Technical *** July 2019 Banger Meet - Time 4 Driving ***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jun 30, 2019.
  1. JT1930
    JT1930
    I’m going to check on the shaft today since I put a different flywheel in the car that has been lightened and fitted with a v8 clutch. I can’t see it being the battery. It’s brand new and charges up.
    winduptoy likes this.
  2. nutrocker
    nutrocker
    I finally got mine running. Sounded great till a big end shell picked. Stripped it down and found a tang position problem with the bearings allowing the bearing to run up the radius on the journal.
    Thinking that was the problem, the motor was fully stripped, cleaned and re***embled. Fitted and run up only to pick up the same big end.
    Got the motor apart again and looking for the cause.
    B3B4C64A-CB76-47F7-85D8-5316DBEAF963.jpeg 7ED56AC1-95AE-4064-9791-81116473E1BD.jpeg FE0115B6-D7D4-4048-80CE-75548C5DD9AD.jpeg 838239E8-F3AE-4FCD-B40F-74B55F4261C6.jpeg 8B9E1DC8-8365-43F3-896E-36736057F221.jpeg 59FCA092-E431-44B9-BADC-F624621FD6AD.jpeg D7C3A2C1-D100-4693-8EAB-4C897A6A5E99.jpeg B59CD78A-1F6C-4389-9D9F-5BA88315796C.jpeg 480D5769-E9F0-49B3-A5B0-EC2B77938EDC.jpeg F7A410B2-F9B6-4D1B-8FF1-14E7AD6F1093.jpeg 83E4BE9E-F36D-428C-AC1A-731425214993.jpeg CDF43E23-7215-4084-A8E4-A456AC6DA31C.jpeg 6D262A2A-18C1-438F-B1B5-1BF59BE8C4CE.jpeg 6CF4CAAE-753D-43A2-B1DD-44C410B5622C.jpeg DF5B3CAB-0440-46FE-985D-BB3F36B32DD3.jpeg 7EFBC2B7-86FD-4000-A7A2-B3FA49660FA2.jpeg E445A71D-6E75-41A2-9A8D-7A66E54F03A8.jpeg 156AC9E2-EFBD-4627-8F35-1CA0926354F5.jpeg 754B2573-E620-4D3A-9D3F-E87816BB7CB9.jpeg 8F670879-F5AC-446D-AEF6-C88CB1111F85.jpeg CC8F7EA8-28C3-46A7-85F2-AD02F3544B6F.jpeg 6D31D43E-01AE-4D96-95A7-93CD25EF55D2.jpeg
    NorthManCad, burl, tomkelly88 and 8 others like this.
  3. 97
    97
    I have seen plenty of NEW batteries which were faulty. Especially the damned sealed ones. You need to load test the battery. A battery can take a charge , but if it has and warped or otherwise damaged plates it may not p*** a load test. A battery shop should be able to do this for you, (Pep Boys , Autozone etc could probably do the test , although they may NOT know what is acceptable for a 6 volt battery. I think you can buy a load tester for under $50 in the USA...a lot more here in NZ!
    Otherwise the in car test is not only the voltage drop on starting/cranking but also the amperage draw. You need an inductive ammeter to test this.
  4. Garagekulture13
    Garagekulture13
    I'm worried about a basic electronic ignition and a downdraft carburetor. Then I see Nutrocker post. It's like a glimpse into a mad scientist's lab. Incredible! Any videos of that setup running?
    Sent from my SM-N950U using Tapatalk
    Dannerr likes this.
  5. Still dancing the hokey cokey with that engine Pete?
    Shutter Speed and Dannerr like this.
  6. nutrocker
    nutrocker
    Yeah, sort of. I keep going back to it and trying something different but still don’t seem to be getting enough oil at the big ends. Plenty of oil through the crank, but as soon as I fit the bearings the flow seems to dry up. Checked all the clearances and they’re all fine.
    I’ll get there.
  7. JT1930
    JT1930
    Starting got better. The only thing I hadn’t checked was the starter switch because I was not familiar with them and what was inside. I opened it up and saw that where it contacts the ****on of the starter it self was grey colored. Sanded it all down to shinny copper and the switch copper plate also. Starts up way faster.
    Jet96, Dannerr, barrnone50 and 2 others like this.
  8. JT1930
    JT1930
    @nutrocker that is absolutely insane. And I love it ! Haha
    barrnone50 and nutrocker like this.
  9. It sounds like you are starving the rods for oil? The pics of the crank don't show the cross drilled holes, but I have to believe they are there. Matching up the shells with grooves to the feed holes will help. As a rule of thumb, the oil p***age to feed a single main and rod is min 1/4", to feed two rods 5/16". How much pressure are you pushing?
    J
    Old Dawg likes this.
  10. nutrocker
    nutrocker
    Yes, crank is cross drilled. I have good feed to all mains and big ends, until I bolt big end caps on then it dries up. The mains are set at .0025” and big ends at .0015” clearance. The oil feed holes to all the mains is no smaller than 5/16” until it gets to the groove in the mains. The drilling in the crank is 3/16”.
    I can run any pressure I want from 20psi to over 200psi. It’s a race dry sump pump and I’d set the idle speed to 40psi and a max of 60psi. It had a very high flow if needed too.
    At the moment I’m working on modifying the big end shells by adding a groove and/or a X to allow better oil transfer from the oil feed hole in the journal around the bearing. Currently there’s nothing in the bearings.
