Hot Rods The No Frame Model A Modified
Discussion in 'The Hokey Ass Message Board' started by rottenleonard, Sep 22, 2017.
  1. ol'stinky
    ol'stinky
    from New Jersey
    Has NASA called and offered you a job yet? Jeez dude you are good.
    brEad and Stogy like this.
  2. rottenleonard
    rottenleonard
    I received back the fuel tank strap from the waterjet and installed it, pretty happy with it.
    Then pushed it outside to get a feel for the hood dimensions
    Made up some guardrails for the paper patterns
    Patterns made up with a cutout for the ignition. Still deciding on a cutout or a blister.
    So far I'm pretty happy with the direction of the car.
  3. 1-SHOT
    1-SHOT
    from Denton
    I haven't seen a cut down steering wheel in a long time.
    I have enjoyed following your build. Can you find a 90% drive for the distributor so you don't have a hole in the hood. Frank
    Runnin shine, chryslerfan55 and Stogy like this.
  4. Stogy
    Stogy
    Great vision and execution @rottenleonard...really enjoying the view from the virtual front seat...;)
  5. BigO
    BigO
    Great work...wonderful.
  6. Nostrebor
    Nostrebor
    I saw that first picture before the paper pattern and thought "he's gonna cut a big hole in the hood for the disto". And then it was there in the mock up. With some thought and balance, it could be a really different/interesting/whattheheck detail. :cool:
    Digging the outside shot... the body is just squared off and parallel at the base and the tire/wheel package is off the path but fits the car. So much forethought here. At first look I felt like it needs a turtle deck, but the exposed mechanicals really work from the back. It's going to be a car that you have to study and study and study some more as a casual viewer, if you're looking to find all the layers of detail.
  7. Marty Strode
    Marty Strode
  8. rottenleonard
    rottenleonard
    Thank you that's a big compliment! The little details that take awhile to notice are my favorite part of a hand built car.
    Thank Marty! Might make the blister a second piece and attach it with quarter turns so I can mess with the ignition when needed. Time will tell.
    I just seen your fender extensions on the Grumman box, they really look right!
    pcbart, chryslerfan55 and Stogy like this.
  9. patmanta
    patmanta
    from Woburn, MA
    Have you considered the idea of making the blister out of clear acrylic?
    clem, chryslerfan55 and Stogy like this.
  10. Blues4U
    Blues4U
    from So Cal
  11. brEad
    brEad
    I just love the idea and look of this car. Constant eye candy as you look at the pics.
    97
    Instead of disturbing the line of the hood, you could add an accessory drive , at the timing gear cover and shelf for a Mag or even the distributor if you don't want to use a mag..
  13. rottenleonard
    rottenleonard
    Better get y'all cought up. Been thrashing trying to get the car running for Speedweek.
    I took the paper template and taped it down on my plasma bed. With a pointer installed i could pull coordinates from around the edge and distributor hole. After recording these I was able to draw a dxf file and cut it from 20 gauge material 20190605_152013.jpg
    After that it was just a matter of bending it over various round objects in the shop until I got proper shape. I did use the English wheel and stretcher shrinker to bell the rearward edge some to make it flow better. I then screwed it to both the cowl and the grill shell. This really stiffened up the grill shell and keeps the radiator from flopping around. 20190606_144220.jpg
    20190627_154019.jpg 20190627_154022.jpg 20190605_165940.jpg 20190627_153719.jpg 20190627_153648.jpg 20190627_153656.jpg 20190627_153704.jpg
    Jet96, brEad, USMercUte and 12 others like this.
  14. rottenleonard
    rottenleonard
    I had a previously built set of headlight mounts that i finally had to admit that I hated. So it was back to the drawing board. Finally set on mounting them off the side of the radiator shell. Also spun up an aluminum support rod to tie the mounts together. 20190702_164122.jpg 20190702_164627.jpg 20190703_110603.jpg
    Jet96, AHotRod, brEad and 9 others like this.
  15. The great build but I’m really digging that front end
  16. rottenleonard
    rottenleonard
    How long until Bonneville?o_O
  17. rottenleonard
    rottenleonard
    Been working on the little things,
    Throttle and choke cables
    20190711_111331.jpg 20190711_125155.jpg 20190711_151824.jpg 20190716_190022.jpg 20190711_153839.jpg 20190711_160456.jpg 20190711_160931.jpg 20190716_165958.jpg 20190716_193852.jpg 20190711_160928.jpg
    AHotRod, brEad, Tim_with_a_T and 4 others like this.
