Projects The Brooks Special - louisb’s 29 lakes roadster build
Discussion in 'Traditional Hot Rods' started by louisb, May 11, 2018.
  1. Aaron D.
    Aaron D.
    Yep, 105 miles so far :)
    chryslerfan55, 48fordnut and louisb like this.
  2. Fyresq
    Fyresq
    from Minden, NV
    Been enjoying this thread and providing motivation for my own build [emoji481]
  3. louisb
    louisb
    Quick update. My 15 year old Craftsman compressor decided to die so I ended up ordering a Quincy two stage 60 gal standup to replace it. Should power everything in the shop with no trouble. Took a couple of weeks to get it delivered and installed but I finally got the body in primer this morning. Some minor filling, then high build primer and lots of block sanding next.
    And yes my shop/two car garage is really packed right now.
    --louis
  4. rwrj
    rwrj
    from SW Ga
    Looking better and better. Really nice work throughout.
    Stogy and louisb like this.
  5. Aaron D.
    Aaron D.
    Nice compressor Louis. The Roadster is looking good too.
  6. louisb
    louisb
    Got an update on the engine. Dan at Hill Country Machine has been working on the 59L block. The block had already been bored 3 5/16 so the plan was to take it out to 3/8s but some pitting in the cylinders was to deep. So Dan ended up installing 8 sleeves and will bore it to 5/16 leaving plenty of meat in the cylinders.
    A53F451C-AAE7-4F9B-B319-0C55F46FAEE5.jpeg C6312B41-FDE8-4EE8-B47C-2023B2E80B75.jpeg EA38F8CB-4318-49CA-AFE8-80E4733F2AC9.jpeg E88FB6A7-DD1D-481D-BB83-B4874A162CA1.jpeg 3E39DAC0-D5CE-4F97-A50F-EBEA95B28403.jpeg A77369E8-12B6-42E2-81BD-B68642C3EBED.jpeg CCE971A6-5957-49B7-B8BB-CCCA4CD4A26F.jpeg
    Thanks,
    —louis
  7. Aaron D.
    Aaron D.
    I know it's a lot more money to put 8 sleeves in, but, when I was cleaning my block there was corrosion pitting on the water jacket side of the cylinder walls, some pretty deep. I think with the sleeves installed, it's a little insurance that you won't have any thin areas of corrosion that could lead to water going into the cylinders at some point. I wish I would have had some installed in mine when I had the chance.
  8. louisb
    louisb
    Dan's making good progress on the engine. Lot's of attention to detail. Sorry if the pics are out of order.
    62169745_411424959584206_7837106312883812333_n.jpg 62231159_508519443250755_8492309004198071956_n.jpg 65117034_610896812652431_5893967223831840367_n.jpg 65117828_383508298962204_2363954657918684718_n.jpg 65168633_1259153230919513_1790444911103177285_n.jpg 65510904_2346248725617099_5389475077851026128_n.jpg 65837971_455819191660721_831859799617586076_n.jpg 66205500_375436133110625_5105074889405293812_n.jpg 66242534_379549796032931_7679004723122254328_n.jpg 66417240_402989967091519_2477078356074008665_n.jpg
  9. louisb
    louisb
    Working on the Merc crank and rods.
    61803148_492098254939590_1710773368045837081_n.jpg 65043063_1031217217086351_759668316131580810_n.jpg 65159852_695473080881288_3521957965708784007_n.jpg 65219552_1515749425240389_8895014704222244290_n.jpg 65307480_504016896805280_4629281692794318516_n.jpg 66203051_249878119303769_7144503169257571841_n.jpg 66317110_1116889745186722_3683606174524277173_n.jpg 66371952_146254576490824_3500705411113521011_n.jpg
  10. louisb
    louisb
    And more
    65300393_335482174041688_1711219729793806928_n.jpg 65584298_369604813738846_4049662071938067269_n.jpg 65966308_428563007988310_4876705295219867889_n.jpg 66039349_440302476811339_2001243372781891326_n.jpg 67090632_1120370751505297_6453953433576825082_n.jpg
    Final size will be 276.
