Projects fixing a smashed 31 model A pickup cab.
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Mar 17, 2019.
  1. tb33anda3rd
    tb33anda3rd
    all the pieces I have came from the same log. maybe the position it was sitting in the pile. top of the log saw more sun?
    I am just curios to see the difference over time and I wish I had checked it when I first cut it.
    loudbang and Stogy like this.
  2. Dago 88
    Dago 88
    Been following this, looks like fun. Here is mine with a two & half inch chop. Good luck :) 18486254_795665157265499_2325039750526650403_n.jpg
  3. tb33anda3rd
    tb33anda3rd
    I just went back and looked at the photos, I tested all of them at the end but the one that read the highest in the middle. maybe that is why?
  4. tb33anda3rd
    tb33anda3rd
    I just went back and tested the end of the piece installed across the back of the cab. 24% at the end.
    kidcampbell71, loudbang and Stogy like this.
  5. tb33anda3rd
    tb33anda3rd
    Charlie and I spent the day working on the truck today. we made a piece of 10 gage to bridge the two rear pillars. we pushed the posts apart to get the right shape. this will be used along with a new piece of wood .we then jacked up the post on the p***enger side and cut a relief to take the bow out of it. matched the shape to the door and welded the cut back up. IMG_5597.JPG IMG_5598.JPG IMG_5599.JPG IMG_5600.JPG IMG_5602.JPG
  6. tb33anda3rd
    tb33anda3rd
    we put the outer front post back on and then we made some angled pieces to connect the top of the windshield post with the back of the cab. this will hold the top of the door opening at the right width. we fit it to the doors. IMG_5603.JPG IMG_5604.JPG IMG_5605.JPG IMG_5606.JPG IMG_5609.JPG IMG_5610.JPG
  7. tb33anda3rd
    tb33anda3rd
    cab is squared up and the doors fit well. we also did some more shrinking of the rear panel. IMG_5607.JPG
  8. tb33anda3rd
    tb33anda3rd
    next step will be to repair the sills. we bent up a new rear crossmember. IMG_5615.JPG
  9. tb33anda3rd
    tb33anda3rd
    the slacker put in less than a 1/3 of a days work................7.5 hrs with a short lunch break.........
  10. ct1932ford
    ct1932ford
    Looks good for a Chevy guy!:rolleyes:
    Runnin shine, Hnstray, Stogy and 2 others like this.
  11. patterg2003
    patterg2003
    You are getting the cab back into shape & looking good. Enjoying your process to coax it back into shape & generous of sharing of the process. The perfect irony of using the tree for the cab wood.
    Hnstray, Stogy, nunattax and 4 others like this.
  12. King ford
    King ford
    from 08302
    TB33anda3rd, is thanks a bunch for sharing!...very educational for backyard hacks like myself!
  13. TFoch
    TFoch
    It's come a long way and looking good!
  14. bschwoeble
    bschwoeble
    Love this. I hope more people take the time to look and understand what is going on here. Like I've said before "If it wasn't created, I'm going to try and fix it".
    Stogy, tb33anda3rd and loudbang like this.
  15. ct1932ford
    ct1932ford
    Finished yet? :p
  16. tb33anda3rd
    tb33anda3rd
    rusty old truck cab =$250
    pile of 10-18 gage sheet stock= $75
    welding gases and wire= $80
    chain saw fuel/oil=$3
    spending time with the slacker.............priceless.
    Jet96, Nostrebor, dwollam and 9 others like this.
  17. ct1932ford
    ct1932ford
    Toms Dogs, MP&C, dwollam and 10 others like this.
  18. Dick Stevens
    Dick Stevens
    Them slackers sure seem to get some real nice work done when they have a mind to! :D
  19. The37Kid
    The37Kid
  20. LOWDUG37
    LOWDUG37
  21. tb33anda3rd
    tb33anda3rd
    worked on the cab this morning. Charlie was painting his patio so I was by myself. I ground the heads off the rivets holding the cross member and posed them out with the air punch. IMG_6631.JPG IMG_6632.JPG IMG_6633.JPG IMG_6634.JPG
    oliver westlund, MP&C, brad2v and 6 others like this.
  22. tb33anda3rd
    tb33anda3rd
    once I got it out I matched it up to the one I had bent up. I made a template of the out side edges and cut them out. IMG_6635.JPG
    oliver westlund, MP&C, brad2v and 5 others like this.
  23. tb33anda3rd
    tb33anda3rd
    both ends are bent down to follow the sill so I bent the edges down. I then test fit the piece before making the curved edge. IMG_6638.JPG IMG_6639.JPG IMG_6640.JPG IMG_6641.JPG
  24. tb33anda3rd
    tb33anda3rd
    of course I screwed up and had to add a piece to follow the body correctly. I fit it again, then made the outer returns by bending a strip of the same material and then forming it with the shrinker. once trimmed I welded it on and cleaned it up. IMG_6642.JPG IMG_6643.JPG IMG_6644.JPG
  25. nunattax
    nunattax
  26. tb33anda3rd
    tb33anda3rd
    so after I got the new rear sill in, I noticed the door on the p***enger side met the rear of the cab low. I thought I may have the sill mounted wrong or something not right under the post. the problem was the front windshield post. that door had a slight bind and the gap , even tho all the measurements were right, was tighter at the top and bottom than in the middle. the slight dip in the original rear panel compensated for the tilting door. there was a dent in the windshield post jamb, I decided to just cut it and pull the post straight, then re-weld it. IMG_6656.JPG IMG_6657.JPG IMG_6658.JPG
  27. tb33anda3rd
    tb33anda3rd
    once that was back into alignment, I cut out the sill on the p***enger side and trimmed down the Tudor sills that were given to Charlie. once that side was fitted, tightened down and the door gaps checked, I made a new middle crossmember. I fitted the crossmember, tightened it down and checked the door gaps. gaps still looked good so I removed the driver sill, fitted, tightened and fitted it. IMG_6659.JPG IMG_6660.JPG IMG_6661.JPG
  28. tb33anda3rd
    tb33anda3rd
    charlie showed up after lunch and we took it all back apart. Charlie cleaned up the new sills and I cup brushed the mating surfaces on the body . I also removed the two rear post brackets and sand blasted them. we then brushed a weld through primer on all the mating surfaces. IMG_6662.JPG
    IMG_6663.JPG IMG_6664.JPG IMG_6665.JPG IMG_6666.JPG IMG_6667.JPG IMG_6668.JPG
  29. tb33anda3rd
    tb33anda3rd
    we put all the pieces back on and fitted and checked all the gaps. I then welded all the joints. the truck is really solid now! IMG_6670.JPG IMG_6671.JPG IMG_6672.JPG
  30. tb33anda3rd
    tb33anda3rd
    MP&C, brad2v, dwollam and 5 others like this.