  18. rottenleonard
    rottenleonard
    Next up the steering column needed shortened 3 inches. Also there was a scary amount of slop in the box. Armed with a Model A manual i tore it apart. Looks like the wear is minimal but someone had been in monkeying with the adjustments, good news.... so proceeded with shortening the column and steering shaft. Changed it over to grease instead if oil, re***embled and adjusted. I'm quite happy with the result. 20190712_131818.jpg 20190712_090136.jpg 20190712_090942.jpg 20190712_125431.jpg 20190712_131241.jpg 20190712_113949.jpg 20190712_114319.jpg 20190712_125443.jpg 20190712_130631.jpg 20190716_182139.jpg
    clem, AHotRod, brEad and 6 others like this.
  19. rottenleonard
    rottenleonard
    Onto the brakes, while I have lots of big ideas for the brake reservoir, truth is I'm out of time so I'll have to come back to it. So I knocked together a bracket for the plastic remote reservoirs and mounted the high on the firewall.
    20190719_094510.jpg 20190719_095051.jpg 20190719_100032.jpg 20190723_141613.jpg 20190723_141600.jpg
  20. rottenleonard
    rottenleonard
    While there is a time crunch i couldn't help but try to address the too stiff, too low ride hight problem. I had used a Posey (sp?) Model a lowering spring that I had on hand. So i took it apart, removed a couple of leafs and then un-reversed the reverse eye main leaf....ya I know.... the harbor freight ring roller does this very well.
    Damn I need to clean up...
    AHotRod, brEad, Tim_with_a_T and 7 others like this.
  21. El Hueso
    El Hueso
    Go man go! I'm looking forward to seeing it on the salt!
  22. rottenleonard
    rottenleonard
    That makes 2 of us, been a lot of corners I've had to cut so I'll be redoing a few things. I had planned on taking a few days to tig weld the ch***is together but instead I went ahead and burned it in with the mig in a couple hours, little sad about that but happy to think ill be driving it soon.
  23. Atwater Mike
    Atwater Mike
    Thanks, Leonard. Here's 200 more ideas for me to think about...
    True bracketmaster!
  24. Fabber McGee
    Fabber McGee
    Looks like time to pick up another barrel of cheese balls too.
    kidcampbell71 likes this.
  25. rottenleonard
    rottenleonard
    I change the head out for one of H&H is Ricardo heads. The motor looks pretty good no wear through any crosshatch anywhere. The valve guide seem tight. Looks like a fairly fresh 80 over rebuild.
    Swapped in new leakless water pump. And got the radiator hoses sorted. 20190726_152408.jpg 20190726_152437.jpg 20190726_152924.jpg 20190726_152940.jpg 20190726_153441.jpg 20190729_170927.jpg 20190729_171011.jpg 20190729_170923.jpg
    Runnin shine, AHotRod, brEad and 8 others like this.
  26. rottenleonard
    rottenleonard
    Next up was finishing up the brake lines. 20190729_170859.jpg 20190729_170910.jpg 20190729_171019.jpg 20190729_171025.jpg
    And not that I had time but I couldn't resist putting the dash panel up on the mill and engine turning it. 20190729_153838.jpg 20190729_170939.jpg 20190729_171254.jpg
    My old man was hanging around the shop the other day and decided to pitch in with some lathe work.
  27. 1-SHOT
    1-SHOT
    from Denton
    IMG_0047.JPG Love it especially the La Grange reference. Here it is today
    chryslerfan55 and AHotRod like this.
  28. rottenleonard
    rottenleonard
    So this fine Chinese ebay radiator has a rearward pressure cap, but you would have to remove the hood to check the coolant as the stock location was there to hold up the radiator cap as an ornament......? here is an idea
    And finish welding the exaust. Eventually i would like to send it out for chrome. This will have to do for now.
  29. 1-SHOT
    1-SHOT
    from Denton
    I would have done the same thing with the radiator
  30. brEad
    brEad
    So cool! Looking forward to the next update.
