Technical Anyone ever hear of a 90 deg inverted flare fitting?
Discussion in 'The Hokey Ass Message Board' started by 1oldtimer, May 18, 2019.
  1. I'm looking through my catalogs and online but I only come up with a brake tee. I'm looking for a 90 deg, double female inverted flare fitting. Something that a hard line will just screw into on both sides. I know I can just bend the line but I went easy this time a bought a line kit (cheap too). If I want to use just a union then I have to shorten the pre bent stuff, which isn't saving me time (which is why I bought the kit in the first place). I also like the idea so the fitting will be touching the frame and not the line so rubbing will be at a minimum.
    Just think of a brake tee without one port........which I can also do is just to use a tee and plug a port, but that looks like ***.
  2. milwscruffy
    milwscruffy
  3. They're all inv to npt, looks like I'll be shortening lines. The Task Force trucks are odd (at least my panel), the brake tee is on the p***enger side frame rail and that feeds the p*** front AND the rear......a single line to the front drivers side.
  4. sdluck
    sdluck
    Napa I think
  5. dalesnyder
    dalesnyder
    Inline tube has 3 listed in their streetrod catalog.
    Part no. El 50, el60 and el 70.
    Is that what your looking for?
  6. My local Napa lets me dig through the bin of fittings.
  7. Thank for looking, but those look to be npt and not inverted flare.
  8. catdad49
    catdad49
    What size are you looking for?
  9. milwscruffy
    milwscruffy
    3502-04-04 | 1/4" Inverted Flare Union 90°
    $11.15 DiscountHydraulicHose.com
  10. iwanaflattie
    iwanaflattie
    Did you find a place for fittings?
    I need a male to female 90 fitting so my coe hood dont rub on the line.
    Anyone have any ideas?
  11. tomic
    tomic
    one of my favorite sites for weird brake fittings: http://www.brakeconnect.com/
    alls orts of problem-solvers here. dunno if they have your 90 degree female elbow.
  12. JeffB2
    JeffB2
    from Phoenix,AZ
    ACE Hardware may have what you need when I did my brake upgrade I found what I needed there.
  13. bschwoeble
    bschwoeble
    tomic. Thanks for the brake fitting web site. There is no need for cobbled together brake lines.
  14. catdad49
    catdad49
    OLSKOOL57 likes this.