    Pete.
    Dannerr likes this.
  11. Pete,
    OK, that makes sense, the rod journals are long in length and that will be an issue.
    making a small groove in the bearing where the oil feed hole is will cure the issue. (360 degrees around)
    I don't run that style rod/bearing combination, using Chev V8 style, 2.0 dia and .860 long.
    John
    nutrocker, Old Dawg and Dannerr like this.
  12. nutrocker
    nutrocker
    Thank you John.
    I’m on it.
  13. railcarmover
    railcarmover
    Spied this my little eye when I was buying the winfield head..half buried in a box of junk,looks like it spent a few years in a mud puddle. Got it at the 'new bro' price after ponying up for the head. The two bolt adapters are cast iron aftermarket ones (edit,homemade but nice work) I can port some to fit a pair of webers I got..tried running them with individual manifolds but no bueno..need a plenum.. thumbnail (38).jpg
    Dannerr, Jet96, barrnone50 and 2 others like this.
  14. Jet96
    Jet96
    from WY
    Checking in-hope you guys all had a good 4th! I've managed to drive my roadster 30 out of the last 36 days, logged a little over 700 miles. Only got drowned once! A couple very pleasant 100+mile Sunday morning trips up near Yellowstone and surrounding areas. I live at 5500' and everything goes up from here. 43/42 mains/ 71 PV's. A little rich still, but livable especially with the 8:1 head. One thing with the dual carbs-97's or 94's- good mileage! low-mid 20mpg. Rethinking my rear shock/suspension setup. Tspring with 2 leafs removed (they were cracked anyway) it rides really nice but if I hit a frost heave or something it compresses, then Springs! up, totally overpowering the shocks. Not cool in a corner. I've got a good pair of 36's I'll try. They're way stiffer. I'll report back.
  15. Jet96
    Jet96
    from WY
    Nutrocker -that's a very cool build, I'll be happy when you get it sorted...
    nutrocker likes this.
  16. joe1932
    joe1932
    from NY
    Jet96 Add some pics of your car or road trips. Thanks Joe
  17. Jet96
    Jet96
    from WY
  18. Jet96
    Jet96
    from WY
    Rainy morning pic-makes it look waaay better than real-life E1755A00-9F6C-4BE0-AB2A-E26581A1B80E.jpeg
    slv63, Bigcheese327, Dannerr and 9 others like this.
  19. burl
    burl
    from Minnesota
    checking in for the month its already july.Got this beater fired up and holding water.Just need to finish rear brakes and get my windshield gl*** in to take it for a spin. 4th.jpg
    Dannerr, barrnone50, JT1930 and 6 others like this.
  20. What a beauty Roadsta! You're touring sans headlights?
  21. Jet96
    Jet96
    from WY
    Shutter Speed- my old mounts shook too much and were too low for my liking so I got an original bar to mod. To tell the truth I kind of forgot about it heh...I head in to work at 6, so sun's up! I better get that done.
    Shutter Speed likes this.
  22. More power to ya Jet! My local Constable woulda snagged me 1st spin thru the village.
    Been lucky with other stuff, like fenders, so far.
    Please post a pic when you get set up.
    Jet96 likes this.
  23. hotrodA
    hotrodA
    @nutrocker
    That is one insane (in a good way) banger!!!!
    Did you machine those pushrod guides filling the old valve seats?
    Did you cut out the old seats or taper the plugs?
    Are the flush with deck or +/-?
    I need to do that to fit up my Alexander head.
    Thanks!
  24. 40 Olds
    40 Olds
    Hi hotrodA
    You can get those from Secrets of Speed
    Valve Plugs (sold each)
    $16.95 IN STOCK
    Fit Model A & B Ford with "F" head OHV conversions.
    Special CNC'd aluminum Plugs fit into the (unused) intake valve seat on OHV "F" head conversions.
    They are non-mechanical.
    Used to support the head gasket and channel OHV oil return to the crankcase.
    The large OD is sized for a press fit into a hole machined in for a hardened ring seat. The large OD can be turned down to fit a stock valve seat.
    Best to install first and then deck the block. Plug should be flush with or a hair below the deck surface.
    The small OD is pre-sized to press into the empty valve guide hole.
    This part is included with all our OHV kits.
    secretsofspeed.com
    Dannerr and Jet96 like this.
  25. 40 Olds
    40 Olds
    Thanks nutrocker for sharing that beautiful work! Quite a sight to see!
  26. Bigcheese327
    Bigcheese327
    Sounds like the Bennington PD, you'd think they'd have better things to do.
    Any chance you're bringing your truck down to the Hemmings Cruise Night on Friday? I'd love to check it out in person.
  27. hotrodA
    hotrodA
    @40 Olds
    Thanks!
    I recall seeing those years ago in Charlie's catalogue. Thanks for jogging my memory.
    Wonder what else I've forgotten? :confused:
  28. Ha! From what you say about BPD, I better lie low! Seriously, I'd really like to catch one of Hemming's Cruises, but you're a little outa my range in my 45mph back road Jalopy... hafta make a 3-day weekend trip!
    Bigcheese327 likes this.
  29. Bigcheese327
    Bigcheese327
    Well, our cruises are normally on Thursdays, so this is your chance! ;) Or, there's always next year's National Collector Car Appreciation Day.
  30. @Bigcheese327 ...thanks for the invite. You're now on my bucket list!
