Features 48 Ford with 41 Packard taillights done.
Discussion in 'Traditional Customs' started by hotrodmano, Jun 19, 2019.
  1. hotrodmano
    hotrodmano
    from Norway
    Well.... Not done as in finished, but taillights done...as for now.
    So...heres a couple of shots of the 41 Packard taillights installed about 6-7 inches lower than the originals on my 48 Coupe. Made the car look even wider and lower. I also frenched the headlights and removed the directional lights up front, the split in the fenders and welded shut some holes in the hood. Oh and an aditional 1" lowering in the rear too. Up next is a Cadillac grille...I think.. .
    I must ad that the top was not chopped by me but by the previous owner about 5"/ 7" 57425244_10157298541829571_1890904251652112384_n.jpg 58079782_2260673054194776_6733339286432645120_n.jpg 58376195_391065971488038_1417166034598625280_n.jpg 58383928_988316404700641_924766562601140224_n (2).jpg 58384470_412342656250413_7980823781780226048_n.jpg
  2. footbrake
    footbrake
  3. hfh
    hfh
    from Western MA
    Nice coupe. Great photography too!
  4. 41rodderz
    41rodderz
    from Oregon
  5. 34Larry
    34Larry
  6. I like 'em. I've been thinking of trying to do something different for tail lights on my '47.
  7. Squablow
    Squablow
    I like it! This car looks like a Cadillac grille would be an appropriate choice. If you do change the grilles, would you incorporate some kind of front turn signal/parking light?
    Stogy likes this.
  8. i.rant
    i.rant
  9. Bandit Billy
    Bandit Billy
    Fat bottomed girls, they make the rockin world go round!
  10. You have captured " The Look. "
  11. 47 ford
    47 ford
  12. hotrodmano
    hotrodmano
    from Norway
    If I do I will hide them as much as possible.
    Sent from my SM-G930F using The H.A.M.B. mobile app
    Stogy likes this.
  13. Russco
    Russco
    from Central IL
    That looks fantastic!
  14. sawbuck
    sawbuck
    from 06492 ct
    nice work..nice chop, you are making a 48 ford look good. not an easy task ...
  15. Greg Rogers
    Greg Rogers
  16. lodaddyo
    lodaddyo
    sweet jesus! love your car man. really like the taillights. nice job!
  17. Finnrodder
    Finnrodder
    from Finland
  18. hotrodmano
    hotrodmano
    from Norway
    Thanks all.
    I must ad that the chop was done by the previous owner back in the late 90s in MA. So I wont take any credit for that :) Only added all side windows and swiwel mecanism and some adjustments in doors and sealings there. But...the rear window will be lifted out to get a better flow with the sweet rooflines this car has.
    Stogy likes this.
  19. Stogy
    Stogy
    @hotrodmano...Custom looks fantastic...please continue to share the goodtimes...;)
  20. bschwoeble
    bschwoeble
    Perfect. Good eye.
  21. topher5150
    topher5150
    I was going to ask about turn signals too. It's not exactly traditional but I saw somewhere where they have hedlights for the 46-48 Fords with built in LED turn signals at the bottom of the light.
  22. 19Fordy
    19Fordy
    Your car is beautiful,clean and simple. Done in desirable design taste.
    You don't say what year Caddy grille you plan to use but, first consider
    removing the stock top ornamental chrome piece and keeping just the 3
    stock horizontal bars. You could also consider replacing that top grille iece with another horizontal bar, the same as the other 3. That's clean and simple and would look great.
    Some Caddy grilles can make the front look very front "heavy" and over
    power the flow of the car, like a "blobby" paper weight on wheels.. The stock 3 bars would even look better than the popular 1948 Olds grille. Remember, horizontal lines (like your tail lights) on a car make it look lower and wider.
    Knghtcadi likes this.
  23. Steel A Rod
    Steel A Rod
    Never really liked '48 Fords. Now I have a new found respect for a great looking car!
  24. rusty1
    rusty1
    ..those sure look like 41 Stude tailites...very nice whatever...
  25. Lou kriger
    Lou kriger
    Don’t know if vanity plates are available in Norway, but your 48 is “SOSWEET”
  26. hotrodmano
    hotrodmano
    from Norway
    LED wont happen. :D
  27. hotrodmano
    hotrodmano
    from Norway
    The 41 Studebaker taillights are a bit longer and narrower than the 41 Packard Jr lights, but Stude lights was my other choice.
    AChopped1950ford likes this.
  28. fatfendered
    fatfendered
    Did you place the old pot metal buckets inside the fender... Or did you build new buckets?
    Dog_Patch likes this.
  29. hotrodmano
    hotrodmano
    from Norway
    I bought complete Packard lights included repop buckets with sockets so I cut out a matching hole in the fender and made a simple piece of metal/screw contraption that, from the outside, presses the bucket against the fender on the inside together with another screw straight into the bucket through the fender. A lot of tec7 around the bucket to avoid moist and then the gl*** and beezle was screwed from the outside in stock screwhole. Note that neither the gl*** nor the beezle matches the contours of the Ford fender so I cut it to match the curve. The bucket also needed a cut and a tweak but tec7 adjusted most of that :D I cut my own rubber gaskets between the beezel and fender.
  30. edcodesign
    edcodesign
