Technical ***June 2019 Banger Meet - Ready 4 summer/winter?***
Discussion in 'Traditional Hot Rods' started by Jiminy, May 31, 2019.
  1. V4F
    V4F
    from middle ca.
    maybe water or dirt on refuel ……...
    Old Dawg likes this.
  2.
    surf10 and Dannerr like this.
  3. railcarmover
    railcarmover
    A lot to be said about this comment, a brother wanted to cc my aluminum winfield to be dead sure about the CR..I answered 'why? Im gonna run it no matter what' ..its the same with horsepower,who cares what it actually is,when the car is fast enough you'll know..
    Jet96, Dannerr and Crazydaddyo like this.
  4. dmdeaton
    dmdeaton
    2 winters and finally around the block last weekend.
    Hamtown Al, ROCKER77, GuyW and 9 others like this.
  5. There you go! [emoji1377][emoji16]
    Keep ‘em kruzin!
    Dannerr
  6. Jet96
    Jet96
    from WY
    1381E545-22FF-4FAA-8AEC-4216ED64B997.jpeg Had great weather all week, put about 250 miles on. Got 97's cleaned out/dialed in. Stock exhaust is nice for dialing in timing, I'm welding up some cooler stuff though haha
  7. Jet96
    Jet96
    from WY
    BB7BEDDC-3830-4828-81B9-EA6529DE6FD6.jpeg One of my carbs tended to flood badly on occasion, you can see the culprit peeking out under the float...
    Garagekulture13 and winduptoy like this.
  8. dmdeaton
    dmdeaton
    Is that the needle wedged in there?
  9. So a couple months back someone was mentioning the oil pump drive on a Donovan block.
    The issue was/is filling the two grooves of the drive housing.
    Yes, it is a must for the Donovan motor, suffice it to say the "B" Ford and Donovan are very different.
    On the Donovan, even if you run an external pump you must put the drive housing in place and block off the two reliefs. Just for reference, if you get to working on one.
    John
    winduptoy and Dannerr like this.
  10. MJW
    MJW
    from NJ
    Getting further along with my '29 roadster banger project. More picts and details on my Instagram @markwellnitz if you use it. Getting ready to fire it up once the battery charges to spin the mag fast enough to light it off. IMG_20190608_153422_909.jpeg IMG_20190608_152825.jpeg
    Sent from my Nexus 6P using The H.A.M.B. mobile app
    Dannerr, dmdeaton, murf 32 and 3 others like this.
  11. Jet96
    Jet96
    from WY
    dmdeaton- Yup that's a needle! ! I have no idea how it got in there. It had been rattling around in there for a while, the edges were worn pretty smooth. When I got this carb/intake setup I just popped the tops off and did a quick once over and ran them. They ran fine but this carb would randomly flood really bad. I get a kick out of opening up old carbs, I've found some pretty odd stuff but never an extra needle....
    Garagekulture13 and Dannerr like this.
  12. V4F
    V4F
    from middle ca.
    is that where you found it or just a nice pic ……...
  13. JT1930
    JT1930
    Where can I find this lake header. I thought I saw them in gear drives website but maybe it was someone else. Thanks. 568D0D81-40A4-47A8-B0BC-A4344143DF37.jpeg
  14. Jet96
    Jet96
    from WY
    V4F- I took the pic last week while out cruising. I just pulled off to get the highway out of the picture.
    Dannerr and Hank56 like this.
  15. Jet96
    Jet96
    from WY
  16. callcoy
    callcoy
    Transport to West Coast
    Headed to S.F. Bay area via Bonneville from the Nashville area late July early Aug with a empty 16" 7000# cap open trailer. Can haul a car or parts west and parts only east mid Sept. Call only to discuss Steve at seven o seven 4 eight 0 4 six o six
    Dannerr likes this.
