Projects My 36 in the shop, getting close ! Goodguys bound !
Discussion in 'The Hokey Ass Message Board' started by rob-redm, Jul 11, 2019.
  1. rob-redm
    rob-redm
    FIX2.jpg So sent the 36 into the for some much needed repairs.. transmission issues along with a vibration in 1st and 2nd gear . Have a list of other things to fix on it... but the shop has got a start on it, and it's in great hands.. Hoping to have back on the road for Goodguys in Puyallup at the end of the month.. fingers crossed FIX1.jpg View attachment 4348881 View attachment 4348881 FIX3.jpg View attachment 4348881 FIX4.jpg
  2. rob-redm
    rob-redm
    so the vibration is the big concern... we are trying first the engine vibration dampener and see if
    that changes anything.. It has a solid front Hurst engine adapter .
    lothiandon1940 likes this.
  3. catdad49
    catdad49
    Boy, I like That!
  4. williebill
    williebill
    Really good looking car...
    rob-redm likes this.
  5. Atwater Mike
    Atwater Mike
    While you have the trans out, have the boys check flywheel/pressure plate balance.
    (Also, loose on crankshaft flange???)
    Johnny Gee and Jalopy Joker like this.
  6. Jalopy Joker
    Jalopy Joker
    good luck on repairs for good looking ride
  7. rob-redm
    rob-redm
    that is the plan as well. doing some simple stuff first to see if it makes any changes.. before we tear the car down and investigate further into it.. might as well replace all the clutch stuff and flywheel as needed since we have the trans out at some point..
    brady1929 likes this.
  8. rob-redm
    rob-redm
    So we did find some drivability issues with this old Holley that was on the car.. Switched it over to a Edelbrock EDL-1406 600cfm electric choke carb.. What a big difference it made... Right out of the box , bolted it on and ran really great.. Needs some fine tuning.. Then we are on to replacing the trans. Check the flywheel and clutch parts.. While there just going to replace them... On another note does anyone know if some makes replacement parts for stock 36 Ford parking brake handle(need ****on spring ect) ? I 've looked and not had a lot of luck... need the spring and some other parts. thank you for all the great comments.. Have my fingers crossed to make Goodguys here... carb holley.jpg
    Hamtown Al likes this.
  9. rob-redm
    rob-redm
    so the shop has the transmission out, and ready to install the rebuilt one... Didn't see anything wrong with the clutch or flywheel .. Since its out just going to replace it all … have some other things like brake adjustment and parking brake needs attention... and other small stuff
  10. Mr48chev
    Cool, we might get to see you put some real miles on it yet once it gets all sorted out.
  11. J2X
    J2X
    rob-redm - Would appreciate learning source of your rebuilt transmission - Thanks in advance for your answer DW
  12. rob-redm
    rob-redm
    sent you a PM
  13. rob-redm
    rob-redm
    That's the plan for sure, Goodguys is around the corner and shooting to have it there again...
  14. rob-redm
    rob-redm
    coming back together... still some small stuff to do... jackstand1.jpg jackstand2.jpg
    Jalopy Joker likes this.
  15. rob-redm
    rob-redm
    Shooting for Goodguys in Puyallup.. wish I was heading to Deuce Days in Victoria BC.. oh well
    Have fun to everyone who is going...
  16. rob-redm
    rob-redm
    Got to give some props to Thunfield Rod & Custom (Marshall & Gary)... They have been busting **** on my car, all at the same time getting some other complete builds ready for Deuce Days... Big thank you to them ( and Mike S.) I can do small stuff, but I'm out of my comfort zone with bigger stuff ( also no room) .. Thank you guys !
    Joemama likes this.
