Technical Swap Meet tool ID
Discussion in 'The Hokey Ass Message Board' started by shivasdad, May 17, 2019.
  1. shivasdad
    shivasdad
    from Texas
    Hey all,
    I found this nicely made heavy duty looking flywheel tool at Pate a couple of weeks ago and snagged it out of the $5 bucket. At least I thought it was a tool to grab the teeth and turn an engine at the flywheel. It really doesn't work for that. There is a tool number on it "Cal-Van 196" but google that number and you get a ball joint tool. The tip is replaceable via an allen head set screw. I don't know what else to call it to get an idea. DSC_0165.jpg DSC_0166.jpg DSC_0167.jpg DSC_0168.jpg
    Thanks in advance.
  2. elmorefats
    elmorefats
    from Elmore
    That’s a tool to adjust upper control arms. I have one that I used on 60’s & 70’s full size Fords.
    loudbang and deathrowdave like this.
  3. sdluck
    sdluck
    Mopar caster/camber tool adj
  4. Mr48chev
    Mustang II, Pinto, Bobcat and a few more caster/camber adjuster. The pin on the end goes in the hole in the crossmember, the "C" goes around the control arm shaft to move the control arm in/out to adjust the alignment. One of those things that make a front end guy wish he had three arms and hands before he is done. There isn't an RWD engraved in that somewhere is there? I traded one back to the tool truck guy to settle part of my bill with him in 1977 before I moved back up here from McGregor.
  5. iwanaflattie
    iwanaflattie
  6. shivasdad
    shivasdad
    from Texas
    Thanks everyone. I occasionally run into the M2 suspension. It will go on the wall with the pullers and such. Probably still a good deal at $5. @Mr48chev , no engravings or markings other than the part number. I am so glad to have the HAMB to help me with this stuff, especially when Google fails me.
    @iwanaflattie that's funny, but sometimes you ain't right. :)
    Sandgroper, loudbang and Boneyard51 like this.
  7. Boneyard51
    Boneyard51
    I know a guy that would gi
    I know a guy that would give $5 just to see that tool!!
    Bones
  8. 1934coupe
    1934coupe
    Boy I was wrong, it looks like a flywheel turner to me.
    Pat
  9. partsdawg
    partsdawg
    from Minnesota
    Looks like a $20 tool
  10. BJR
    BJR
    that's just plane funny, I DON'T CARE WHO YOU ARE!:p
  11. Flathead Dave
    Flathead Dave
    from So. Cal.
    Just what I need to open my Dental and OBGYN Office. I can get a diploma from ebay...
    Sandgroper, loudbang and fauj like this.
