Projects Need advice on hydraulic clutch 63 falcon/comet
Discussion in 'The Hokey Ass Message Board' started by Deano63comet, May 30, 2019.
Tags:
  1. Deano63comet
    Deano63comet
    Hey guys, really hope someone could help me out with some advice. I’m swapping to a master/booster disc/disc setup for the brakes and hydraulic clutch(Tilton t/o bearing already installed on tremec tko) but am having a hell of a time figuring out how to get clearance for both master cylinders (booster is in the way). Anyone ever do a conversion on one of these cars like this? Thanks!
  2. That'll be a tough one... Space is so tight that even Ford didn't want to install the brake booster on these cars; if power brakes were ordered, Ford threw the parts in the trunk and made the dealers install them! That's one reason power brakes is a very rare option on these...
    I'd give serious thought to going with either mechanical linkage or late Mustang cable linkage; or non-power brakes...
  3. oldiron 440
    oldiron 440
    I can't believe you need power 4 wheel disk breaks on a 63 Comet, a 67 Corvette manual master cylinder will bolt up.
  4. gimpyshotrods
    gimpyshotrods
  5. Chiss
    Chiss
    from S.C.
    Didn't early Bronco's have Offset Booster?
    • [​IMG]
    • [​IMG]
    • [​IMG]
    • [​IMG]
  6. BigChief
    BigChief
    Consider hydro boost instead of vacuum ***ist. Much more compact and easy to retrofit with common junk yard or over the counter parts.
    Sent from my SM-G950U using The H.A.M.B. mobile app
  7. bobss396
    bobss396
    I have a dual master on my '59 Ford and kept the brakes manual, it stops easily. Discs up front, drums out back.
    I made up a steel plate that mounts the master and clutch master to the firewall.
    Deano63comet likes this.
  8. Deano63comet
    Deano63comet
  9. Deano63comet
    Deano63comet
    Thanks guys for all the info. Looks like I will have some options thanks to your advice. Really appreciate it. Going back in w a 390 for a bit more umph.
