Technical Offenhauser 4 deuce on a SBC Questions
Discussion in 'The Hokey Ass Message Board' started by lewk, Jun 24, 2019.
  1. lewk
    lewk
    from Mt
    So I came up with this old Offy 5024 with 4 Holley 94s on it and I've got a couple of questions. I'm building a '35 3 window with a SBC, T10, and a 9". I've been planning on using a 59 283 that will be bored to 292 or 301. I also have a .060 over 327.
    When did these intakes come out? I know they still make them, but this one is old....
    When did they become out of date? I'd ***ume mid 60's?
    Is this too much intake/carb for my 283? Would it run better on my 327?
  2. lewk
    lewk
    from Mt
    Pictures!
  3. Mike VV
    Mike VV
    from SoCal
    So...you did, did you..?
    Why do people start a sentence with the word..."so" ? Your English teacher is probably rolling in her/his grave..!
    Mike
  4. lewk
    lewk
    from Mt
    So, it’s a forum and my tone is meant to be conversational. I’d also bet you money my english teachers don’t give two ****s how I write on car forums. They’re just happy I’m not still sitting in the back trying to crack my friends up and writing essays about VW bugs.
    Thanks for bumping my thread, though.
  5. I have no info about the intake except that it looks great on the 35. SO, what’s with the exhaust manifold?
    Deuces and lewk like this.
  6. AngleDrive
    AngleDrive
    from Florida
    The cfm for a 94 is around 150 to 175. A 301 requires about 475 cfm at 80% efficiency. You can make them work but since they have power valves it takes some patience.
  7. lewk
    lewk
    from Mt
    P***enger side late 60’s truck rams horns flipped to the drivers side get you steering box clearance. I’ll see if I can find a pic with the box in. Piping will be a little complicated.
    Deuces and scotty t like this.
  8. el Scotto
    el Scotto
    from Tracy, CA
    I don’t know when they came out but I’d be interested as well. I’m sure someone here has an old Offy catalog.
    I’ve got an older one that takes four Rochester 2gc carbs. I needed spacers to for the linkage to clear some old thick aluminum valve covers with them.
  9. lewk
    lewk
    from Mt
    Here’s the rams horn/ steering box pic.
    loudbang, swade41, catdad49 and 3 others like this.
  10. lewk
    lewk
    from Mt
    Very nice!
    Deuces likes this.
  11. 54BOMB
    54BOMB
    9071AD08-834C-4279-8CA1-26BA0BAE4A77.jpeg Might be hard to read but here is a review on it
    loudbang, RMR&C, catdad49 and 4 others like this.
  12. Now that’s using your noggin
  13. Jalopy Joker
    Jalopy Joker
    know that this is not exactly what you are dealing with - but, interesting 20190622_095953.jpg 20190622_100012.jpg
  14. lewk
    lewk
    from Mt
    Thanks! That is super helpful. I have ***umed that tuning this thing will be time consuming.
    Thats an interesting read. This intake is going to be tricky!
    That nailhead is a thing of beauty.
    Deuces likes this.
  15. hrm2k
    hrm2k
    I did one of those manifolds several years ago with stromberg carbs. I never got it running correctly. I decided to try it again. This time I used Rochester 2J carbs. I acquired 4 carbs all exactly the same carbs from several 1972 Nova 307 engines....... I had a shop go through the carbs, same jets, same squirters. This whole system ended up in my 65 Corvair back seat...……...here is what it looks like.
    Since the carbs were all the same specs, it has been pretty easy getting it running. The only " take it apart " came when we realized that all the vacuum had been blocked by the base gaskets.
    This video is the first startup. I'm glad I spent all the upfront time on the carbs. My friend Frank handling the carbs and linkage
    Just Gary, swade41, D-Russ and 5 others like this.
  16. swade41
    swade41
    from Buffalo,NY
    Can't beat the looks that's for sure
  17. lewk
    lewk
    from Mt
    I managed to steal some online images of a 1964 Offenhauser catalog. The 5024 goes back at least that far....
    Anyone have an older catalog?
    hrm2k likes this.
  18. NewToMeT
    NewToMeT
    I got one. Father built the car in late 70's. Sitting on a 65 283. 20190406_124343.jpg
    hrm2k and lewk like this.
  19. Old-Soul
    Old-Soul
    Early sixties for sure, they came out not too long after the Weiand 4x2 which was (I believe) 1959?
    lewk likes this.
  20. zeuglodon
    zeuglodon
    Nothing says "Hot Rod" like too many carburetors.
