Hot Rods Old Bessy build
Discussion in 'The Hokey Ass Message Board' started by chop job, Nov 21, 2017.
  1. chop job
    chop job
    from Wisconsin
    1. WISCONSON HAMBERS
    Finally put the body on for the final time. Was a perfect day at 72 degree and sunny. What a wonderfull day with my brother. 20190422_132521.jpg 20190422_141005.jpg 20190422_142429.jpg 20190422_150609.jpg 20190422_151108.jpg
    Tim, Lil'Alb, barrnone50 and 9 others like this.
  2. Stogy
    Stogy
    Cool Stuff Hotrodder...its really coming together Just like the weather...;)
    chop job likes this.
  3. @chop job, it looks like a small forest of Clecos has started growing on your roof! Looks good sitting where it belongs on that frame.
    Stogy and chop job like this.
  4. low budget
    low budget
    from Central Ky
    Cool car, Cool garage space, The old Rail Road sign catches my eye, I like it!
  5. chop job
    chop job
    from Wisconsin
    Having fun again today setting up grill and headers. Still a long way to go. 20190430_111048.jpg 20190430_111037.jpg 20190430_111029.jpg
  6. chop job
    chop job
    from Wisconsin
    20190504_152209.jpg 20190504_151943.jpg 20190504_151905.jpg 20190504_151926.jpg Setting up header to make both the same good thing I saved the piece we cut off the first elbow. Gas tank went right in with no trouble HA HA never going to happen right? Painted the steering coulum. 20190504_152228.jpg
    Ron Funkhouser, Stogy and brEad like this.
  7. chop job
    chop job
    from Wisconsin
    Been busy with spring cleaning but still had time to add some parts to hot rod. 20190513_112356.jpg
  8. chop job
    chop job
    from Wisconsin
  9. wow, can't miss those buggers now can you:eek::D Are they the commercial units?
    Stogy likes this.
  10. chop job
    chop job
    from Wisconsin
    Why yes they are indeed.
    Stogy likes this.
  11. chop job
    chop job
    from Wisconsin
    Have both header cones now in place will tack up and then welded. Just PAINTED new drive shaft . 20190520_111923.jpg 20190520_111916.jpg 20190520_111903.jpg
  12. Dick Stevens
    Dick Stevens
    You can edit your posts and delete the extra photos!
  13. chop job
    chop job
    from Wisconsin
    Thank you Dick.
    Stogy likes this.
  14. chop job
    chop job
    from Wisconsin
    More work done. 20190608_130912.jpg headers done. 20190608_104904.jpg gas filler. 20190607_093149.jpg
  15. chop job
    chop job
    from Wisconsin
    Have to put gas in this baby so I decided to go in from the top. 20190613_134808.jpg my brother helped with tis design now have to punch holew and install. 20190613_214924.jpg
  16. chop job
    chop job
    from Wisconsin
    Trial fit today. Good shape. 20190619_105623.jpg 20190619_105913.jpg 20190619_105833.jpg
  17. chop job
    chop job
    from Wisconsin
    Lots of button head bolts on floor but better than all that welding. 20190622_144140.jpg 20190622_144133.jpg
    barrnone50, Ron Funkhouser and Stogy like this.
  18. Stogy
    Stogy
    Aviation inspired and looking good @chop job...that said it could even be just working within your means...as in Alternative fastening systems...I'm sure many many garage builds shared this inspired securing method...
    The finish line is approaching and a new milestone in the adventure will begin...
  19. chop job
    chop job
    from Wisconsin
    20190712_140901.jpg 20190712_120309.jpg Spent all morning long sanding and wire brushing these and next will clear coat with high temp clear.
  20. Bugguts
    Bugguts
    Still following. Glad your still getting things done. Going to look great!
  21. rosstom
    rosstom
    Looks great so far. Can't wait to see more updates and pics.
  22. Nice job on the exhaust. Have you used the high temp clear for this purpose before? I’m curious how well it holds up as I’ve had the same thought.
  23. chop job
    chop job
    from Wisconsin
    I have not but I'm hoping for a good result. Will keep you posted.
  24. chop job
    chop job
    from Wisconsin
    Today no did more work on the hot rod I know I'm slow but I'm having to much FUN with this build. Painted the radiator and added the shifter. 20190808_135140.jpg 20190808_135149.jpg
  25. chop job
    chop job
    from Wisconsin
    Stogy, brEad and Ron Funkhouser like this.
  26. chop job
    chop job
    from Wisconsin
  27. chop job
    chop job
    from Wisconsin
    20190828_103109.jpg 20190828_160315.jpg [/B]
    brEad and Stogy like this.
  28. chop job
    chop job
    from Wisconsin
    Lots of rain lately here in Wisconsin so all inside the shop work. 20190913_101328.jpg
    Tim, brEad, 51box and 1 other person like this.
  29. chop job
    chop job
    from Wisconsin
    Made some changes on the fuel log mount. 20190916_122816.jpg 20190916_104107.jpg 20190916_122832.jpg
  30. chop job
    chop job
    from Wisconsin
    Just got around to adding fuel lines and pressure gauge. 20191004_124333.jpg 20191004_123802.jpg