  17. My computer Croaked and I was dark for few weeks! Report on VARA's race at ****onwillow Raceway: I qualified in 1st Place with a 2.24:303 min. lap (my best ever at that track)! That put the lap average at over 82 m.p.h.! I was hitting over 105 m.p.h. down the back straight (calculated) with a 4.11 gearing. But in the main event the carburetors began to dismantle themselves, so I shut down. Screws on the top of the airhorns and floats started to come of; and a drain plug on the rear carb dropped completely off. The fix was to replace all screws with drilled head cap AN Screws; and safety wired them. I took the drain and Jet plugs off and completely cleaned them. I put them back loose (not all the way in); put a dab off Permatex non-Harding Thread Sealer on a feeler gauge. I laid the feeler gauge on the last threads and screwed the plugs towards home pulling the gauge out as it went. NO LEAKS! Before the car goes on the track each tine, a tape over a clean set of drain plugs will be in place!
  18. burl
    burl
    from Minnesota
    Matt still making them.Give him a call.
    JT1930 likes this.
  19. Jet96
    Jet96
    from WY
    5FA2E369-F73E-41EF-B29A-5ABCCDE05D66.jpeg BF7B224D-B5AE-4AE1-9B83-4EE0FFDAAAC8.jpeg We got a ton of rain here around Memorial Day, caused some major slides...
  20. fourd
    fourd
    from Colorado
    So I am pretty sure I need to pull the flywheel out of this car. The hood fits poorly at the grill so I guess I can fix that too.
    B motor and B transmission with stock B flywheel. My questions are: Lighten the stock B flywheel? Standard cut down A flywheel and does that fit the transmission? Custom flywheel? Did I see WindupToy with some? I want this fix involve the last flywheel and pressure plate I ever buy for this car. Thanks and I look forward to great advice as always.
  21. Why do you need to work on your clutch and flywheel? Is there something wrong? Vibration, slipping or chattering? Do you have a stock '32 transmission? Inquiring minds need to know! Example: I have a rather powerful high revving "Banger" in a light race car! The flywheel is balanced (along with everything else that rotates) "cutdown"; but slightly to fit a V8 9" clutch. The friction disc is one solid plate steel! It's not very "roadable" because without the springs in the disc it slams into gear!
    Dannerr and Jet96 like this.
  22. JT1930
    JT1930
    @fourd just balance your setup. I cut my stock A flywheel down only to fit my bellhousing but after balancing all vibrations I’ve had before are gone. Drives great. You can use what you have or goto a v8 clutch. I went with the v8 clutch and it’s pretty nice to drive.
  23. V4F
    V4F
    from middle ca.
    nice pic … no ofense
    Jet96 likes this.
  24. burl
    burl
    from Minnesota
  25. denis4x4
    denis4x4
    from Colorado
    Loading up tomorrow and heading out Monday to Lincoln NE for the Speedster Reunion at Speedway. Since my brother and I are both 6' tall, thought the extended cab CCPU was a better choice than the Zipper. Will post photos when I return.
  26. Jet96
    Jet96
    from WY
    5EA5C597-FB38-462D-BBFD-8EBD23C585D6.jpeg Drove roadster every day to work this last week. Getting the 97's dialed in. Flooding thing figured out. Jets are about perfect, might drop down a couple sizes on PV's...Did about 80 miles up in the mountains and back Sat. after work. Got caught in the rain on the way home. I stayed over 60 so I didn't get too wet haha. Perfect day!
    Note to self: get Rain-X.
  27. ratamahata
    ratamahata
    from Argentina
    Hey guys... Found a Police Head, I bought for my banger engine... Originally model A block with a C head on it...
    received_341367526576053.jpeg received_2520257334672879.jpeg received_615249475657829.jpeg
    Sent from my Mi A1 using The H.A.M.B. mobile app
    winduptoy, Dannerr, Binger and 4 others like this.
  28. Dustyp489
    Dustyp489
    Late. But checking in.finally got the new jets installed, checking for any leaks, been sitting since fall. Hope to get back on the road by next week.
    Skip
  29. It's coming up fast! Who needs a racer entry form? Pre registration helps get you in quicker. There are swap spaces available too for $40! There is also a $500 cash award ( the Mike Spangler memorial award) for the best spectator specialty car. So drive your old car, hot rod or custom even if you're not racing. Let me know if you need a pre-registration form!
    Dannerr, Crazydaddyo and waxhead like this.
