Technical F100 dropped axle, leafs and steering setup??
Discussion in 'The Hokey Ass Message Board' started by Sammy Cakes, Jun 6, 2019.
  1. Sammy Cakes
    Sammy Cakes
    I recently bought a 1960 F100 with 3" Nostalgia Sid's dropped front axle and 2" drop blocks for the tie rod. It has Western Ch***is lowering leaf springs all around too. There's also a steering stabilizer and sway bar kit. The truck is really hard to steer (way harder than my other manual steer trucks). It feels notchy too.
    I looked under the truck and it appears like the tie rod is touching the oil pan. The leafs also appear to be arched in the opposite direction. Is this normal? I'm including some pics and the build sheet so you can see what has been done to the truck. Any suggestions on making this steer/ ride better are greatly appreciated!
  2. guthriesmith
    guthriesmith
    I would call Sid 405-416-3080 and talk to him about the setup too. He is great at making sure to get you set up right.
  3. guthriesmith
    guthriesmith
    But...seems the springs may be your main issue.
  4. Sammy Cakes
    Sammy Cakes
    Thank you! I did send a couple of emails to Sid. Maybe a phone call is better. The guy who sold me the truck is adamant that the setup is correct and that lowering leaf springs just look that way. Do you think the weight of the 5.4L and auto trans would contribute to the sag? Is there ever a scenario where leafs are meant to be arched in the opposite direction, or is that just plain wrong?
  5. RMR&C
    RMR&C
    from NW Montana
    De-arched springs look like that. I'd be more worried about the drag link angle.
    Gotta have bump steer....
  6. Sammy Cakes
    Sammy Cakes
    Thank you for the input! Sid said the drag link angle was no good either. I think that's why the previous owner installed the steering stabilizer, because of the bump steer. I heard that people heat and bend the spindle arm to compensate for that. However, can't I just buy some kind of dropped drag link like the 4x4 guys use? upload_2019-6-6_14-53-12.jpeg
  7. Mr48chev
    That drag link angle has to give some terrible bump steer and probably half the reason for the steering stabilizer. I don't know if shock clearance is an issue but the drag link should be a lot closer to level which means that the steering arm from the spindle needs to be bent down accordingly or replaced with one with the correct drop.
    On the springs, I'd email Western Ch***is with a photo but am like RNR&C in that that is the way they are set up.
    Pan clearance have the steering arms been dropped? At any rate that is the . thing that has to be taken care of as the tie rod will eat a hole in the pan in short order the way it is now. You may end up changing to a pan that has a more friendly shape to it or having that pan modified for clearance.
  8. Atwater Mike likes this.
  9. wheeltramp brian
    wheeltramp brian
    You can buy dropped tie rod ends from Speedway motors a**** other places
  10. bonzo-1
    bonzo-1
    No bump steer because of the oil pan steering brake.
  11. bonzo-1
    bonzo-1
    No because the two ends need to be level.
  12. bonzo-1
    bonzo-1
    That front end needs some major work. Raising the engine to clear the tie rod and lowering the steering arm to level it out should take care of most of it. Your castor shim looks like more of a spacer than an angled shim.
  13. bonzo-1
    bonzo-1
    If you drop the tie rod lower it will be below the scrub line.
  14. sunbeam
    sunbeam
    Is the spring tie- axle locating bolt the same distance from both ends if not are the springs installed right? It is hard to tell from the picture but the axle looks farther back than other 57-59 trucks. Moving the axle forward would help with pan clearance.
  15. Sammy Cakes
    Sammy Cakes
    That's funny!
    Kodak Jack likes this.
  16. Sammy Cakes
    Sammy Cakes
    Yes, the tie rod drop blocks are kind of hokey in my opinion, but they drop it by 2", whereas the dropped tie rod ends only drop it by 1.5"
  17. Sourwood
    Sourwood
    from Atlanta Ga
    I would take a look at starting over, get rid of the dropped axle . There are better ways. I know three guys who have sold there dropped axles and enjoy the ride a whole lot better. Those tie rod ends are just **** and scary. Here's a picture of my 63, though its not that low it still lower that stock and drives like new. And all the parts are factory except the reverse eye leafs, ans the two inch body drop.
