What solid axle to use on a 53 Ford Mainline
Discussion in 'The Hokey Ass Message Board' started by Dan Todd, Jul 10, 2019.
  1. Dan Todd
    Dan Todd
    Hi. I am looking at turning my 53 Ford Mainline into a g***er style cruiser and I am wondering what to use for the complete transformation. I am retired and have a wife so I am looking to build myself and any pointers in this area would be appreciated greatly.
  2. Rusty O'Toole
    Rusty O'Toole
    Keep the stock front suspension and raise it a few inches. At the back you can flip the rear spring hangers with a crow bar. Remove the front bumper for the g***er look. You don't need a beam axle.
    porknbeaner likes this.
  3. alchemy
    alchemy
    Isn't "g***er style cruiser" an oxy*****? They aren't meant to go together.
  4. Squablow
    Squablow
    I'm with Rusty, you can add some racy appeal to your Mainline without adding a straight axle, and you'll be a lot happier you did it that way if you intend to street drive it. I would think most of the cars that got converted from IFS to a beam axle were strictly drag-race only.
  5. HOTRODPRIMER
    HOTRODPRIMER
  6. RichFox
    RichFox
    You might look at an early Econoline. I don't know how it is width wise, But I used one and liked it. And the bolt pattern is correct for your Ford
    jimmy six likes this.
  7. HOTRODPRIMER
    HOTRODPRIMER
    The only problem with that is finding a early Econoline that you can afford, the last one I saw was pretty nice and had a huge price, they are getting pretty popular again.HRP
  8. 55 Ford Gasser
    55 Ford Gasser
    I don't know where you are located, but I have a complete econoline front axle ***embly that I would let go for $300 picked up. I'm in Hampton Roads area of Virginia.
  9. lumpy 63
    lumpy 63
    There is one at the shop ...
    scotty t likes this.
  10. Jalopy Joker
    Jalopy Joker
    be sure to add steps on both sides, like on a tall 4 wheel drive pick up truck to make it easier to get in & out
  11. southcross2631
    southcross2631
    Early F-100 53-56 . A lot of guys are pulling them out to put Mustang 2 front ends. A guy gave me his and it had a disc brake conversion already done with braided steel brake lines. I narrowed it to put it under my Morris Minor , but should fit your Ford fine.
  12. lumpy 63
    lumpy 63
    A properly done straight axle car drives just fine. I'm not talking about those stupid super nose high abortions. As long as everything is correct such as steering angles and caster they drive as normal, not saying I'm going to road race one but in my experience done correctly no big deal.
    seb fontana likes this.
  13. Rusty O'Toole
    Rusty O'Toole
    1953 was the first Ford with ball joint suspension.
  14. No, it was the '54. New suspension to go with the new overhead V8...
    sidevalve8ba likes this.
  15. ^^^ I like this. We used to lift more cars with stock suspension then anything else.
    My mid '50s Fords used to get lifted by using a rubber shim on top of the front spring and re-arching the rear springs.
    Now as for an axle seems like we used and Econoline axle more than anything else on a mid '50s ford it should work well on the earlier fords as well.
  16. Dan Todd
    Dan Todd
    Thankyou for the reply Rusty. This sounds like a much easier way to achieve what I am wanting to do.
  17. Dan Todd
    Dan Todd
    Yes, it is kindof an oxy***** but I was trying to "not" offend anyone while trying to get answers to my request.
  18. Dan Todd
    Dan Todd
    Nie ride. I am from SouthEast Minnesota..
  19. HOTRODPRIMER
    HOTRODPRIMER
    No sir, the 1954 Ford was the first to have a modern ball hoint front suspension, the '53 cFord still retained the pin and like suspension. HRP
  20. southcross2631
    southcross2631
    As a former owner of a 53 Ranch Wagon . I can verify that they are the last year of the King pin style front end. A rubber A/C spacer can be used to raise the front end a few inches. Just make sure the front end does not need to be rebuilt before you start screwing with the geometry of the front end.
    They were pretty good driving cars when everything is right.
    Converting a straight axle will have it driving like an early F100 which is not bad, even easier if you install a power steering box to turn it with.