    Thanks,
    --louis
    Outback, slv63, kidcampbell71 and 5 others like this.
  11. Atwater Mike
    Atwater Mike
    Louis... 276" is 5/16 X 1/4. ("five-sixteenths by quarter", in the 'lingo')
    Are your sleeves bored to 3-5/16" OR 3-3/8"?
    I read you were going to 3-3/8" above, so did you end up at 3-5/16"?
    Thanks...building another flattie myself....
    Stogy, kidcampbell71 and louisb like this.
  12. louisb
    louisb
    Hi Mike,
    Since we ended up sleeving all eight cylinders we decided to go 5/16 and leave plenty of meat for a future overbore should it be needed. Good blocks are getting so hard to find. Dan says he is happy we made the call to sleeve all eight because it is like working with a new block.
    Thanks,
    --louis
  13. louisb
    louisb
    While Dan is making good progress on the Flathead I have started the body work in earnest. Built a quick and dirty chassis rotisserie from some HF engine stands. Makes it a lot easier and clears up some much needed space in my 2 car garage shop.
    IMG_20190713_143305.jpg IMG_20190713_143348.jpg IMG_20190713_171016.jpg IMG_20190713_171557.jpg
    Fill, sand, prime, sand repeat until flat.
    MVIMG_20190715_095945.jpg IMG_20190715_095935.jpg MVIMG_20190714_111120.jpg IMG_20190715_105910.jpg
    The dark areas are all low. Lots more priming and blocking needed to get ready for the neon green metal flake paint. :D
    --louis
  14. brEad
    brEad
  15. Aaron D.
    Aaron D.
    Ya man, that neon green metal flake will look great with the 24" chrome rims :cool::cool::cool:
    louisb likes this.
  16. louisb
    louisb
    Spent five hours block sanding yesterday which doesn't look that interesting in pictures. But Dan sent me these pics of the heads back from the polishers. Engine is going to look good!
    Stock Ford Canadian aluminum heads that have been milled for compression. Can't wait to see the new intake when it comes back from the polisher.
    --louis
    Outback, 48fordnut, Stogy and 9 others like this.
  17. Aaron D.
    Aaron D.
    Nice!
  18. louisb
    louisb
    Tired of seeing flathead engine building pics? Nah, me either. Sometime in the past the 59L block had been mildly ported but Dan wasn't happy with the work and spent some time reporting the block and intake to his satisfaction.
    61996094_154241062301393_5595405058375003939_n.jpg 66294786_1252147041633700_3736583438978782777_n.jpg 66321180_125031338756273_4975113515826692966_n.jpg 66417507_476646129572199_5503684358273409460_n.jpg 66420132_389398098595581_1772956947175901202_n.jpg 66427555_2359127967679046_7057460169413743707_n.jpg 66509207_401450113827007_7244310164606423883_n.jpg 66682412_2317527668334329_5630326653181351310_n.jpg 66690128_650605628772456_694906959412446253_n.jpg 66989836_371015913605032_3287732560154508180_n.jpg
    Thanks,
    --louis
    Outback, Stogy, Tim_with_a_T and 5 others like this.
  19. FlatJan
    FlatJan
    holy crap.. That's gonna be a killer motor /car!
    Btw I'll never get tired of those engine build pics!
  20. louisb
    louisb
    I have this reacuuring dream where I spend all my days block sanding a car and it never seems to come out straight. Then I wake up and go out in the garage and block sand some more. Remind me again why I decided to choose black for my first paint job? Oh yeah, cause it will look killer when done.
    In other news Dan is about ready to start actually assembly on the engine. All the machine work and balancing is done.
