Projects Aussie 32 frame / Model A coupe build.
Discussion in 'Traditional Hot Rods' started by Wardog, Feb 7, 2019.
  1. Man that looks good, very nice
  2. Wardog
    Wardog
    Thanks Fairlane500.
    I also started cleaning the engine up. Wash 1 of about 40.
  3. Stogy
    Stogy
    Well documented and thought out vintage inspired throwback to simpler times @Wardog...so I'm assuming it will be fenderless but you may have other plans...(and yes I know fenders are manditory)...I mean bobbed rears and cycle/spare ring or no fronts look good too.
    No chop either? The body looks pretty solid...that will make the transition smoother...oh yeah nice shiny bits on the engine no hood perhaps...;)
    Anyways a pleasure to witness your journey in Hotrod...thanks for sharing it with us Hoodlums...:D
    1947knuck and chryslerfan55 like this.
  4. Wardog
    Wardog
    @Stogy thanks for the compliment.
    You made me realise I haven’t spelled out the vision in my head.
    The plan is an early hot rod, a 40’s style build. Like a kid bought a driving chassis from a wrecking yard and put dads old coupe body on top. Hi boy, no hood.
    As for a chop. For sure, I’m set on 4” but not until I have the body properly mounted to the frame. It will be a bit of a treat after the car has hit the road in its new form.
    1947knuck, chryslerfan55 and Stogy like this.
  5. Wardog
    Wardog
    I washed the engine a few more times today. Then we removed the coil bracket, some washers and the end of an old braided earth strap from under the head nuts.
  6. fourspd2quad
    fourspd2quad
    Really nice build you have going there Wardog! It's awesome that your son is right there with you. It gives me hope that there will be a next generation of vintage hotrodders.
    Wardog and chryslerfan55 like this.
  7. 1947knuck likes this.
  8. Wardog
    Wardog
    Yes. Ace is my 11 year old son.
  9. He looks like a well mannered young man. Wise beyond his years i suspect.
    1947knuck and Wardog like this.
  10. brEad
    brEad
    You have some grade A help there! Trans & frame look good!
    chryslerfan55 and Wardog like this.
  11. Wardog
    Wardog
    Thanks for the kind words guys. @chryslerfan55 He is a good kid. He likes to help and is very mechanically able.
  12. Wardog
    Wardog
    The engine got some new water pumps and a paint job today.
    7897B7C2-4DD6-4ADF-9F99-E3D82C08D8F7.jpeg D9DCB7BF-BFD3-4002-A6AD-E23112F62594.jpeg 8CF045C9-C2D0-469B-AEBA-2E12DCF4D3FF.jpeg 08D48D41-6DC7-4719-8E4F-8E30B10428D0.jpeg
  13. whodaky
    whodaky
    from Aust
    Looking good Wardog.
    Geoff aka whodaky
  14. Wardog
    Wardog
    Thanks Geoff.
  15. Wardog
    Wardog
    Tonight I made a start on my brake pedal. I didn’t expect to procrastinate on this as much as I have. But when you have such a nice set of pedals that first cut is a hard one to make.
    I cut the mechanical brake lever off the pedal and straightened it in the press. Then after some trimming and scalloping with a file I tacked it back on the bottom of the pedal.
    I’ll turn my attention to the master cylinder mount before welding it completely.
    B90E6F33-EBD6-407B-8A44-8A22350510E4.jpeg D946F943-BDBE-41E7-AFF3-AE67B349620C.jpeg
  16. Wardog
    Wardog
    I’ve been getting a bit done every night this week. Tonight I assembled and checked it then welded the repositioned lever to the pedal. I’m happy with the position of the master cylinder, it’s a lot higher than the suspension and where the sump will be. The mismatched bolts will be replaced by some new unc hardware.
    15727750-4C97-46DA-AD1D-A888D451B3F4.jpeg 6F2A8992-779C-4478-8838-FD8DC7366E58.jpeg A73374F1-BE44-4F24-A893-872F005C2639.jpeg A368B2EB-9B01-45AB-BA29-738A43C536C6.jpeg FB542E18-F134-4278-A210-7509A573BA21.jpeg C18E35A2-D2B2-4C02-9662-D890F9E32946.jpeg 734DC593-A6FF-4248-839E-74A8DBC8C165.jpeg 70E74169-71A8-4FE5-9E39-062009B474F9.jpeg
  17. tub1
    tub1
    from tasmania
    Nice job on the brake pedal
  18. Wardog
    Wardog
    Thanks man.
  19. Wardog
    Wardog
    The last couple of weekends I’ve been busy with the family and haven’t achieved much. What I have done has been during the week. Today I put bushes in the pedals but that wasn’t really worth a photo. So here is a photo from before I pulled the engine I had forgotten about.
  20. Wardog
    Wardog
    I made some rear legs for the center crossmember this weekend. I used some laser cut channels a friend gave me. I started by flattening out sections of the lip on the back edge of the crossmember for the legs to fit flush.
    Nothing groundbreaking about them. They meet the rails at about the same place as some stock holes.
    799A0A57-38FB-4C20-97BC-63A570A7456C.jpeg 1BB79165-F3A5-445A-8A6B-C408B9BAE7BF.jpeg 078B7C75-6A28-4FCD-9B4D-7AF5ADD4FF45.jpeg
    I picked up on the transmission mount for the front brackets.
    Sometimes you need bigger filler than you have...
    1947knuck, treb11, deluxester and 6 others like this.
  21. Wardog
    Wardog
    Finished and bolted in.
    D9BC14A6-3A97-4CC7-882C-12CFDDD3F478.jpeg E832C0E1-7C26-4C60-AAA7-BBAEDEC7A77B.jpeg
  22. Wardog
    Wardog
    I got engine back in this morning and started to look at how I will modify the headers.
    EE930967-83DB-421D-877E-ADC1A0A60E9A.jpeg C2C7E200-508C-45AB-86AB-16DB895BAAE8.jpeg
    itsmee, 1947knuck, deluxester and 5 others like this.
  23. Nick Agius
    Nick Agius
    Looking great Wardy! That thing has such a good stance..
    One of these days we’ll be cruising together
    phelan9251 likes this.
  24. Wardog
    Wardog
    Thanks Nick. I can’t wait man.
  25. Wardog
    Wardog
    I bought some headers knowing they wouldn’t clear the steering box. So I’ve been modifying them for clearance. I got that done tonight, now on to the rest of the exhaust.
    33941C29-0CE5-44B6-85D7-40EEE6DD119A.jpeg F8464E3D-6D25-4514-AADD-5D08E11AE576.jpeg 67B17B9F-68BF-4D70-9BCA-3C2C343D79A3.jpeg 13F77589-E63D-4AD2-A8F7-AF04D597AC51.jpeg 9E607CF3-E1F1-46AA-8B03-F63538E1E37C.jpeg 55AD0BDD-D35A-4101-BF22-FEA6C7F89C9B.jpeg
  26. tub1
    tub1
    from tasmania
    Mate you needed some pilot manifolds
  27. Stogy
    Stogy
    :rolleyes:...Fantastic Detailing @Wardog
    1947knuck, Wardog and chryslerfan55 like this.
  28. thommoina33
    thommoina33
    Alliance Member
    from australia
    Just catching up on the build, really great progress. The chassis legs make a world of difference for stiffness. Can’t wait to see this done.
  29. Wardog
    Wardog
    I’ve got some but I really wanted to run the headers.
  30. Wardog
    Wardog
    Thanks Thommo. I’m really enjoying this.
    thommoina33 and chryslerfan55 like this.
