Technical Metal fuel line
Discussion in 'The Hokey Ass Message Board' started by chttles, Jun 14, 2019.
  1. chttles
    chttles
    Looking for a metal 3/8 fuel line from fuel pump to carb on a 1966 327...having a hard time finding one that is accurately run behind the water pump
  2. gimpyshotrods
    gimpyshotrods
    DIY.
  3. jcmarz
    jcmarz
    from Chino, Ca
    Make your own. It's easy peasy!
    Sent from my SM-J737T1 using The H.A.M.B. mobile app
    Blue One, kadillackid and D-Russ like this.
  4. squirrel
    buy three pieces of pre flared fuel line, the third one you'll bend the right way....
  5. BamaMav
    BamaMav
    from Berry, AL
    Use wire or coat hangers for a pattern, then bend one to suit.
    kadillackid likes this.
  6. el Scotto
    el Scotto
    from Tracy, CA
  7. patterg2003
    patterg2003
    Ditto on bending a coat hanger or a heavy wire. That will allow the run to be perfected then bend the tube to follow the wire. As Squirrel said get about 3 pieces or at least 2. Mark a piece and put it in the bender so you can see how much tube it takes for a 90 bend. You can eye the 90 degree bend over the wire and see where the tangent occurs then mark that on the 90. It is possible to measure and mark the start and ends of each bend with reasonable accuracy. If it is complex it may take a couple tries.
  8. noboD
    noboD
    Look in restoration catalogs for a car that uses the same carb.
    pprather likes this.
  9. 41rodderz
    41rodderz
    from Oregon
    I would just PM DDDenny . I am sure if you ask nice he would give you the one off his prized sbc.:D
  10. Tell me I am wrong, But I didn't think there was room behind a short pump to run fuel line?
    unless the OP has a long pump on it.
    And I don't recall the fuel line went behind the water pump went around it..
  11. vinfab
    vinfab
    66 is an odd year for 327s. If you order a prebent fuel line, you need to know the original horsepower rating. A 275 horsepower version could have used one of three different carbs. Early in the year it could have had a 600 cfm Holley or a Carter AVS. Mid year, they switched to a Rochester Quadrajet. The 300 horse version used a Holley with a cast iron intake, the same as the 275 version. Finally the 350 horse version used a Holley with a semi hi rise aluminum intake. So there are 4 different possible fuel lines.
  12. southcross2631
    southcross2631
    I had a ***** of a time bending my clothes hangers to get the right bends . Had to get my heat gun out to bend those plastic coat hangers. The good thing was they are the same diameter as the fuel line.
    catdad49 likes this.
  13. Blue One
    Blue One
    from Alberta
    But, that still doesn’t mean you can use that as your pattern until you figure out what your bend radius will be from the tubing bender.
    It will get you close but you know what they say about close.
  14. Blue One
    Blue One
    from Alberta
    Most of the auto parts places I shop at will order all 4 and then I’ll buy the one that fits.
    That applies to a lot of other parts too.
  15. 65pacecar
    65pacecar
    from KY, AZ
    I believe Fine Lines carries those of you want to buy pre bent lines.
  16. This place has all 4 of them listed and they are Cheep. Bought a fair amount of parts from them and so far very pleased.
    1966 Chevelle Parts @ OPGI.com
    https://www.opgi.com/chevelle/1966/
    Restore your 1966 Chevelle with premium quality restoration parts and accessories from Original Parts Group. Enjoy low prices, helpful experts,
