6-AA5E2139ED83.jpeg BA9E5FFD-728C-43C7-8880-BA34961225B3.jpeg
  19. blue 49
    blue 49
    from Iowa
    RPM1.JPG Were M/T valve covers ever made in USA? I just had my vintage set off and they say "Made in Japan" on the inside.
    An updated picture of mine with a different carb and manifold. I had to bore the manifold for a filler tube so I didn't have to knock out a breather hole in my M/Ts.
    Gary
  20. lippy
    lippy
    from Ks
    You all are sick. I have some BBC ones. Black wrinkle. :D LOL
  21. rob-redm
    rob-redm
    have a pair left over from my 62 Pontiac Bonneville Wagon.. upgrade to 400Ci with a turbo 400 when
    I had it...
    CudaChick1968, loudbang and Deuces like this.
  22. Blue One
    Blue One
    from Alberta
    I’m sticking with my original ***essment.
    M/T valve covers were never cool.
    olscrounger and X38 like this.
  23. Deuces
    Deuces
  24. blowby
    blowby
    from Nicasio Ca
    About 10 million hot rodders bought uncool valve covers then, obviously wanting to be ****s.. They are perhaps a victim of their own popularity.
    I recently put a set on my work truck, not because they are cool or not. I wanted better sealing than the '80s stamped steel stockers it had, and the M/Ts were 20 bucks at the swap meet. The polish was long gone, wasn't about to buff, so they got the orange rattle can. Now the wing nuts, those might be uncool..
  25. catdad49
    catdad49
    Nothing wrong with those wing nuts, but being OCD, I would rotate them so they follow the length of the valve cover. Besides that, they make vc removal lots easier.
    loudbang, Deuces and blowby like this.
  26. fortynut
    fortynut
    M/T valve covers are cl***ic hot rod parts. They were designed from the dictum of 'form follows function'. I remember reading of Mickey Thompson's exploits as a young man and being impressed by his take no prisoners style of purpose built machines that were pushed to the limit. Over the years I've owned my share his company's valve covers for one simple reason: When I lived in SoCal I could go to the Fairgrounds Swap Meet with a flashlight early enough and find 'em for a saw buck, and for the same price at the Veteran's Stadium Swap Meet. The reason I looked for them was 'they work'. Also, now, they are a memorial to one the pioneers of our sport. You can't beat that.
    High test 63, egads, catdad49 and 5 others like this.
  27. I would sure like one for a Straight Eight Buick.
    Ben
  28. Dooley
    Dooley
    from Buffalo NY
    wing nuts were loose as the new gasket was settling in
  29. 56sedandelivery
    56sedandelivery
    Just think of all the goodies we'd have to chose from now had him and his wife not been murdered? And, I have several sets of M/T valve covers for the SBC. They are a right of p***age for any hot rodder/racer.
    I am Butch/56sedandelivery.
    blowby and Deuces like this.
  30. Crocodile
    Crocodile
    They aren't Cal Custom cool, but definitely cool.
    Deuces and das858 like this.
