Technical Looking for high beam and turn signal indicators
Discussion in 'The Hokey Ass Message Board' started by txcr13, Jul 1, 2019.
  1. txcr13
    txcr13
    Built a 5 gauge panel for center of dash. Looking for small indicator lights to add to the panel for high beam and turn indication. Want something that doesn't light up the car or that is too bright when high beams are on. Can only use something that fits 1/4" or 5/16" hole in the panel.
    What lights have you gents used and where did you get them?
    Thanks for the help.
  2. squirrel
    I used some of these
    L71526-ND
    from DigiKey, they are incandescent, which is getting hard to find these days. Problem is they are for a 1/2" hole, which is pretty common for incandescent indicator lights.
    If you want to use some modern LED ****, you can just buy some LEDs and panel bushings and perhaps several different value current limiting resistors, and see how you like it. More resistance, less current, and not so bright. The problem is they will need to be bright in the day to see them, and dim at night to not blind you.
  3. Fry
    Fry
    from SK, Canada
    Tim, BradinNC, Just Gary and 4 others like this.
  4. HOTRODPRIMER
    HOTRODPRIMER
    This is where I got mine, I used red for high beam and green for turn signals, they bot were a little too bright so I lightly sprayed some black on the inside and toned it way down, a dimmer bulb would have worked but I didn't take the time to find them. HRP
    https://www.amprepairparts.com/jewels.htm
    302GMC and Shadow Creek like this.
  5. squirrel
    unfortunately, look is all you can do....
    "This item is temporarily unavailable"
  6. Russ B
    Russ B
    For my high beam and idiot light, these are smooth faced, but almost out of sight.
    For turn signals, these are amber rhinestone faceted style and fit older style cars nicely.
    Search eBay motors, vintage parts, interior lights. A lot of things will pop up and you can refine the search for size and type. Rhinestone style fits nicely in many traditional situations. There are a lot of choices.
    txcr13 likes this.
  7. I'm that old geezer that continues down the road for another 5 miles with the turn signal flashing. :confused:
    I prefer something like airport landing lights to remind me to switch 'em off. :cool:
    325w, RDR, firstinsteele and 5 others like this.
  8. '34 Terraplane
    '34 Terraplane
    from Western PA
  9. theHIGHLANDER
    theHIGHLANDER
    I hated everything I found. Too big, too small, too common, too ugly, too modern, too cliche'. I did this;
    Came from a postwar Mopar, 46-7 Dodge I think. The light sockets are little big in the back so I couln't put it between the gauges like I wanted.
    6inarow, treb11, robracer1 and 7 others like this.
  10. txcr13
    txcr13
  11. txcr13
    txcr13
  12. squirrel
    the hole for those is relatively huge
  13. rjones35
    rjones35
    I got some little tiny ones at radio shack years ago. Worked for me.
  14. TrailerTrashToo
    TrailerTrashToo
    We need an "I resemble that remark" ****on
    Black_Sheep likes this.
  15. GordonC
    GordonC
    These are some bullet lights that I added in for turn indicators and high beam. I wanted blue for the high beam but broke the light installing it and all I had on hand was the red one. It will still work though. I wanted them bright enough so that the turn indicators could be seen in the daylight as well as at night seeing as they are not self cancelling.
    txcr13 likes this.
  16. 52HardTop
    52HardTop
    txcr13 likes this.
  17. Atwater Mike
    Atwater Mike
    ^^^^ Very similar to these, (plastic push-in) BUT! Have a chrome bezel around the top, that slides on over the back body/socket, and comes up to the lens. Push it in from the front. Radio Shack and Quement electronics. 12 volt, bright enough... Red, blue, green, amber. $7.00 each.
    txcr13 likes this.
  18. rusty rocket
    rusty rocket
    I found the high beam indicator from a 46 ford pick up. Nice and small and it looks like it should be there. Forty ford cars used the same thing.
  19. My daily driver late model has a chime that sounds after a short time if you leave the signal on. Not sure how you wire that up but it might work for your “problem”!
  20. Old busses and commercial vehicles sometimes have nice indicator lights
  21. I have the same problem, so I have installed small 12volt buzzers, with a couple of diodes, which sounds at the same time as the indicator. It was a little loud, so I wound some tape over it to shut it up, and mounted it up under the dash.
  22. robracer1
    robracer1
    I have blinker indicators but chose not to install a high beam indicator, at night I just turn the headlights on and push in the dimmer switch on and off to set my head lights.
    In other words with low beans on I can see ****, with the high beam on I can see what I'm going to hit.
  23. Blue One
    Blue One
    from Alberta
    txcr13 likes this.
  24. Canuck
    Canuck
    Nice vintage look with a jewelled lens and available in various colours. Used on vintage English motorcycles and cars. Bulb is totally enclosed so doesn't throw light behind dash. Works good day or night.
    Available from parts suppliers for vintage motorcycles.
    My Model A dash - - [​IMG]
  25. LM14
    LM14
    from Iowa
    txcr13 likes this.
  26. bjinx
    bjinx
    Radio shack has small LED 12V lights that are 1/4" Dia. They only come in green or red though. Believe they are less than $3.00. Used them on my gauge panel for turn and bright light indicators.
    txcr13 and kidcampbell71 like this.
  27. Gman0046
    Gman0046
    watsons-streetworks.com should have what you need.
    Gary
    txcr13 likes this.
  28. KJSR
    KJSR
    from Utah
    That's awesome. Looks killer
