28 Coupe Build
Discussion in 'Traditional Hot Rods' started by 51box, Jan 16, 2016.
  1. Malcolm
    Malcolm
    from Nebraska
    I see you did end up getting a pair of the M&H slicks --- Looks great with them!!
  2. 51box
    51box
    from MA
    Yeah man they worked out great ,thank you for the input on them. I ended up putting them on a set of 15x6” Lincoln wheels with tubes and they bite really good even on that unprepared surface.
    Malcolm likes this.
  3. 51box
    51box
    from MA
    Couple things that I added to the car to be able to race it. A drive shaft loop which I should have done originally on it. 150EEB31-37EE-44C0-B37C-6FD0D13E034C.jpeg
    Also blasted and painted these 15x6” Lincoln wheels and mounted up the 29x7 M&H slicks for some much needed bite.
  4. 51box
    51box
    from MA
    Little update...
    I finally made it to New England dragway last weekend with the car. Made it through tech ok (NHRA) but they wouldn’t let me run my slicks cause I don’t have a blow shield. So I gave it hell on the 7.50-16s and hoped for something decent out of it!
    Ended up having to launch it pretty easy to keep from blowing the tires off but man was it fun to get on the track with this car. She ran great and most importantly nothing broke! Last run was a 13.4 @ 101mph so I’m pretty confident with slicks it would run in the 12’s without too much h***le. AF8336F2-365F-411A-9A2B-11869466DA11.jpeg
  5. 1-SHOT
    1-SHOT
    from Denton
    What is a blow shield?
    JOYFLEA likes this.
  6. Mike Colemire
    Mike Colemire
    ****ter shield.
    JOYFLEA likes this.
  7. 51box
    51box
    from MA
    SFI certified bell housing
  8. 51box
    51box
    from MA
    One last drive to work for the season, it was 26 degrees and that little heater worked pretty good. I bought a sewing machine and have been messing around with it, almost ready to start doing the interior. Will post updates soon, we’ll see how it goes. 169C0116-9B2C-48DC-A31B-51BC4C4A7C53.jpeg
  9. 392
    392
    Great job. Kick *** ride.
  10. 51box
    51box
    from MA
    Thanks @392
    I put a little over 3k miles on it this summer and have a few issues that need to be addressed this winter. The biggest thing is the axle has too much camber at 3 degrees. The feel of the steering is not great because of it. Not sure if I can get it in spec with a press or I need to send it out to be done.
    kidcampbell71 likes this.
  11. 51box
    51box
    from MA
    In keeping with the theme of “I’m pretty sure I can do that myself”, picked up a Sailrite Fabricator sewing machine when they had a great sale going. Watched a bunch of YouTube videos and ordered some supplies to get my feet wet. After some practice pieces I got started, this was the winters project for the coupe. C3558AF4-4EF9-4983-B5A1-71425167613F.jpeg 4F7D872F-3E39-4CC0-B5A3-D60D999636AC.jpeg 3F613280-B5F3-4026-97C3-92035A6F7E59.jpeg 7A8D873E-9A37-44F1-8AEB-A0352163428C.jpeg 2AFD5F0F-C500-43CC-9269-D6E0981D1C7C.jpeg 0679C085-0554-485D-B06B-134042DF50CA.jpeg 200768EE-3974-4962-8DF4-2F273A1F20A7.jpeg D605A5DF-BAF7-4A7F-897C-BB8083AA80F1.jpeg B13ADAF6-C3AC-419B-8E44-51FF4DEC2697.jpeg C4A77DE1-09CE-49C4-8775-A3EFD01354E5.jpeg 981ADE95-E391-4DB7-A1D1-DFDE66053267.jpeg E03B07C8-69E1-4C55-96CF-CA43C58BA8FB.jpeg 6AECFFD4-1AD7-42CA-ACE6-02F261129CE6.jpeg BEFFF23E-4E45-4979-8143-3301675F3548.jpeg 9C1D40E2-87E2-4E68-9485-21006A619E4F.png A08E3F53-2A2C-453C-BA2C-42940CCDC9B3.jpeg 338F78E5-E5DD-476F-900D-0FD4DCF0328E.jpeg 39A593A0-1553-46AD-8748-81503E8446A0.jpeg 0C7CAD5E-CA9A-4206-89D6-E73716CB2268.jpeg E964BAEF-F53E-4F7D-94B2-2BB553F796BB.jpeg
  12. dirt t
    dirt t
    Good job
    loudbang and 51box like this.
  13. nor6304
    nor6304
    from Indiana
    Outstanding build Thank you for the build thread just went through it
  14. waxhead
    waxhead
    from West Oz
    Amazing job. The interior looks great.
    kidcampbell71, loudbang and 51box like this.
  15. Tim
    Tim
    from KCMO
    Outstanding
  16. Duke
    Duke
    That looks really good! How did you make a pattern for the head liner?
  17. Finnrodder
    Finnrodder
    from Finland
  18. vtwhead
    vtwhead
    you must have been a sewer in your previous life! I have paid good money for work that does not look as good as yours....well done, keep at it.
  19. -Brent-
    -Brent-
    SLICK!
    Love your dash, too.
  20. goldmountain
    goldmountain
    kidcampbell71 and loudbang like this.
  21. vtwhead
    vtwhead
    One who sews is generally called a “sewer” (pronounced SOH-er), a word that's been in English writing since the 1300s. The alternative, “sewist,” isn't recognized in dictionaries, though it's quite popular on the Internet and is often used on sewing websites. However my grandmother preferred “seamstress".
  22. Mike Colemire
    Mike Colemire
    Whatever you want to call him, it sure looks really good. Wish I could do half as good.
  23. 51box
    51box
    from MA
    Thanks guys I had a lot of fun upholstering it and learned a tremendous amount with this car. My next project is a roadster and I will do the interior and a chopped top for it when I get to that point.
    I measured in between each bow, and subtracted 1/2” from each panel so I could pull it tight. Left the front, rear and sides long because you pull them tight , staple and then cut the excess off. It’s far from perfect but it looks ok for an amateur attempt.
  24. Duke
    Duke
    Looks good to me. I picked up a machine to do the same when I get there.
    kidcampbell71, 51box and loudbang like this.
  25. YJ4000
    YJ4000
    WOW That looks great!!
  26. manitouguy
    manitouguy
    Incredible - and thanks for posting - inspiring for my ‘28 build ... but daunting too as I sure don’t have those skills
    congrats on building your beautiful car!
    Cheers Ron
  27. sloppy jalopies
    sloppy jalopies
    I ran an AOD behind a 268 flattie with a gennie swan shifter...
    I used the top of a 2 liter soda bottle with the top 2"-3" cut off, screwed it down under the vinyl boot...
    it kept the boot "inflated", it did not sag... and it was real cheap !
  28. 32 hudson
    32 hudson
    Looks great ! Nice work. Looking forward to seeing the car at NED again.
    kidcampbell71 and 51box like this.
  29. 51box
    51box
    from MA
    Thanks guys, yes I would love to drag race it again soon. Put bigger jets in and added a little timing to it over the winter and it doesn’t lean pop on light throttle anymore and pulls strong. My goal is to run in the 12’s on the 7.50-16’s so we’ll see how it goes.
  30. OFT
    OFT
    Fantastic job on your s***ch work, best in getting into the 12's
    Outback and 51box like this.
