55 210 Wagon Progress
Discussion in 'Off Topic Hot Rods & Customs' started by MP&C, Mar 24, 2013.
  1. rockable
    rockable
    I knew it wasn't straightforward and easy. Thanks! Great work!
    Could you post a picturecture of that vise grip tucker?
  2. MP&C
    MP&C
    Here's a post I did that shows building the tool as well as using it...
    To expand on the pictures from OJ's event this past weekend, here is an online friendly tech thread on shrinking that should have prefaced the lead demo.
    I didn't get as many pictures this past weekend (too many hammers in my hands) so this will be supplemented with some diagrams and previous pictures so we can make a good tech thread.
    Prior to Tom showing the body lead demo, I needed to make some panels for him to work from. We decided that a curved surface, similar to the front end of a 38 Chevy and its hood halves, would be a better fixture for showing the need for flowing lead up a slight incline. I started with two equal sized panels, and bent a flange on the long edge. Then discussed some of the issues faced when shrinking a flange. For demonstration purposes, in the following example we have a 12" long panel with a 1-1/2" wide flange.
    If we were to look at the same panel with a radius, formed by shrinking the flange, we would note dimensions similar to as follows:
    ....where the 90 degree bend at the flange still retains its 12" length, the centerline of the flange in this case is shortened by almost an inch, and the outer edge of the flange shortened by almost another inch.
    In working with the Lancaster/Eastwood style shrinker-stretcher machines, it is important to note that they are a linear device, the movement they introduce into the metal is in a straight line.
    So that once a radius starts to form, and with the shrinking device still moving in a linear fashion, the outer edge of the flange will be put into tension as the centerline shrinks. Anyone who has used these devices will have seen this as the machine starts to lose its effectiveness.
    To counter this effect, we need to shrink the outer edge of the flange more than the inner. By simply alternating the depth of the shrink as shown, you can provide more shrink to the outer edge and the device will become more effective.
    Another method of shrinking is with the use of tucks. Looking at their shape, the tuck has a wider "gather" at the edge of the flange as compared to the inside bend of the flange, so this eliminates some of the tension issues seen in the mechanical shrinker.
    Where the demos this past weekend were supposed to concentrate on using only hand tools so that the participants could readily duplicate the results without the need for a major purchase, we did find the use of the Shrinker a good comparison, and by chance the tuck shrinking did prove to be faster and more effective.
    For the tuck shrinking, one can use tucking forks, rounded jaw pliers (by design or modification) or special designed devices. As an example, here is a set of tucking forks I made out of some s**** metal and 5/8 bolts turned down.
    And a pair made from needle nose pliers..
    Probably the biggest challenge with their use is producing consistent tucks. To produce a flowing, consistent radius, we should start with consistent tucks, both in size and the spacing between them.
    I decided to make a pair of tucking pliers out of Vice Grips, as the jaw adjustment on them would prove to give repeatable sized tucks.
    We'll start off by finding a pair of vise grips suitable for the job, which in this case means the jaw serrations are starting to wear and round off and won't grip much of anything else. Finish what has started by removing the serrations to produce a nice flat jaw on the bottom, and cut the top one off at about 30 degrees from its original position.
    I had some extra long shouldered 3/8 bolts, perfect round stock for the job. Three of them were cut off to 1-1/2" length.
    Here's my economy model lathe made by Dewalt...
    To set the spacing for the "fingers" the first is clamped in the vise grip jaw, centered.
    The outer is placed next to it and then welded down the outside, center finger removed, and then welded down inside. Here we should leave a slight gap of your sheet metal thickness to prevent any binding, which will allow a deeper tuck.
    Repeat for opposite side, then weld center finger.
    Note in the above picture the 30 degree cut of the upper jaw positions the center finger at an angle compared to the bottom fingers. It is this angle that will help to form the tuck's shape.
    Of course I took my favorite anvil along to the meet, here clamped in the vise..
    Again our object in this case is consistency, so equally spaced marks are placed on the flange, identical tucks made at each mark, and you can see the consistent radius along the panel.
    I use a O/A torch to heat the tucks prior to hammering them flat. Others prefer to not use heat, and can capture the tuck and flatten it very effectively without it. I am still working on this proficiency, so in the meantime, I use heat. We're looking for something like this, prior to hammering.
    Here OJ ***ists with torch duties...
    Another point to mention is that the hammering action tends to also spread the tuck back apart if not captured effectively. Where the picture above doesn't show it well, a good means of overcoming this would be to clamp a strap of metal across the ends of the newly formed radius prior to hammering, similar to this:
    Then the hammering force will be more effective in flattening the tuck back into itself.
