Projects Resurrecting the Mehoopany Coupe - 1936 Ford 5W
Discussion in 'Traditional Hot Rods' started by 50DropTop, Dec 3, 2017.
  1. SMOKINFLATHEAD
    SMOKINFLATHEAD
    from SOCAL
    Who did you buy the wood from? Wondering if they have the floor reinforcement pieces also?
    Thanks,
    Oh, by the way ALL of these pictures are helpful!
  2. 50DropTop
    50DropTop
    I bought the roof ribs from cl***ic wood products located in Greensboro, NC. I was fortunate and didn’t need the floor supports. I would think if they had a pattern, they could make them. Below is their website. They’ve been very helpful in the past with questions.
    http://www.cl***icwoodproductsllc.com/
  3. 50DropTop
    50DropTop
    Decided to rework the door. I think I’m happier with these results.
    Also did a little paint blending on the cowl vent I welded in. I think it’s going to work....barely noticeable where the paint blend is.
    Plan is to spray the roof during the long 4th of July weekend. I’ll also finish buffing the cowl and firewall so I can set the body back on the frame.
  4. 50DropTop
    50DropTop
    Here’s a close up of the blend. Does anyone know if a light coat of lacquer thinner will help it blend? My blend on the drivers side is better than the p***enger.
    P***enger side
    Driver side
    catdad49, chryslerfan55 and BigO like this.
  5. ... I used to blend in paint by first rubbing out the existing paint with a paint compatible compound ( Meguires no7) ... then overlapping the blending edge with same color lacquer before flashing that edge with lacquer thinner when the paint is still wet ... then rubbing it out a couple of weeks later ...
  6. 50DropTop
    50DropTop
    Ok, so polish the existing paint (no wax of course). Paint new area and feather into the old paint or create a hard stop? When you say flash, exactly what do you mean? Is this just a light coat of lacquer thinner at the blend line?
    I feel like the drivers side is less noticeable than the p***enger side. I think I feathered the paint out more on the drivers side vs the p***enger side where I feel I had a hard stop. Think a coat of lacquer thinner now will do anything?
  7. ... Feather new paint into the old paint ... then I would have another gun or cup ready with lacquer thinner only ... and give the whole area a pretty good shot of thinner right after my last coat of the blend job ... I would polish the old paint AND the newly wet sanded primer where they meet with the Meguires no.7 for a nice smooth surface before painting the new topcoat ... When you hit it with thinner you could see the blend line kind of melt into the old paint ...
    ... Don't think Shooting the thinner on it now will do much ... The trick is to flash it when it's wet ...
    ( I'm not a pro painter ... I just experimented with this method and it worked for me) ... hope it helps ...
  8. 50DropTop
    50DropTop
    I got in now...thank you. I’ll report back the results.
    chryslerfan55 and 1935streetrod like this.
  9. 50DropTop
    50DropTop
    She’s all one color again. I’ll determine how successful I was after the first cut and polish.
    Also hit the firewall.
  10. 50DropTop
    50DropTop
    1935streetrod, your blend technique worked beautifully. All 4 corners of the roof have a nice feathered blend of new into old. I did a quick wet sand this morning.
    3439BC76-DB0F-487C-BEDB-BBA1AF2D1A99.jpeg A224BF29-B6E7-420C-ADE5-ABEE99916993.jpeg
  11. ... Black is toughest color to blend besides silver ... You will probably still be able to see where the blend stops somewhat after you rub it ...
    50DropTop likes this.
  12. 50DropTop
    50DropTop
    Update!!
    Had a little time after work so I decided to sweat my *** off polishing the coupe. To say this turd really polished up would be an understatement.
    @1935streetrod - Your technique for paint blend was absolute magic. I know you said it would still be noticeable, but damn....I’m not sure I can even find it. Here’s a photo of your technique vs my first attempt at the cowl.
    ***My perfect blend using @1935streetrod technique ***
    ***My f’d up blend not using @1935streetrod technique***
    I can’t find the blend line with your approach! I really appreciate the advice.
    I’m getting really stoked seeing the old girl showing her age so beautifully.
    catdad49, Stogy, Hank56 and 5 others like this.
  13. ... I'm happy that it worked out for you ... It looks awesome ... I've been subscribed and lookin' forward to seeing the re***embly!
  14. 50DropTop
    50DropTop
    Working on the drivers side at the moment. Here’s the latest.
    Really liking this Wizards Mystic Cut Compound. It’s really bringing this old lacquer back to life.
    994E171A-BAA0-4714-88D7-8362E01ED3A9.jpeg 363A1323-C772-40A3-9CB2-92CA0A539A1E.jpeg
  15. 50DropTop
    50DropTop
    Mehoopany Coupe all polished up and ready for wax.
    68B263C7-9D79-485D-8742-45D086DD6285.jpeg A764710E-EC3C-442C-9184-14B752EF0D41.jpeg 7B3AADBF-711A-4D08-A0C9-9DCA4C49BE60.jpeg
  16. ***Area-51***
    ***Area-51***
    from Ohio
    wow! nice, looks good!
  17. 50DropTop
    50DropTop
    Update:
    Believe it or not progress is being made weekly, I’m down to some of the work that just doesn’t photo well. But anyway, here it is.
    Body has been polished and waxed. Door handles and mirrors have been installed.
    6740651E-5291-416B-A4BE-DDEBE9CC3E1C.jpeg 218FE32E-17F7-455B-AF32-5E51741F19C0.jpeg 9F827D10-54C2-4ED4-B326-CF66BFD8EC41.jpeg 590FDE28-D62F-452A-944E-8D725E99BC8A.jpeg A7130D5C-94A4-4B16-B3E8-E30EB15352BE.jpeg
    Original firewall pad has been cleaned, ‘rebuilt’ (original hardboard re-glued to the outer covering) with new jute pad and installed using the original firewall clips.
