Projects Progress on Rocky's 34 coupe..last update 9/30/2020
Discussion in 'The Hokey Ass Message Board' started by Rocky, Jan 12, 2009.
  1. vtwhead
    vtwhead
    I like it. Great idea Rocky.
  2. Rocky
    Rocky
    Classified Editor
    Got rid of the old plastic spider and got the USN insignia installed. I likes it and now when I look down at my horn ****on I'll think of the 'ol man and the years he, his brothers and their dad fought in WWII. 34hornbutton1.JPG
    Ric Dean, Tman, FORDY 6 and 16 others like this.
  3. vtwhead
    vtwhead
    Being an old salt myself...……………. you know I like that horn ****on!
    greaser and loudbang like this.
  4. atch
    atch
    I also happen to be a former member of Uncle Sam's big canoe club. Nice horn ****on Rocky. Especially since it was your father's belt buckle.
  5. belair
    belair
    Cool details. Thanks for sharing.
  6. Snipe
    Snipe
    I like it! (U.S.N. 1966 - 1987) Loved every minute of it.......well most of it anyway.
  7. 31hotrodguy
    31hotrodguy
    Go Navy! Looking good sailor!
  8. Rocky
    Rocky
    Classified Editor
    I was never happy with the old original [but NOS] 57 Pontiac oil pump...never seemed to have enough pressure to me. So I bought a 400 Pontiac Melling #54D, 60 psi pump, knowing the pump body was different and it wouldn't bolt up to my earlier engine. However, I did know the guts would interchange directly into my old ancient 52 year old pump body so I popped the oil pan off this afternoon and yanked the pump out....swapped the internals from the melling pump into my existing pump and slapped the modified pump back on the engine. By then I was exhausted and now it's after 1 AM here. I'll catch a quick shower and hit it again tomorrow....its' gonna be epic! I can't wait to see 60 PSI oil pressure....it'll prolly leak from every gasket and seal!
    In the photos, the straight cut gears are the new ones. I forgot to click a photo of the new pressure relief spring VS the old one but the difference is easily seen. Also check the difference in pump cover thickness....the old one is paper thin sheet metal and the new one is like, 1/4 inch thick!!
  9. Tim
    Tim
    from KCMO
    Awesome!
  10. Frankie47
    Frankie47
    from omaha ne.
    Looks good Rocky! My Gramps fought in the Pacific on an oil tender and I was an AMH2 aviation hydraulics man myself.
    GO NAVY!
    RICH B and loudbang like this.
  11. Rocky
    Rocky
    Classified Editor
    Alright now! I gots oil pressure! Use to idle at 5-10psi and 30 psi at cruise RPM. Now cruise oil pressure is 60 and it idles at 40 or so...and a pesky oil leak apprears to be gone too...but I only let it run for 20 minutes. Fingers crossed on that oil leak.
  12. brEad
    brEad
  13. I didn't know that was the way to stop an oil leak; increase the oil pressure. :)
  14. Rocky
    Rocky
    Classified Editor
    It was wishful thinking but it's much better. Just a quarter size puddle overnight.
  15. wheeltramp brian
    wheeltramp brian
    Good to know about the oil pump gear interchangeability.i shimmed the spring on mine and got 10 extra psi.ive got max of 40 and min of 25-30
  16. Roadsir
    Roadsir
    That's a neat solution, and worked as planned!
  17. Tim
    Tim
    from KCMO
    Only a quarter? That’s not a leak, that’s preventative maintenance. Keeping that belly rust free!
    kidcampbell71, brEad and loudbang like this.
  18. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Man thats a cool oil pump hack-!!
    kidcampbell71 and loudbang like this.
  19. catdad49
    catdad49
    That's just pressure relief! Way to go, Rocky.
  20. Rocky
    Rocky
    Classified Editor
    Brian...the #54D has the parts to give you 60# if your bearing clearances are reasonably tight. I think it's the 54A that is 40#.
    31hotrodguy, loudbang and Tim like this.
  21. wheeltramp brian
    wheeltramp brian
  22. Rocky
    Rocky
    Classified Editor
    silicone some jazzy chrome nut covers on my quick change bolts...nothing else to report except I need to get a new vega steer box. My old original needs to be adjusted every 300 miles or so to get the slack out of it.
  23. HOTFR8
    HOTFR8
    Oh well. Looks like I am not going to get that ride in the Coupe this time. Good luck sorting out that steering box.
  24. Tim
    Tim
    from KCMO
    Bummer. Think you’ll outright replace it or just rebuild it? I often hear of aftermarket ones not holding oil very well
  25. Rocky
    Rocky
    Classified Editor
    Still have to do some research on new VS rebuilding my old original steer box.
  26. Tim
    Tim
    from KCMO
    Hopefully it’s something as simple as a bushing with to much slop in it and it’s not off the road to long.
  27. Blakmerk
    Blakmerk
    from St.Joe MO
    MO-KAN is straight south, steering would go east or west.
    See you there.
  28. Rocky
    Rocky
    Classified Editor
    OK, Brad....I'll set the sum***** on cruise control, open the windshield and take a nice nap at 70 MPH.. See ya there.
  29. Tim_with_a_T
    Tim_with_a_T
    My understanding of the Vega box was that it does not have standard bushings, so when you go to sleeve it, things can get expensive/impractical. That is what I was told when my Vega box was found to be pretty sloppy, so I just bought a new one. Maybe I was told incorrectly, though?
  30. Rocky
    Rocky
    Classified Editor
    I dunno, Tim but I'm going to do the same. Not really time to rebuild this box and do all the stuff I wanna do before the HAMB Nationals on Aug 17th.