    Once each piece was completed separately, the flanges were aligned back to back and the two pieces tacked together. Each had an identical radius, for a good fit. Consistency pays off!
    Mtn Goat, JUNK ROD, JOYFLEA and 5 others like this.
  3. rockable
    rockable
    Thanks for that excellent tech lesson, Robert! I'm sure I can put that to use sometime soon.
    Are you aware of any Metal Meets in the southeast? I would love to participate in one and learn more from the "pros"!
    MP&C, loudbang and Bowtie Coupe like this.
  4. alchemy
    alchemy
    Thank you for the tucking lesson. I'll have to make one of those vice-grip forks.
    We can see how OJ lost his hair. o_O
    Bowtie Coupe, lothiandon1940 and MP&C like this.
  5. MP&C
    MP&C
    Not aware of any at the moment, will let you know if I hear of any..
    He was a bit close with the heat, wasn't he! If making that vise grip tool don't forget the taper cut on the top jaw. Gives a nice taper on the tuck for less distortion/marking of the panel.
    Mike is still plugging away on the Drummer's Lounge sign.
    Saturday he started fabrication of the insert panels. One side will be plug welded in place, the other will be removeable to access the wiring for the flashing lights.
    Tracing the first pattern onto some 19 ga crs, and adding mounting flanges.
    The bend lines are run through the bead roller with a tipping die into the skate board wheel to better mark the bend location. Makes it easier to locate the upper press brake die as it will fall into the indent.
    Since everything is a tool, and we needed to fold down a bit of metal in the inside corner, a piece of angle is chosen for it's inside radius match and a body hammer with a nice barrel roll on it does the trick...
    Side #2....
    While he was busy with that, I continued on our speaker mount modification to the doors. Since we had cut away at the hinge mounting structure, we needed to add strength back in that surrounded the speaker. We chose a cone shape over cylindrical as we thought that would have less chance of collapse under stress. Our pattern is cut out and transferred to some 14 gauge cold rolled, the same thickness as the hinge structure.
    I forgot to get pictures of us rolling the cones, but basically as shown here with the pattern, the bend line was kept aligned with the vertex of the outer angle cuts, and slightly pressed, move and repeat, and continued until we have a good roll where the ends met up.
    We plan on wire edge on the edge inside the square opening, so let's use gas welding for a more pliable weld area.
    The cone is then trimmed to fit the structure profile...
    Flange is left for our wire edging of the open area...
    The flange is tipped on the bead roller and then used the linear stretch dies in the Lennox to both stretch and tip the flange over to flat.
    Then we use this modified Craftsman punch to hammer over a rounded void for the 3/16 wire to lay in..
    Then we have some modified vise grips that have a relief cut into the top so it won't slip off the wire when clamped.
    The wires were left long so they could better tie into the hinge structure, here the VEE relief is where the wire will weld to that structure.
    Tacked in place with the MIG, then TIG welded....
    All cleaned up and then primed with some epoxy primer before we weld the speaker mounting ring in place.
    JUNK ROD, brEad, Bowtie Coupe and 2 others like this.
  6. MP&C
    MP&C
    Back on our speaker mounting ring, we welded on some 8-32 hex nuts on the back side....
    Then the ring is TIG welded in the door...
    After welding, the area is scuffed and brush painted using SPI epoxy primer.
    JUNK ROD, brEad, alchemy and 4 others like this.
  7. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Robert. I think you have more time in making special tools for this project than most would want in the whole car!! As always excellent work. Are we thinking paint by 2023??? lol Larry
    Bowtie Coupe, loudbang and rockable like this.
  8. MP&C
    MP&C
    Maybe able to make that one.... :D
  9. belair
    belair
    Vise Grips...is there nothing they can't do. Thanks again for showing us how the gods do it.
  10. MP&C
    MP&C
    I have a bunch of them that have been modified for one purpose or another. If you don’t have the tool, make it!! :D
    brEad, loudbang, Bowtie Coupe and 2 others like this.
  11. MP&C
    MP&C
    P***enger door modifications, inner structure added...
    …..speaker mounting ring welded in place and brush painted using SPI epoxy primer..
    In our attempt to finalize all the needed fabrications before getting deep into paint mode, we had some clearance issues to deal with on the Vintage Air bracket for the AC compressor. The initial mockup showed that the upper mounting tab was too close to the tall valve covers we have on the 383 stroker. A half inch spacer under the intake mounting tab gives us about 1/4" clearance, and shows how much we need to modify the water pump mounting tab.
    I didn't have much in the selection of 1/4" flat stock, so the shoulder of a 5/16 bolt was used, first the root p*** and then a filler p***.
    Another part checked off the list....
