Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. noboD
    noboD
  2. banjeaux bob
    banjeaux bob
    from alaska
    Yes, it is at the WACO Museum.I guess I should not have been surprised to learn someone here knew what a WACO was or the anything about the museum itself.As for FUNK....there was a gent here who was able to collect a large amount of automotive iron from around Alaska and Yukon Territory. He was also an airplane pilot. So, his collecting wasn't limited to just early automotive "stuff". When the final cleanup was made an NOS Model A Ford engine surfaced that had been modified by FUNK.It now lives in a Model A pickup and runs rather well.These images are from the Experimental Aircraft ***ociation Museum(https://www.eaa.org/eaa-museum) in Oshkosh ,Wisconsin of a Model A engine that has been modified for an aero application. I don't recall if it was FUNK or other....
    Bigcheese327 likes this.
  3. Bigcheese327
    Bigcheese327
    Not to get too far off topic, but the Funk Brothers converted their Ford engines to run inverted. That looks perhaps more like a Pietenpol conversion.
  4. banjeaux bob
    banjeaux bob
    from alaska
    Although Jim posted quite bit on this thread I don't think it was his greatest area of interest.To me one indicator was a question he asked me over the phone once..."what are you trying to accomplish on the cyclecar thready?".
  5. SR100
    SR100
    This showed up in the Images of Vintage Gas Stations thread a while back:
    As far as I can tell it is a 1934 Singer Le Mans Sports Saloon. The registration is from Middle*** in 1934.
    Okie Pete and motoklas like this.
  6. culpspecial
    culpspecial
    I have never seen the front cowl on a Model A engine used in anything that I am familiar with. I have seen some pics of early airplanes with a similar cowl and that looks factory. Of course there have been about as many airplane manufacturers as auto in the US. Auto manufacturers seems like about 2500 different makes. Problem is we are losing all those guys that might have know what some of that stuff was. I am talking with people via Facebook to help them with solving problems these days that my mentors helped me with years ago. Oh, year. I am building an Amilcar knockoff cyclecar with a straight 8 engine. So I am still in the cyclecar thread.<grin>
  7. 64 DODGE 440
    64 DODGE 440
    from so cal
    You need to have a build thread on that Amilcar knockoff. We need more information.
    Ned Ludd likes this.
  8. culpspecial
    culpspecial
    If you have ever followed a Harley down the road and looked at the chain it looks as though the sprockets are off center as the chain is has rhythm to it. A multi cylinder other brand it will usually be smooth. It is the harmonic pulses of the Vtwin engine and I would guess it might be hard straight linked to a gearbox. Would urethane joint help?
  9. culpspecial
    culpspecial
    Be happy to start a blog. I am getting to the end of this one and have another lined up to go. Do I just add to the bottom of the page with a response to build a thread or? I am somewhat saddened that the gag pic I use on my profile has never been identified. It is CSX 2602 Cobra Dayton Coupe! I figured some Cobra guys would flip seeing this! Hahahaha Thank you, Steve
  10. culpspecial
    culpspecial
    Here are a few pics. I have the wiring harness done and getting ready to finish the body. All systems are run. Except for the ones I missed! <grin>
    rod1, rooman, Ned Ludd and 4 others like this.
  11. Stueeee
    Stueeee
    from Kent, UK
    That looks great. Those skinny beaded edge rims should ensure an interesting ride with all those horses up front:)
  12. culpspecial
    culpspecial
    Well, yeah! Makes an interesting ride with less horsepower! Hahahaha Thank you. Oh, and there really are not a lot of horses up front. About 150. It is a 263 but it should have some torque. And it is really smooth!
  13. fredvv44
    fredvv44
    you can build a blog page for free using www.blogger.com
    I just started one for my latest Morgan build. www.52morganfsuper.blogspot.com
    Also see my other blog in my signature line.
    It is very easy to use; you just type text and click to add photos.
    1952B3b23 and morac41 like this.
  14. Rolfzoller
    Rolfzoller
  15. foolthrottle
    foolthrottle
  16. Rolfzoller
    Rolfzoller
  17. fredvv44
    fredvv44
    I wonder where Chapman got the design idea from for the Lotus Elan?
