Customs My version of a speedster using Deere parts.
Discussion in 'The Hokey Ass Message Board' started by Deere boy, Jul 8, 2019.
  1. Deere boy
    Deere boy
    speedo.jpg So I built this. Deere radiator, two cylinder vertical flathead engine, pedals, steering, seats and more. T frame with model A axles.
  2. Moon50F3
    Moon50F3
    That’s a one of a kind ride there. Do you drive it anywhere?
  3. Deere boy
    Deere boy
    Got it done for a show in June, but still working through some clutch and brake issues that make it a little scary to drive in traffic. I bought an aftermarket clutch disc, which I found out was a little too thick and I had to go in and put washers between the flywheel and pressure plate. The linkage to the brakes needs some better engineering also.
  4. DERPR30
    DERPR30
    from HARVEY LA
  5. Hdonlybob
    Hdonlybob
    Very Impressive...especially with the two cylinder.. Love it.
    AmishMike and chryslerfan55 like this.
  6. I was a bit nervous before I opened this thread, but that's pretty cool!
    scotty t and chryslerfan55 like this.
  7. Deere boy
    Deere boy
    Quick yet blurry video of the engine running. It's only rated at 15 horsepower, which isn't that far off a model T. It has a heavy flywheel and will spin the rear tires.
  8. Tim
    Tim
    from KCMO
    Pretty cool!
  9. iwanaflattie
    iwanaflattie
    John deere?
    Low BUCk rod!
    nochop, VANDENPLAS and chryslerfan55 like this.
  10. gnichols
    gnichols
    from Tampa, FL
    Doesn't look like will have any cooling problems! NICE and green, too! Gary
  11. Deere boy
    Deere boy
    No, the original radiator for that engine is about 12x16.
  12. oldiron 440
    oldiron 440
    So does it come with the slow moving triangle on the back?
  13. mr57
    mr57
    Deere actually built cars - the Velie - but this doesn't have the 'cool' factor yours does. Great car!
  14. 2935ford
    2935ford
  15. Deere boy
    Deere boy
    It's actually scary fast. Not so much top speed, but it is geared too high for close quarters. No way you could drive it on a trailer. If I had to do it all over again I'd have used a four speed ****** with a creeper low.
  16. Deere boy
    Deere boy
    The Velie and Deere and Clark were actually side projects by some members of the Deere family. Never an actual Deere and Company product.
    tractorguy and chryslerfan55 like this.
  17. hedg12
    hedg12
    That's pretty cool. What's the engine out of?
  18. Deere boy
    Deere boy
    It's out of a model 12A Deere pull type combine from the 1940s. It's actually the same engine used in a model "LA" tractor. As some of you probably know Deere used two cylinder horizontal engines in anything over about 20 horsepower, so I didn't have a lot of engine choices.
    winduptoy, Old wolf and chryslerfan55 like this.
  19. hedg12
    hedg12
    I always thought it'd be neat to build something around a pony motor for a 720, but they're pretty heavy - and hard to come by.
  20. 51504bat
    51504bat
    "Nothing runs like a Deere"
    barrnone50 and chryslerfan55 like this.
  21. Jalopy Joker
    Jalopy Joker
    ya done good - so, what farming implements attach to it?
    scotty t and kidcampbell71 like this.
  22. Poppinjohnnies
    Poppinjohnnies
    Very cool!
  23. v8flat44
    v8flat44
    Well, i for one am GREEN with envy!! That is awesome !
  24. goldmountain
    goldmountain
    Someone will probably tell you they had one just like that back in the day.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  25. Deere boy
    Deere boy
    They aren't hard to find if you know where to look. The problem is they are designed to run 5500 RPM for a minute or two. Not sure how they would hold up with prolonged running.
    winduptoy likes this.
  26. I happen to have two of those flathead 2 cyl engines in my hoard. And mine have small radiators with br*** tanks. Your radiator looks like one from a unstyled B?
  27. the pair
    I own came off of the old pull type combines. they are made to run countinuiosly.
  28. Deere boy
    Deere boy
    GP
  29. Deere boy
    Deere boy
    Probably the same engines this speedster has.
  30. I took them off some s**** combines and bought them from the s**** man. just hated to see them recycled. pulled the heads and got then turning over. never heard them run. I also got a small 4 cyl overhead valve deere engine at the same place. It wasn't stuck.