    66380565_1631357323661718_2038975795514813393_n.jpg 66619295_162030031516178_5290834883360932895_n.jpg 66646993_163864764744877_7797569941945150283_n.jpg 66704453_426556007953864_9107052251284779904_n.jpg 67132947_2093173814321729_998396183753581969_n.jpg 67197136_361906601406385_6956403622098557237_n.jpg 67357525_2341221266151965_2508678419698455184_n.jpg 67508253_511605099648290_3877670769734561734_n.jpg 67585489_1354497304704522_1706080874662862887_n.jpg 67805978_127863208484946_1578095157350951026_n.jpg 69267867_132556681304016_5779535326514777399_n.jpg
    Dan is making me step up my game for the rest of the car. The engine is going to be to nice for the jalopy I had planned. :D
    In one of the engine photos you can see the fully polished Hemi that Dan is building for a customer. That engine is unreal. If you are on Instagram you can find Dan at @dansoliz. His work is amazing.
    --louis
    --louis
    Stogy, Tim_with_a_T, lodaddyo and 3 others like this.
  21. louisb
    louisb
    Been a while since I last updated this thread. We bought a new house and are in the process of selling our old house which means the project is on hold for a while. Still trying to get a few small things done. Sent my S&W Wings gauges out for rebuild and the GM gauge panel out for chrome plating. Dan is getting back to the engine soon, he put it on hold while I moved so I wouldn’t have to move the engine too. Not looking forward to packing up my shop and moving all my tools/parts. Same town just a bigger house and enough yard to eventually build a real shop one day.
    Hopefully I will be able to get back to it in a couple of months.
    —louis
    Outback, 48fordnut, Stogy and 6 others like this.
  22. Aaron D.
    Aaron D.
    I know what that's like!
    Stogy, loudbang and louisb like this.
  23. 1-SHOT
    1-SHOT
    from Denton
    When I packed up and moved 40 miles 40 years ago I had the same problem. Got the kids raised and after I had been here 20 years finally built a 30X60 shop. Still working on cars @ 77.
  24. Sculptive Design Co.
    Looking good! A really nice build. That flathead will move that 29 around nicely.
  25. Stogy
    Stogy
    Hi Louis hope you were able to get your move accomplished before the fan got covered in the brown stuff.
    Does your new place have a garage at all? I suspect you are going to have to find one for the Brooks Special...
    I hate moving...I'm still recovering from it near 3 years after...
    I hope yours is WAY better...;)
    A wish for good health to you and the ones you care for @louisb.
  26. louisb
    louisb
    Hey Stogy,
    Things are going well, just been swamped with new house stuff. Spent the weekend working on a storage shed so I can clear out enough space to work on the roadster.
    Since my roadster is on hold till at least this summer I picked up a side project. Bought a 51 GMC half ton long bed and sent it to Andy Kohler at Kohler Kustoms. He is going to go through the mechanicals, lower it bit and get it going as a daily driver for me. Hope to have it done this fall.
    Thanks,
    —louis
    Outback, kidcampbell71, brEad and 4 others like this.
  27. Stogy
    Stogy
    You guys and that southern metal...I know its more solid than it looks...Thunder Andy...awesome choice man...Look forward to what you fella drum up...Stay safe...
  28. louisb
    louisb
    Small update though I am pretty stoked about it. Got the last piece of my gauge cluster assembly back today. Lots of work went into this assembly.
    The gauges are original S&W wings that were rebuilt by Williamson Instruments and they did a great job. Gauges are now 12v, fully rebuilt and all the bezels replaced. He also cut new curved glass for the speedo.
    The GM panel was replated by DGM Chrome Plating in Philly. (@dgmchrome on Instagram) was great to work with and very reasonable.
    Last but not least Haneline Products did the metal turned insert for the GM panel. It was the first one they have done so I ended up sending the the panel to make a pattern. Now that they have a pattern they can do one for you too.
    Thanks,
    --louis
    Outback, Stogy, barrnone50 and 9 others like this.
  29. brEad
    brEad
    Dash panel looks killer!
    Stogy, louisb and kidcampbell71 like this.
  30. louisb
    louisb
    Tony at Hill Country Machine has my block featured in his first YouTube series which is about Flat Heads. He just released the first video yesterday:
    He told me that final assembly should be done soon. Can't wait to hear it run.
    --louis
    Outback, Fairlane500, Stogy and 5 others like this.
