Hot Rods Flathead suddenly running like crap.
Discussion in 'The Hokey Ass Message Board' started by AeroCraftsman, Jun 1, 2019.
  1. AeroCraftsman
    AeroCraftsman
    So the weather has been great, the rains have stopped for a while and I’ve been driving the roadster quite a bit. Has been running great.
    All of a sudden it started running worse and worse, to the point it’ll barely accelerate up the street.
    Pulled the plugs and they were very sooty. Cleaned and reinstalled, no change.
    Looked at the rotor, normal wear. Couldn’t really see inside the cap without pulling all the wires.
    Replaced the coil, no change.
    Replaced the plugs, no change.
    I should probably mention it’s got a Pertronix elec.ign. in place of the points, so no condenser. Either works or doesn’t I’d think.
    Starts right up and idles. Not as smooth an idle as normal, but OK. Under load there’s a lot of exhaust smoke and it’s really choppy sounding.
    It’s got dual 97’s, don’t remember the jetting, but it’s been fine up to now.
    It seemed to start after my last fill up. 91 octane, ethanol free from a reputable station.
    I’m sure open for suggestions at this point.
  2. big duece
    big duece
    from kansas
    Float setting, needle and seat, power valve I would look at first...
  3. Doublepumper
    Doublepumper
    from OR-WA, USA
    Possibly a blown power valve...?
  4. alchemy
    alchemy
    The power valves in Strombergs don't "blow".
    Could the distributor have slipped its clamp? Timing off?
    clem likes this.
  5. AeroCraftsman
    AeroCraftsman
    It’s a crab style. I’ll check the mounting bolts just to be sure, same with the advance slider.
  6. Slopok
    Slopok
    Even so, could it be water in the gas???
  7. Doublepumper
    Doublepumper
    from OR-WA, USA
    D'oh :oops:
  8. Petejoe
    Petejoe
    from Zoar, Ohio
    Check your voltage off the generator and the battery.
    Check your spark off the wires.
    I’d suggest you stay in the electrical area.
  9. AeroCraftsman
    AeroCraftsman
    What’s the saying? 90 percent of all carburetor problems are ignition....
  10. Rickybop
    Rickybop
    You said...
    Worse and worse
    And...
    Lots of exhaust smoke
    And...
    Very sooty plugs
    You're running very rich all of a sudden. I'd guess a stuck Inlet needle valve or a gas logged float.
    First thing, I just simply rap on the inlet area of the carbs with something that won't damage anything... maybe a screwdriver handle. You might loosen a needle valve if it's stuck. See if it makes a difference.
    Sent from my VS835 using The H.A.M.B. mobile app
    flatford39 likes this.
  11. Rickybop
    Rickybop
    Kind of thinking a heavy float though. Cuz you said it quickly got worse and worse. Could be the float started taking on gas and it didn't take very long for it to get too heavy.
    It doesn't usually happen with metal floats. Are yours made of cork?
  12. BamaMav
    BamaMav
    from Berry, AL
    It does happen though. I have seen br*** {plated?} floats get a pinhole and fill up with gas and sink.
  13. AeroCraftsman
    AeroCraftsman
    Problem solved. I don’t have the chokes connected and the one on the front carb was just slightly closed. Not even enough where you could see it, but when I moved it, I felt it tick open just a little bit. Also cleaned the sediment bowl, but after moving the choke, it revved right up nice and smooth like it always had.
    A little bit more exhaust than I’m used to, but I think that’s the soot burning out. I’ll know for sure when I test drive it tomorrow.
    Petejoe and flatford39 like this.
  14. AeroCraftsman
    AeroCraftsman
    Oh yeah, I pulled a plug lead and it was throwing a 1” blue spark to the plug.
    And thanks for all the suggestions. Glad it was something simple.
    big duece and flatford39 like this.
  15. Rickybop
    Rickybop
    Me too.
    Yup, definitely running rich LOL. I always forget about the closing chokes. I guess it happens more often than I was ever aware of. Glad you got it figured out, AC.
  16. alchemy
    alchemy
    Uncle Max sells a nice little pointer thing that fits into the choke arm detent. It locks the arm in the open position. Very simple and does the job.
