Technical Potvin cam durations at 0.050"?
Discussion in 'Traditional Hot Rods' started by 61klassic, Jul 10, 2019.
  1. 61klassic
    61klassic
    from Kent UK
    Good morning all.
    I'm trying to find more details on both the Potvin 3/8 and 400 Climax.
    I've searched on here and the Barn but can't find out the duration of either at 0.050".
    If anyone can post up full specs on both I would be grateful.
    Also is anyone out there still grinding these?
  2. Torana68
    Torana68
    from Australia
    Might be wrong but I think your looking for a modern measurement. I don’t remember anyone doing @.050 in the time frame of the HAMB. You got “ advertised” duration which wasn’t always measured the same , hence the modern ish @.050 ( as well as advertised and the older 1/2 race 3/4 race etc)
  3. 61klassic
    61klassic
    from Kent UK
    I appreciate that it wasn't a measurement always used. But hopefully someone has measured an original or if someone is regrinding them they know the specs.
  4. squirrel
    I'd be really surprised if that information exists anywhere. If you can find an old cam, new or used, you could measure it yourself....
    sunbeam likes this.
  5. akoutlaw
    akoutlaw
    Have you tried calling Moon? They were grinding the Potvin cams & would most likely have the info.
    lumpy 63 likes this.
  6. christmas tree
    christmas tree
    Try American Custom Cams at 626 963
  7. 61klassic
    61klassic
    from Kent UK
    I wish I could find one, but pickings are a bit slimmer this side of the pond
  8. 61klassic
    61klassic
    from Kent UK
    Thanks guys. I’ll try Moon and American Custom Cams
  9. Pete1
    Pete1
    from Wa.
    Flathead Jack had that info at one time.
  10. 61klassic
    61klassic
    from Kent UK
    Thanks Pete.
    Someone over here in the UK mentioned you are still grinding potvin cams. Are you still able to produce either of these?
  11. Pete1
    Pete1
    from Wa.
    I can do the 3/8 and the 425. It would have to ship t a USA address.
  12. 97
    97
  13. roseville carl
    roseville carl
    and a great job at doing it too Pete your da man.........................425 and loving it...............
  14. So-cal Tex
    So-cal Tex
    Does anyone have a phone number where Pete could be reached to order a reground camshaft?
  15. roseville carl
    roseville carl
  16. mgtstumpy
    mgtstumpy
