Projects ‘31 av8 coupe build
Discussion in 'Traditional Hot Rods' started by kustomitch, Nov 17, 2018.
  1. That door skin came out really nice. Good to see you making progress!
  2. kustomitch
    kustomitch
    from Monson MA
    Thanks! It’s getting there
  3. You do really nice work. The inner and outer on the door came out great.
  4. wheeldog57
    wheeldog57
    Great looking project, the finish line is in sight!
  5. kustomitch
    kustomitch
    from Monson MA
    Thank you!
  6. kustomitch
    kustomitch
    from Monson MA
    Thanks. Hoping to get it up and running soon. I still need to hunt down a few parts.
    Stogy likes this.
  7. wheeldog57
    wheeldog57
    Watcha looking for?
  8. kustomitch
    kustomitch
    from Monson MA
    Still need a set of 32 pedals and a steering column and box. Then just little stuff.
  9. kustomitch
    kustomitch
    from Monson MA
    So I got the door metal finished to where I’m happy and started making and tacking in the rumble lid patch. Nice to have the garage doors open again! Also got a ‘32 pedal assembly and tons of little odds and ends. Still looking for a steering column and box if anyone has an f1 setup.
    FlatJan, Stogy, adam401 and 7 others like this.
  10. kustomitch
    kustomitch
    from Monson MA
    Pushed it outside for the first time in a while.
    FlatJan, adam401, Jet96 and 11 others like this.
  11. Getting there! Car looks good!
    Stogy likes this.
  12. kustomitch
    kustomitch
    from Monson MA
    Thanks!
    Stogy likes this.
  13. kustomitch
    kustomitch
    from Monson MA
    Couple more parts came in yesterday.
    Stogy and brEad like this.
  14. kustomitch
    kustomitch
    from Monson MA
    I got the rumble lid patch all finished up today.
    FlatJan, kadillackid, brEad and 3 others like this.
  15. Stogy
    Stogy
    :rolleyes:...Someones getting Antsy...:D
    Great Vintage look you have coming together there Kustom...
    and you have one of those Vintage ambient Workshops to boot...
  16. kustomitch
    kustomitch
    from Monson MA
    I’m definitely getting excited! Haha. Thank you, I’m having a lot of fun with this one.
    Stogy likes this.
  17. kustomitch
    kustomitch
    from Monson MA
    So I’ve been finishing up all the welding and getting the doors opening and closing as they should with the handles and mechanisms installed. Tonight I finished cutting out the wood for the floor and started building a seat frame. Leather also came in for the seat. I may be getting a little ahead of myself there but I never get to do any upholstery work for myself so I can’t wait to do it.
  18. kustomitch
    kustomitch
    from Monson MA
    Pulled a nice F1 column, box, and front shock mounts out of a junkyard the other day. Also got the seat frame finished up.
  19. kustomitch
    kustomitch
    from Monson MA
    Working on getting the column fitted before I pull the body back off to finalize everything. It sure is tight. Using a model a flange on the f1 box.
    FlatJan, kadillackid and Stogy like this.
  20. kustomitch
    kustomitch
    from Monson MA
    More progress on the seat. Shaped all the foam today.
    FlatJan, brEad, patmanta and 3 others like this.
  21. Wow, nice workmanship... :rolleyes:
  22. kustomitch
    kustomitch
    from Monson MA
    Thanks!
  23. kustomitch
    kustomitch
    from Monson MA
    More progress. I got the headers tacked up and brought them over to a friends shop to be finished. Then I pulled the body back off to finish the chassis. Got the k legs fitted and bolted the pedal assembly in. Also started making the master cylinder bracket and k leg extensions. Everything seems to be fitting together nicely.
    FlatJan, Stogy, 51box and 6 others like this.
  24. kustomitch
    kustomitch
    from Monson MA
    An I took a break from the chassis work to start sewing up some leather
    FlatJan, Stogy, Old-Soul and 10 others like this.
  25. pumpman
    pumpman
    Dang, really nice work man!
    I see you have a Friendly's sign in front of your shop. Brings back memories of when I was stationed at Westover AFB back in the early 60's. They had great hamburgers and ate there all the time. Are they still around?
    Stogy likes this.
  26. kustomitch
    kustomitch
    from Monson MA
    Thanks man! Friendlys is still around. Not that good anymore though.
    Stogy likes this.
  27. That seat is going to look great!
  28. Never2low
    Never2low
    Metal fab skills? Check
    Sewing skills? Check
    If you can sing you're a triple threat!
    Looks killer man!
    Stogy, LSJUNIPER and kadillackid like this.
  29. oldsman41
    oldsman41
  30. Damn that seat just beckons you to go park your ass on it, looks incredible...great build :rolleyes:
