Hot Rods Wiring and General Advice - Model A with SBC and Generator
Discussion in 'The Hokey Ass Message Board' started by 53OlderThanMe, May 14, 2019.
  1. 53OlderThanMe
    53OlderThanMe
    Almost to the point where I can begin wiring my coupe to start the motor. Using the attached diagram I found as a reference I am realizing I have replaced a wiring harness before but never started from scratch. Couple questions for you wiring experts, will be using a 12V Rebel Wiring Harness:
    Engine - 1967 283 SBC with NOS Generator
    Transmission - 1939 Ford 3 Speed with 1939 Ford Banjo and shortened torque tube
    Questions -
    1. Do I need a voltage regulator with the Generator? I know some alternators have it built in. ***uming yes any recommendations or any 12V will do?
    2. Ignition Ballast? Where can I source that? My distributor is a NOS Roto Faze with NOS Judson coil.
    3. Starter Solenoid - I ***ume any 12V will do?
    4. Was always planning to use the Model A gas tank as its in decent shape. Any disadvantages to using it versus a trunk mount?
    Thanks for any advice or guidance.
    Stogy likes this.
  2. Truck64
    Truck64
    from Ioway
    Yes, an external regulator is required. Look for NOS or good used, modern repros are a ****shoot.
    53OlderThanMe likes this.
  3. Rex_A_Lott
    Rex_A_Lott
    If you're going to the local store and play the Make,Model and year game:
    I like the Chrysler inline resistors for the distributor, 69 Dodge Charger, 318 engine.
    Remote Solenoid, 72 Ford pickup, F100, 360 engine.
    The last external voltage regulator I bought was solid state, not the old adjustable type. I'm not sure when Chevrolet stopped using generators, I had a 64 that was alternator, my 55 is generator. So I would try a 55 Chevy .
    Good Luck
  4. distributorguy
    distributorguy
    from MN
    If your Judson coil is 1.5 Ohm, then you can run the Chrysler ballast resistor at 1.7 Ohms to reduce power input to the + terminal. If its a 3 Ohm coil, no ballast resistor is needed. In essence, no matter what coil and ballast resistor, they need to add up to 3 Ohms to protect your points.
    56-62(?) Chevy voltage regulator. Early 55 was positive ground. Don't know if that matters since you'll need to polarize your generator. Don't forget to do that before you start running everything.
  5. 302GMC
    302GMC
    from Idaho
    Chevrolet starters have the solenoid mounted on top … maybe a diagram for a '55 - '57 Chevrolet would be closer to what you want to follow
    bobss396 and 53OlderThanMe like this.
  6. DannyBrent28Sedan
    DannyBrent28Sedan
    If the alternator has built-in regulator you don't need an external regulator. Just run the single wire from the alternator to the positive connection on the starter
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  7. xracer40
    xracer40
    I don't think your stater switch will work as currently drawn. You need to pickup 12 volts at the point you showing going to ground. This would energize the solenoid and complete the circuit between Bat + and the starter. Where you pickup 12 volts for the starter switch would depend upon if you wanted the the starter switch to work only when the Ign. switch is on or work independent of the Ign. switch.
  8. bobss396
    bobss396
    If you are set on the look of the generator, all the ones I have ever seen had an external regulator. Pretty easy to wire up. I run a Ford solenoid (relay) up on my firewall, an old stock car trick I have used for decades.