    TFoch, JUNK ROD, jakespeed63 and 7 others like this.
  12. loudbang
    As usual everything you do it topnotch. Is there ANYTHING on this car that hasn't been improved or modified LOL? :)
  13. MP&C
    MP&C
    :D
    Time to play catch-up, had a short hiatus in Upstate NY on the St Lawrence river.
    Daytime and sunset:
    I picked up some louver dies that are set up for the press brake but should be the start of a louver press eventually... got both 2" and 3" dies.
    I also have a couple good friends that understand my tool addiction that both sent me a link to an ad for body tools, especially for the Vise Grips. Here's what I picked up from a retired bodyman, now to keep these quality tools going. VG collection is now over 130.. never enough.
    ...and with the engine brackets back from powder coating, and our new 45* water neck arrived, we were able to get the belts and upper hose all mocked up. The hose we used was a Dayco 72384, made as a lower hose for a V6 Ford Explorer, but it fits this application like a glove...
    Video version:
  14. lothiandon1940
    lothiandon1940
    Hope it was cooler in Upstate N.Y. than here, Robert......At least it was some beautiful scenery.........Don.
  15. JOECOOL
    JOECOOL
    Thanks for the tutorial on the tucking tools.
    brEad, loudbang and MP&C like this.
  16. MP&C
    MP&C
    Spent some time organizing, needed some racks for all the Lennox dies..
    One set down, two more to go....
  17. MP&C
    MP&C
    While I was blocking some primer, E added some sound deadening to the inside of the door skins...
    Behind each of the speaker mounts we added a section of Dynaliner…
    She did a good job of that, wait until she sees how much more we have to go!
    brEad, Bowtie Coupe, TFoch and 5 others like this.
  18. kidcampbell71
    kidcampbell71
    Lol. /\ /\ /\ An apt pupil shall never sway. Daughter daddy, times two here ... awesome stuff. Hard to shake DNA. ( ... you may not find crayon marks on YOUR floorplan )
  19. MP&C
    MP&C
    Progress pics from last night... Yep, we've been block sanding..
    Using Evercoat 416 to address the few low spots..
    Honing up on my painting skills with brush on seam sealer
    Today's lesson is on media blasting and stretch damage that occurs. Here’s what a sand blaster will do to a roof skin when blasting the braces underneath.
    Our blaster was doing the brace from underneath/inside and the inadvertent stray media hitting the adjacent roof skin stretched it, pulling it inward toward the media stream . On the outside the “unstretched” area shows as a high spot, the stretched part that needs shrinking is seen as a low. So if you must media blast any braces or internal structure, block off the skin next to it so no media touches it. Save yourself the extra body work.
    We fixed the lows by locating the exact spots on the inside that needed shrinking and tapping outward into a small shot bag. To locate, a rare earth magnet is placed outside on the roof skin in each low spot, and some grinding dust finds the magnet on the inside where we can mark the perimeter both inside and out, and work with one person on either side to remove the lows. (See video, magnet marks highs or lows, it doesn’t care) For multiple lows, mark both sides of all spots and number them, so you can move from one spot to the next, calling out the number desired to your shrinking ***istant. If your car is too clean to have grinding dust, look under your bench grinder.
    Magnet use video:
    Note on the inside roof skin picture the multiple numbered circles where we found low spots to address.
    David Gersic, brEad, JUNK ROD and 8 others like this.
  20. Johnboy34
    Johnboy34
    from Seattle,Wa
  21. MP&C
    MP&C
    So we've been blocking out epoxy primer, it sure is nice to be able to rotate the car where you need it instead of sanding upside down on the bottoms of drip rails.
    But then you walk past the Driver's A pillar and see holes that shouldn't be there.
    I don't know how I've missed this before. We did have this same repair done to the other side, I guess with the roof damage confined to that same side I must have not thought this side was suspect. Goes to show, check ALL problem areas, especially if issues show on one side.
    Inside the hole has a minimal amount of surface rust, especially for 64 years old. Safe to say the damage was caused by water/dirt ac***ulation between the center structure (the one we're remaking) and the outer skin. Oh well, it's been a while since I've had a back up and punt moment. Glad this was found before the green kandy went on.
    Starting to make the new replacement for the inside, using 14 gauge cold rolled steel.
    Quite a bit if stretch added for the part to match the original..
    Rough shaped on the MH19, tuned up a bit with body hammers, punches used as anvils, and various other implements of destruction. Trimmed and fitted:
    All ready for welding. Meanwhile, Mike has been working on the pointy end of the arrow, here stretching an inside corner to better fit the housing....
    And adding holes for the plug welds....
    TFoch, tomkelly88, brEad and 8 others like this.
  22. MP&C
    MP&C
    After a week in FL for the day job, time to get the inner patch welded in place.
    Tacked using the TIG:
    video:
    welds dressed:
    Epoxy primer added:
  23. MP&C
    MP&C
    Now to get our outer patch fabricated.. The corner is going to need a GRUNCH of shrinking.. We started on the Baileigh, but the dies are only going to get us so far. So some tuck shrinking with some heat for persuasion was used..
    A tipping wheel in the bead roller was used to mark our bend line, and an upper press brake die used as an anvil to hammer the flanges over..
    Some hammer action to stretch the corner flange so it will tip the full 90*
    I missed some in process pictures here, but various hammers, anvils, punches, and other implements of destruction were employed to give us our basic shape...
    After a bit of fine tuning, it is trimmed and fitted into the A Pillar...
    and the windshield stainless is test fit for good measure..
    The finished piece is media blasted (Barton Garnet) so the SPI epoxy primer will have a good bite. The inside is primed as a bit more preventative measure over factory....
    The flange is quite small compared to what we normally plug weld, so we opted for a .169 drill bit to keep the heat away from the edge...
    In order to clean he primer out the inside of our plug weld holes, we flattened and backfaced our drill bit to mimic an end mill....
    Does a good job of giving us nice clean metal for a good weld..
    much better....
    Fordor Ron, pmdguy, JUNK ROD and 12 others like this.
  24. MP&C
    MP&C
    Here's some of the forming process of our A-Pillar fabrication that I missed the other day. Did a couple time lapse videos, first shows the shrinking of the corner. The Vise Grip tucking tool, torch, and hammer is used to get the corner to come down about a 20* angle, then the two flanges were folded, which gives us one big tuck. At that point wide VEE is heated up and the high spots of the flange corner is hammered back into itself. Repeat for the next high spot, until the corner is folded where you want it.
    Here's the corner shrink complete...
    Then the barrel end hammer is used to make the joggle creases by using an upper die from our press brake as a post dolly. That’s the basic process.
    Bandit Billy, JUNK ROD, brEad and 8 others like this.
  25. Nostrebor
    Nostrebor
    You are way faster at this stuff than me:eek::D
    Great work. You make it look easy.
  26. brEad
    brEad
    Thanks for sharing the videos. Love seeing how the magic is done.
  27. MP&C
    MP&C
    Today we worked on some rust prevention up inside the roof. This is between the roof skin and the perimeter structure just above the windows.
    The car was rolled on it's side and SPI epoxy poured into the area, acid brush was used to cover everything we could..
    Once the entire p***enger side had been flooded around to the liftgate hinge, we rolled the car right side up again. It wasn't long that we had paint dripping on the top of the rocker panel.. It was running down inside the A Pillar and running out the bottom of the dogleg. This is a good indicator of exactly where the roof condensation runs to when it reaches the A Pillar, and why we had rust issues there.
    Here's a picture of when we opened the roof for rust repair, showing what the condensation did for us..
    So our primer is sealing the joint between the roof skin and the structure.. We found an opening above the windshield that would help us to flood the front seam....
    We opened up an acid brush to form a funnel, and poured SPI Epoxy in the area..
    A puddle out of the A Pillar dogleg shows we have good flow through the windshield...
    To insure everything was covered above the windshield header, we joined two acid brushes for an extended reach over the header, and bent to match the roof skin profile....
  28. lothiandon1940
    lothiandon1940
    Outstanding! It's no wonder so many cars lost their drip rails to rust. Great detailed explanations.
  29. MP&C
    MP&C
    Progress this weekend, We had originally left the factory jute insulation under the roof supports, thinking we could just **** up to it with the new stuff. After installing the Noico inside the doors, I guess my OCD wasn't about to leave the old stuff in the roof. So the bottom edge of the roof supports were scribed on the driver's side for relocation purposes, de-spot welded, and pulled downward enough to s****e off the old jute..
    The bare area is then scuffed with 80 grit and two coats of SPI epoxy primer applied.. After that sets up we applied the Noico sound deadening mat to the inside of the roof skin. Then the roof supports are aligned with our scribed marks and plug welded in place..
    Mike has been plugging along on the Drummers Lounge sign, the arrow is close to done, it still needs fastening hardware added for the access panels, and holes added for the lights..
  30. kidcampbell71
    kidcampbell71
    Nice work, Robert. Still convinced, that you iron your underwear ... but yes, that jute backer, obviously had to go !! Be gone, jute !
    Now you can wet sand, basecoat, clear, cut, buff, and polish underneath those supports, too. :) Like gl***, baby !
