Hot Rods Need help to find what this fits for another project
Discussion in 'The Hokey Ass Message Board' started by 74bowtie, May 19, 2019.
  1. 74bowtie
    74bowtie
    I have this under the dash switch bezel, got it to possible use on another project. I can't seen to find what it fits so I can get the switches for it. Can someone tell what its from?
  2. oldolds
    oldolds
    I suspect that the 3 labeled holes use cables. The center one was the fan switch. No help as to original application.
    Crazy Steve likes this.
  3. greybeard360
    greybeard360
    May be for aftermarket add on heater.
  4. 74bowtie
    74bowtie
    I was thinking the same being they were cables, I may just open up the hole some and use switches instead.
    Found that Friday at the Dunkirk, NY swap meet could not p*** it up for $2.00, I did blast it and powder coat it yesterday, it looked a lot worse when I got it.
  5. Doublepumper
    Doublepumper
    from WA-OR, USA
    I believe it's a control panel for a Ford script fresh air heater. Something like '48 through '50 or so.
  6. 74bowtie
    74bowtie
    I believe you are right, Thanks