    Sourwood
    alanp561 and 6sally6 like this.
  18. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    As already said, tie rod rub is bad, as is steering rod angle. You could fab a bracket and move the steering box up a couple of inches. Lots of work needed there.
    It shouldnt drive like a potatoe wagon when you get it dialed in
  19. Doublepumper
    Doublepumper
    from OR-WA, USA
    Just looks like it never got properly finished. To use what you have, bend the steering arm down to get the drag link level. Use dropped tie rod ends and loose the blocks. Modify the oil pan for clearance. Check shocks for adequate travel.....done.
  20. Sammy Cakes
    Sammy Cakes
    All good input. I actually have some reverse eyed springs that came with the truck when I bought it. I wonder if I should reinstate them. The tie-rod would clear the pan and the spindle arm wouldn't need such a drastic adjustment. But then the front might be jacked up in the air compared to the back. I also have a stock height '64. It's my pride and joy. This lowered thing is all new to me.
  21. I'd start with the other stuff first & then maybe install the other springs if you're still having issues.
  22. Sammy Cakes
    Sammy Cakes
    I've enlisted the help of an able-bodied friend who is willing to help me heat and bend the steering arm. We'll take it from there.
  23. alchemy
    alchemy
    Usually heating and bending the steering arms is done with a bare spindle. You will cook the grease in the kingpin boss, if not even warp the bushing a little. And I would sure never do it with the brake hose right there. It takes a LOT of heat.
    But, this is a necessary job to help correct your extreme drag link angle. Might not make it perfect, but it will be a lot better. Make sure to re-center your steering box afterward, then adjust the drag link to fit.
    I have a pair of those dropped tie rod ends from Speedway and they look OK. I'd recommend them for you, and if that doesn't give you enough clearance from the oil pan, take a saw to the pan.
  24. Sammy Cakes
    Sammy Cakes
    Thanks for the info. We were gonna do it on the truck, lol! Could have been bad!
  25. 1946caddy
    1946caddy
    from washington
    To start with, those are not caster shims but spacer blocks to raise the truck so the tie rod will clear the pan. I would put the stock springs back in it to bring you back to about where you are now. You either need to raise the engine-transmission to clear the tie rod or modify the oil pan. Dropped tie rod ends will put you below the scrub line. Modifying the pan would be the easiest way to go. Either get a drop steering arm or bend your arm to get rid of the angle as suggested.
  26. D-Russ
    D-Russ
    Like someone else said, raising the steering box will fix half of your problem. I made this simple box from 3/16 plate to raise my steering box 5 inches. I moved it forward 1-1/2 inches while I was at it because I moved the axle forward that much. Drag link ends up parallel with the ground. I think you'll also need to install some positively arched springs to fix the rest of the issue.
    Zax likes this.
  27. Sammy Cakes
    Sammy Cakes
    They are definitely caster shims, but the angle of my first photos makes them look like spacers. Here's a better shot. The raised steering box is interesting to me. I do need to investigate the box as well because there is a LOT of free-play in the steering wheel. There's maybe 4" to 5" of travel from left to right before I feel any resistance. That's pretty insane now I think about it!
  28. earlymopar
    earlymopar
    That much steering box slop can't be "adjusted-out". A rebuild or replacement is in order.
    - EM
  29. Sammy Cakes
    Sammy Cakes
    Maybe someone is selling a decent one on here somewhere
  30. alchemy
    alchemy
    The trouble is a box may feel nice on the bench, but once it is in the truck you can feel the extra slop.
    In your case though, I wouldn't be surprised if a lot (most?) of the slop is in the weird dropped steering arm extensions.