    Seat has been covered and new door gl*** has been installed. I also added the lap belts to the seat base (just feels safer with the kids).
    Original windshield and frame have been installed with new rubber seal.
    Besides that, I’ve started to insulate the interior with ‘Mighty Mat’.
    I also needed to redo a couple of brake lines for the Early V8 Garage Kit. Dennis and Richard were extremely helpful and this brake kit is top notch.
    The last ch***is hurdle is to find a solution to the Waldron exhaust pipe around the Early V8 garage brake kit. My first attempt wasn’t successful. Once that’s complete there is nothing stopping the body from going back onto the ch***is.
  18. rob-redm
    rob-redm
    coming along really nice ,,keep the updates coming
  19. ... LQQK'n Good! ...
  20. 50DropTop
    50DropTop
    Original garnish moldings and dash have been lightly wet sanded, washed and prepped for clear coating. These will be the only items that receive a clear coat treatment. I’ve included a photo of the glove box door wet with water to show what they will look like after shooting. I’m planning to get a chance this week....we’ll see how this pans out.
    Drivers door garnish is still wet in this photo
    Shiny area is this photo is wet/water. This is how they should look after clear.
    2BA68FA3-8A87-40D8-B659-20F4F65F835D.jpeg 3BA2A2FC-6574-4A8E-BC08-396FC8DE82A8.jpeg AC2F6C4F-9B6C-4520-8E04-9FE8CEF56805.jpeg B36AD687-368B-4F0E-8E57-D2C4D74C0E51.jpeg 19CF6C1A-AE16-4F7A-9E72-911CACB11760.jpeg 4B841F31-8E04-48A8-9D1E-AFC4F9812A4A.jpeg
  21. 50DropTop
    50DropTop
    Ok, so I didn’t get around to spraying the clear; weather just wouldn’t cooperate. Instead I spent a rainy Saturday completing the exhaust for the left side. A friend came over with a tubing bender and we hashed it out.
    The tube tried to collapse at one spot, but we were able to catch it in time. When you have so many compound curves, it became difficult to get the outside die close enough to the inside die to make the radius. Anyway, it’s breathing free and no leaks. Also plenty of clearance around that master cylinder and brake lines.
    With that complete, I could now install the body. Here’s a video of Dad and I installing the body on the ‘36 in just over 30 seconds :D
    I couldn’t believe we got it spot on the first try.
  22. 50DropTop
    50DropTop
    Got the dash cleared and started on polishing the fenders. Fenders have had a repaint at some point in their life.
  23. choptop40
    choptop40
    Nice thread, thanks for sharing the build. Great workmanship...
  24. 50DropTop
    50DropTop
    Haven’t quite finished with the dash, but I had to do a quick install to see how it’s going to look. I deleted the foot activated starter switch, so I had to add a starter ****on to the dash. I’m also using a dealer installed ‘49-‘50 Ford turn signal switch, so I’ll have the two green jewels on either side of column drop as the indicators.
    3BC62195-BD5A-4FA3-B497-548E1A5582A1.jpeg 54B2BEF6-A4BA-4A89-A095-A0D625475942.jpeg
  25. 50DropTop
    50DropTop
    Still working to get on the road; I feel I’m getting really close now. I took the day off from work yesterday and made some good progress on a few things. Finished the rear wiring harness and license plate mount.
    I’m using one of the 4 rear spare tire carrier holes for the wires (nut was removed from cage) and one of the holes to hold the bracket for the license plate light/3rd brake light. There is a rubber pad behind the bracket that helps protect the body and keep the bracket from pivoting. I welded 2 - 5/16 studs (bolts with heads cut off) into the bracket to hold the license plate mount. The bottom two holes of the spare tire carrier are filled with rubber bumpers from McMaster Carr. Originally intended to help support the license plate but they’re doing more to seal the body than support the plate. Anyway, here are some photos from yesterday; you’ll need to excuse the dust that’s ac***ulated on the car in the photos.
    catdad49, slv63, Shadow Creek and 3 others like this.
  26. sololobo
    sololobo
    cool spacer tip, that is why the H.A.M.B. rules.
    50DropTop and chryslerfan55 like this.
  27. 50DropTop
    50DropTop
    Completed the battery cable routing so I was able to take it up the road this afternoon. Decided to get a couple outdoor shots in as well. Getting real close now.
    3rd brake light showing here.
    I’m thinking I need a better rear bumper. This one didn’t clean up like the front.
  28. 50DropTop
    50DropTop
    Here’s a few more. The front fenders still need to be polished.
    E71E171B-0DF0-4A1E-B6D9-813536A588D3.jpeg 6DC32A45-D472-4B9F-8E65-17D8987F8E37.jpeg 847D8B39-5ED7-4F14-A456-19FE62594023.jpeg B891635C-94C3-4FDE-BB02-3486211F0806.jpeg 9D691F24-479C-4C73-8BC0-DC2A4D818425.jpeg 2E1E2A6D-86FD-4A8C-8DB4-4E0B5B1BE101.jpeg 470CF6C1-4A1D-4EEA-8B1F-5CE687FF20F7.jpeg C444425D-1149-4EA9-B8F0-530AEBF4F4B0.jpeg
  29. 50DropTop
    50DropTop
    This mornings project, H.A.M.B. tag topper. No hotrod is complete without it.
    Blocked flat and ready for paint.
  30. 50DropTop
    50DropTop
    Coat 1 - zinc chromate primer
