good deal ? chev 6 stuff
Discussion in 'The Hokey Ass Message Board' started by johndanger, Jun 14, 2006.
  1. johndanger
    johndanger
    54 235 6cyl hyd lifter eng and 54 glide rear end 350-400 bucks
    came out of running car , and I need it for my 52 chev , motor will be rebuilt , but will try to run rearend as is , seems like a good deal to me .
    can I just bolt my late head on the early block , and what is the ratio on the 54 glide rearend ( tall I hope )
  2. 53sled
    53sled
    from KCMO
    You'll have to put a front engine mount on it, and the glide rear has numerically lower gear.
    PG's came with 3.55 ratio, sticks were 4.10 iirc
    sounds like a deal
  3. Hellfish
    Hellfish
    54 Powerglide rears had 3.55, but the manual trans had 3.73. Pre 53 the manual trans cars had 4.11
    you can bolt a 848 head on.
    $200 is reasonable for the motor
  4. 302GMC
    302GMC
    from Idaho
    '52 & '54 mounts are the same, '58 up cylinder head will bolt on the '54 block.
  5. HEATHEN
    HEATHEN
    from SIDNEY, NY
    These days, it's worth the money. '54 is the last year with the early water pump, and is a no h***le bolt in for your '52. It's getting hard to buy "out of a running car" parts for these old toads. At least you know they work.
  6. johndanger
    johndanger
    my car has homemade side mounts on stock towers and a 61 engine in it now , and its knocking , so I will put the late head on a rebuilt short block using the 54 block , I can then use my original 52 sidemounts , and get rid of the ghetto fab stuff thats there now , right?
    and the rear end torque tube is from a glide and will be behind my 3spd , but the transmissions are the same length right? will be happy with 355s
    and thanks for the input.
    John
  7. 53sled
    53sled
    from KCMO
    yes, the rears are a bolt in, you should be good to go.
