Projects Another 55... (Nasty Nickle)
Discussion in 'The Hokey Ass Message Board' started by 54hotrodder, May 21, 2019.
  1. Looks great, I wish I had the time to work on my stuff like you do!
  2. uncleandy 65
    uncleandy 65
    I'm waiting for the straight axle, and the 60's bucket seats.
  3. It amazes me. folks will cut the frame of and graft a subframe under a 1950's truck to get IFS and better drivability. and yet then folks will cut a perfectly reliable IFS from a tri five chevy and install a straight axle? There aint any weight savings. Nothing accomplished but make it handle worse. If you adjust the stock drum brake shoes just a tad loose. they have less drag and are faster that disk brakes. The roller bearing conversion is a good improvement. My 55 will retain the stock IFS and drum brakes.
  4. BigO
    BigO
    Awesome, love that car... congrats man.
  5. 54hotrodder
    54hotrodder
    No straight axels for me I just picked up up a set of buckets for it. And 4 olds 9.3 rear ends
    Sent from my SM-G975U using The H.A.M.B. mobile app
  6. 54hotrodder
    54hotrodder
    enloe, catdad49, Thor1 and 12 others like this.
  7. 54hotrodder
    54hotrodder
    Well while the 9.3s are on hold for a nice buildup. I dropped this Ford 9" "direct bolt in" in the old car.
    Has speedway leafs in it. It sits like a 4x4.
    And extended shackles the exact kind that was in the car. Same length and everything.
    My old springs pretty much where horizontal but these are like 6" k10 lift springs now. Even though they are "factory replacement"
    I'm gonna drill the shackles out all the way to a stock setting because I cant stand how high the *** of the car sits now... I hope they have settled down by the time I get back in townbur I doubt it. I was up north for memorial day weekend at our cabin... 20190523_162015.jpeg 20190522_233215.jpeg 20190523_170221.jpeg 20190523_181729.jpeg 20190523_190324.jpeg 20190523_190337.jpeg 20190523_231637.jpeg 20190523_231725.jpeg 20190523_231645.jpeg
    enloe, Thor1, kidcampbell71 and 15 others like this.
  8. exterminator
    exterminator
    You don't mess around!
  9. Fitnessguy
    Fitnessguy
    Good lookin build brother! Man that drivers front fender sure fell apart above the headlight eh! Pickin all the right parts. Enjoy the build!
  10. 427 sleeper
    427 sleeper
    That is one KILLER ride!!! I like the way you don't mess around too! Get it together and beat the hell out of it and have fun! [emoji41]
    If you ever want to get rid of one of those Olds rear ends, I'd be more than happy to buy one from you! I have a '56 that one would look really good in. [emoji6]
  11. rusty1
    rusty1
    ...just a thot, in the one pic you have 6x6 wood blocks under the frame,...you mite consider turning one set 90 degrees, or both sets 45 degrees,...I use the same blocks under cars and have had one roll backwards off those blocks if the front wheels are on the floor and not blocked well, ...when workin on the car those blocks can roll back and forth,..specially torquin down rear end u-bolts, etc,...just a safety thot,..I like yer Chevy a bunch...
    chryslerfan55, loudbang and Stogy like this.
  12. 54hotrodder
    54hotrodder
  13. 54hotrodder
    54hotrodder
    I'm not very organized right now trying to ge this thing cranked out.... but heres a recent update.
    Lights all function along with signals.
    More wrapping up on the motor, and trans.
    Trans
    Gotta install the shifter cable and brackets.
    Get a driveshaft made up.
    ****** cooler lines.
    Fresh fluid.
    Motor
    Oil pressure line.
    Fuel line plumb
    Wire fans, and magneto to an kill switch.
    Pray for no leaks.
    Brakes need to blead hope to tackle that tomorrow.
    Mount the bucket seats.
    20190520_204833.jpeg 20190520_214339.jpeg IMG_20190521_020643_082.jpeg 20190521_214758.jpeg 20190520_213832.jpeg 20190520_213826.jpeg IMG_20190521_020643_081.jpeg 20190520_214403.jpeg
    enloe, catdad49, Thor1 and 18 others like this.
  14. classiccarjack
    classiccarjack
    Great work! Your killing it! Can't wait to see it move under it's own power.
    Sent from my Moto Z (2) using The H.A.M.B. mobile app
  15. 54hotrodder
    54hotrodder
    Just messing around today waiting on some parts from summit and speedway! 20190529_232746.jpeg 20190529_232505.jpeg 20190529_232736.jpeg 20190529_230136.jpeg
    enloe, Rathbone, Thor1 and 10 others like this.
  16. Stogy
    Stogy
    I think when you start that up you might blow some of the less stable metal off and actually help expedite the repair process...she really needs her eye brows done...:D
    I remember as a teen an old 55 2 dr post that was in an old garage, I took several parts off...man it was tough...the left front fender had the front foot of the top fender missing and they had tin wrapped around it wired on with coat hanger...last time I looked it was still sitting and rotting in there too.
  17. 54hotrodder
    54hotrodder
  18. I really like the gold Moroso valve covers! It really gives it a cool vibe.
  19. 41rodderz
    41rodderz
    from Oregon
    I was never was big on gold valve covers but they really pop against the engine paint and the plug wires. Lighting helps as well. We need to call you Speedy Gonzales:cool:.
    loudbang and 54hotrodder like this.
  20. rusty1
    rusty1
    ...are you bringin this 55 to the Uncle Sam's drags or the Glory Days at Byron, Illinois?
  21. treb11
    treb11
    I don't know what it is, but I F'N LOVE the rear wheel well radius job on this.
  22. 54hotrodder
    54hotrodder
    Nothing like an old ball bean hammer some vise grips and a sawsalll cant cover.
    Was definitely a home grown job back in the day.
  23. 54hotrodder
    54hotrodder
    I'm not huge on the gokd covers either but I think it gives it the van Nuys boulevard street sweeper look.
  24. swade41
    swade41
    from Buffalo,NY
    I like it !
  25. 54hotrodder
    54hotrodder
    chryslerfan55, loudbang and swade41 like this.
  26. 54hotrodder
    54hotrodder
  27. 54hotrodder
    54hotrodder
    Getting their fools.
    Driveshaft.
    Bleed brakes and time it. 20190601_210102.jpeg 20190531_225813.jpeg 20190531_225014.jpeg 20190531_223944.jpeg
    enloe, Rathbone, Thor1 and 6 others like this.
  28. 48fordnut
    48fordnut
    I like this .No one is telling
    you do this or that. Good.
  29. Butch M
    Butch M
    oh my that's so cool
  30. swade41
    swade41
    from Buffalo,NY
    You spoke to soon...ha ha ha
    If you plan on racing the car, the firewall mounted regulator won't p*** tech
