Hot Rods Driving at night - update 3/27/2020
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jun 11, 2019.
  1. GM Mirror, Ck, Chevys' of the 40's they sell them
    Deuces and HOTRODPRIMER like this.
  2. 3banjos
    3banjos
    from NZ
    Well I hope you find something that will comfort the curse. Nothing ****** worse.
    I planted the lights on the coupe real low, only because it looked good, but ****, try driving into on coming headlights, and all you can do is cringe hoping they don't realise your on full beam.
    Mentioned prior, dash lights in general. The little directional indicator lights on the dash, I've got a couple of pieces of tape I slap over them just for night driving.
  3. spanners
    spanners
    Just do what most other drivers do and drive with your eyes closed.
  4. Chebby belair
    Chebby belair
    from Australia
  5. patterg2003
    patterg2003
    I hate the super white white headlights in the new GM trucks and some transports. The GM full size truck lights all seem to be at eye level unless I am in my truck. I think there needs to be a study on the whiteness of the new headlights. It is almost on the welding spectrum of white IMHO and it hurts. I was taught in my driver education cl***es to look towards the right shoulder instead of straight ahead if someone does not lower their lights. That helps somewhat but it takes a bit to recover after the intense white lights p***. I used to adjust my mirrors so that I had to change position to check the mirror so I did not get a directed glare. Now I have the auto mirror but I still adjust my door mirrors slightly.
  6. nunattax
    nunattax
    I used a 2003 VW golf mirror.non reflective black rear view mirror.quality item.cheap and plentiful what more could you want .e5
  7. 03GMCSonoma
    03GMCSonoma
    hee kadoit
  8. chrisp
    chrisp
    I have a cool early 50's Panhard Dyna Junior rear view mirror that the gl*** flips over, it's actually a 2 sided mirror with one side being dark for night driving.
    chryslerfan55 and Deuces like this.
  9. Deuces
    Deuces
    Great for fog lamps also.... And they look cool... :cool:
    chryslerfan55 and lothiandon1940 like this.
  10. seadog
    seadog
    @HOTRODPRIMER Danny, After suffering from being blinded by other drivers at night I think I've finally found a CHEAP solution. I spent less than a hour today with some bronze tinted acrylic, a couple of Earl's line clamps, a s**** of mahogany that was left over from boating days and two screws, and came up with a glare shield that easily slips over the top of the mirror in the roadster. The pitures show it better than I can explain it, but it works pretty good. Night Mirror-2.jpg Night Mirror-3.jpg
    Stogy, v8flat44, 47ragtop and 3 others like this.
  11. Model A Vette
    Model A Vette
    There are some stock early 30s Ford mirrors.that clamp the gl*** on the top and bottom. Maybe a late model mirror that dims by tilting the gl*** could be dis***embled to remove the gl***. If you started with gl*** bigger than what you need it could be cut down to the proper size and clamped into the early bracket.
    You would just have to tilt the mirror to get it to act like a late model mirror and still have a rear view.
  12. Sourwood
    Sourwood
    from Atlanta Ga
    I've got a set of really bright back up lights on the back of my F100, they are bright enough that most of the **** heads will back off when I flip the switch.......................not much
  13. lonejacklarry
    lonejacklarry
    That's going to stick with me for awhile.
  14. Deuces
    Deuces
    I love that flag!!!!!.....:)>>>>> 230716 (1).jpg
    Gman0046 and chryslerfan55 like this.
  15. GTS225
    GTS225
    I feel compelled to ask; Just how do you know what that looks like?
    Roger
    Deuces likes this.
  16. Kustomkid
    Kustomkid
    from Montana
    The new lights are bright, but not as bright as original 32 headlights with halogen bulbs. My low beams are so bright I get flashed and or they leave there high beams on every night I drive the pickup. They shut them down really quick when I hit the high beams.
    Deuces likes this.
  17. 6sally6
    6sally6
    You are NOT alone my friend.
    Those idiots with their super brights and the front of their truck jacked up a foot absolutely blind the **** outta me(and everybody else) They are far too stupid to realize it though!
    6sally6
    chryslerfan55, Deuces and dana barlow like this.
  18. 6sally6
    6sally6
    Suggestion (but I never tried it)...........You know those million candle power portable lights that deer hunters use to "shine-up" deer? The ones that plug into a cigarette lighter plug?...You know the ones I'm talking about???
    Wonder if it would get some of those brain-dead idiots attention if......................?;)
    6sally6
  19. Deuces
    Deuces
    :D
  20. Blue One and Deuces like this.
  21. BamaMav
    BamaMav
    from Berry, AL
    I had a semi truck once that had one of those teardrop spotlights on the A pillar. One night I had a car behind me that wouldn’t dim their lights, were right in my mirrors. I reached up, turned it to shine toward the car, and turned it on. Took all of 5 seconds for him to hit his blue lights! We had a serious discussion on the side of the road, could have cost me $150 but got off with a warning.....
  22. HOTRODPRIMER
    HOTRODPRIMER
    Bringing back a old thread instead of starting a new one, to recap I did eventually find something for the wagon but still needed something for my old beater, while in the garage and digging through the roll around tool chest I found a old clip on dark visor that that has been there for years, I took it out in the drive way and tried it on the mirror on my old beater, I had to modify the clip to tighten the lens to attach to the original Deuce mirror.
    It's larger than the the original mirror and I can live with that, the only problem is with all the years it has been laying in the bottom of the junk drawer there is a wide scratch right through the middle of the lens.
    The lens is plastic so I figure most of the scratch will polish out, my question, what material do you guys suggest for something small & simple? HRP
  23. LAROKE
    LAROKE
    White toothpaste? Something you might already have on hand.
  24. nochop
    nochop
    from norcal
    Be my luck the thing would blow off and Konk me one, oh wait, I drive a coupe
  25. bobss396
    bobss396
    I have a couple of used mirrors saved in my eBay watch list, the trick is to get them to attach to my mount. Day/night ones go for around $15-30 used.
  26. Chili Phil
    Chili Phil
    Your mirrors should be adjusted to where you need to move your head a little bit to use them. Gee gaws and gimcracks are for low rider bombs. It's form follows function in hot rods.
  27. v8flat44
    v8flat44
    Primer, wait till yer over 70....i don't go at night unless i just gotta hear that flathhead rumble.
    Put my shades on n go......still crazy after all thesse years....hmmm, sounds like a song.
  28. HOTRODPRIMER
    HOTRODPRIMER
    Phil, you know how the lights reflect off the front and rear gl*** & the bright blue laser beams on all the new cars is so bright in the car Brenda can read a book, I've been driving cars with flat gl*** since I was 16 years old, the lights are just too bright for me.
    I'll be 70 in a few weeks and I had cataract surgery last year, you think the lights are bright, they seem twice as bright now that I can see without gl***es. HRP
  29. rusty valley
    rusty valley
    those new lights really are terrible. sealed beams came out in 1940, used until about, what -1990, and later on some makes, so in effect we were all equal. not so any more
  30. Chili Phil
    Chili Phil
    Yeah, Danny, you can't do much about the flat gl***. When I bought my roadster the PO had tinted gl*** in the windshield. That had to go, right away.
