Technical bolting driveshaft to stock '32
Discussion in 'Traditional Hot Rods' started by terry k, Jun 29, 2019.
  1. terry k
    terry k
    from toledo oh
    Bolting up the stock type driveshaft to the trans. No room for sockets or a wrench to tighten the nuts next to the cup..... What is the standard solution to this problem ....Special nuts ?? Spacers? '32 trans 001.JPG
  2. 19Fordy
    19Fordy
    Would unbolting the cross member help?
    Use use a socket head cap screws instead of hex bolts..
    Could you tack weld the nut to the coupler and then insert the bolt from the other side?
  3. alchemy
    alchemy
    Pretty sure Henry used special nuts with a smaller hex. When I did my 32 I didn't have those nuts, so it took a lot of partial turns with a wrench held at a weird angle. Get them as tight as possible then put in the cotter pins.
    Oh, I just realized you have that added crossmember thing in the way down below. Maybe you can grind a socket real thin to slip on the nuts?
  4. RICK R 44
    RICK R 44
    You can tighten them with an open end wrench, but it is a slow process. I am going to try using coupling nuts(used for joining lengths of threaded rod) on my present project. Probably have to go to an industrial supply house to get fine threads
  5. Fogger
    Fogger
    If the cradle between the two add-on legs is removable mark them before taking off and clearance for the two lower nuts. Or tighten the two lower nuts and add the cotter pins before reinstalling the lower cradle. It looks like you have the Industrial Ch***is reinforcing legs which are a great structural improvement to the early ch***is.
  6. 19Fordy
    19Fordy
    I bet you could modify open end wrenches by grinding them
    thereby reducing both the thickness and the outside width .
    You may also have to heat up the wrench and bend it to a configuration
    that allows access. You could also take a smaller size nut and drill and
    tap if for the required thread size. That would give you more working
    room by reducing the wrench size required.
    rwrj and flatford39 like this.
  7. terry k
    terry k
    from toledo oh
    Bolts are fixed to the plate.
    continentaljohn likes this.
  8. LM14
    LM14
    from Iowa
  9. Cliff Ramsdell
    Cliff Ramsdell
    What’s the thread size on those, 3/8-24? I have some various 3/8-24 twelve point nuts that are both 1/2” and 7/16” socket sizes. These are all self locking nuts.
    Let me know and I can send you some hardware to try. I don’t have a ‘32 so I can’t say.
    Cliff Ramsdell
    Johnny Gee likes this.
  10. WiredSpider
    WiredSpider
    You can also use a coupling ,nut they are longer
    Then you can get a socket on them
  11. Ralph Moore
    Ralph Moore
  12. terry k
    terry k
    from toledo oh
    thanks for the help. I'm giving Nacewicz a call tomorrow. I think Ford may have had a special nut.
  13. stillrunners
    stillrunners
    from dallas
    What does the manual show.....?
  14. MAD 034
    MAD 034
    from Washington
    If I remember correctly the studs are fine thread 7/16" and Ford used a 5/8" nut instead of the more standard used 11/16" nut. A chrome thin wall socket will work with the smaller nuts.
  15. alchemy
    alchemy
    Mr. Nacewicz recently p***ed away. Let us know if you can still make purchases from his company.
  16. terry k
    terry k
    from toledo oh
    Looks like they do have a listing for a fastener for the cup. Sorry to hear about his p***ing. When ?? I have purchased for him before. what a collection of correct parts.
  17. continentaljohn
    continentaljohn
    Very sorry to hear about Roy a pic image.jpg From the 1932 ford book by David
  18. FlatJan
    FlatJan
    could you use allen nuts?i used them on a tight fit with my steering arm.
    sorry to hear about Roy, bought a lot of stuff from him.
  19. alchemy
    alchemy
    http://fordscript.com/ Looks like they are still closed.
    I'd think about taking a smaller nut and boring/tapping it out to 7/16" in a lathe. You've got to have a friend with a lathe, dontcha? Probably take about a half hour tops. Next time I need some I'm doing this.
  20. seabeecmc
    seabeecmc
  21. alchemy
    alchemy
    Still need slots for the cotter pins.
  22. seabeecmc
    seabeecmc