  18. SR100
    SR100
    I'm pretty sure the 1st & 3rd pics are of the first car mentioned at the end of the article. The ch***is & steering boxes are different. Both cars appear to use the same Salmson engine.
    What the Wyss special most reminds me of is a larger, front-engined version of a San Giusto (Italy, 1923):
  19. fredvv44
    fredvv44
  20. SR100
    SR100
    I wonder how the curved windshield worked out in real life:
    motoklas and 1952B3b23 like this.
  21. fredvv44
    fredvv44
    In my Morgan my head is just above the windscreen and I get it right in the face.
    64 DODGE 440 likes this.
  22. banjeaux bob
    banjeaux bob
    from alaska
  23. fredvv44
    fredvv44
    I've always wondered how they adjusted the belt tension on those cars.
  24. banjeaux bob
    banjeaux bob
    from alaska
    gravity?
  25. Ned Ludd
    Ned Ludd
    On perhaps a bit of a tangent, I've been thinking about motorcycle-engined cars again. The perennial problem is, of course, how to rig a reverse gear. Add to that my intuition that the greater weight of a car really wants a wider spread of gear ratios than a typical motorbike gearbox provides. So, what we'd want would be an auxiliary gearbox with a reverse gear of roughly the same ratio as the forward gear, plus an overdrive.
    Provided one could be built light and with low enough internal friction, there is such a thing. It's called a Powerglide.
    As the motorcycle gearbox already incorporates a clutch the PG could be used without a torque converter. I wouldn't be entirely happy subjecting a lightweight motorcycle clutch to everyday use in a heavier vehicle, so there might be something to be said for a torque converter behind the motorcycle gearbox. And that line of thinking prompted me to calculate stall speeds through the motorcycle gear ratios. That gets interesting.
    Taking a representative UJM, with a 5-speed all-indirect gearbox and which produces 48lb.ft @ 7500rpm, the converter will see:
    112lb.ft @ 3210rpm in 1st gear,
    85lb.ft @ 2290rpm in 2nd gear,
    66lb.ft @ 5440rpm in 3rd gear,
    54lb.ft @ 6670rpm in 4th gear, and
    46lb.ft @ 7800rpm in 5th gear​
    For purposes of illustrating what happens next I've ***umed a K=140 converter. That means a stall speed in engine rpm of:
    3450rpm in 1st gear,
    1570rpm in 3rd gear,
    1030rpm in 4th gear, and
    910rpm in 5th gear​
    That might even obviate the need for a TCC.
    But be that as it may. Carry on ...
  26. fredvv44
    fredvv44
    Bike powered race cars are required to have a rev. box so a lot of work has been done in that area. There was one that had a shifting overdrive.
    My experience with my JZR, with Guzzi engine, is that first gear is quite a high ratio and I have to slip the clutch a bit to get it going. Top end is about 95 MPH. The bike would do 110, so there is your weight difference. I haven't been able to get anybody to ride with me at full speed to see what the p***enger weight difference is; LOL.
    My JZR has an electric reverse. There is a tilt plate next to the driveshaft that has a bike starter motor mounted. There is a gear welded to the driveshaft. The plate is tilted by a lever to mesh the starter gear to the driveshaft. It works quite well on level ground and is intended to just get me out of a parking spot.
  27. JackdaRabbit
    JackdaRabbit
    from WNC
    I think the added weight and bulk of a Powerglide would neccesitate a larger than usual cyclecar and therefore a larger than average cycle engine.
  28. DesmoDog
    DesmoDog
    My money says the difference is due to frontal area/drag, not weight... more weight slows acceleration, not top speed.
    When I was considering putting a bike engine into a boat (long story) I was looking into using the reverse mechanism off an outboard's lower end.. Never got far enough into it to really work it out though.
  29. banjeaux bob
    banjeaux bob
    from alaska
    there is a transmission with reverse made for the BMW air cooled twins.It is quite expensive.
  30. banjeaux bob
    banjeaux bob
    from alaska
    67740572_10156400113990770_1044712779996463104_n.jpg Austin Seven special built by Alan Wragg.
