Features Doing Falcons Right
Discussion in 'The Hokey Ass Message Board' started by falconizer_62, Jul 23, 2008.
  1. roundhouse
    roundhouse
    from GA
    543BF6F9-8946-4543-B0A9-F7376CAE3F26.jpeg Gonna bring this thread back to the top
    My 21 yr old son bought this one yesterday
    So we will be back on here with a lot of questions
    Little rough around the edges but a good starting point
    VIN says it was factory V8
    Currently has a 302 with a lumpy cam
    Automatic with a floor shifter
    And AC that doesn’t quite blow cold enough
    Manual disc brakes on the front
    Armstrong steering
    Missing a lot of parts from the interior , dash is hacked up around the radio
    Has some mods to the suspension
    Trying to figure out what exactly
    Jimmy, Thor1, Nailhead A-V8 and 4 others like this.
  2. Ghostcruiser
    Ghostcruiser
    from NE Florida
    She's a beauty!
    Rob
    Thor1 and loudbang like this.
  3. Gammz
    Gammz
    from Lincoln Ne
  4. safetythird
    safetythird
    So I'm hunting down a set of headliner bows for a '62 Falcon.
    Can anyone confirm if they're the same as the ones in a '62 Mercury Comet?
    If anyone has a set for a Falcon.....I'm interested.
  5. Boulderdash
    Boulderdash
    Can anyone provide a picture of the engine bay brake line routing from the m/cylinder? I have a t-piece and brake light switch (not shown) as well as the split union as pictured, all of which came off it, but can’t figure out which lines are T’d where.
    Does the rear come off one outlet on the master and the fronts off the other? Or does it not matter?
    63 Falcon by the way
    13AC55CB-DC03-4239-B96C-6C4B7A02788D.jpeg 2460847A-DE38-490C-BCCE-2F65F06DF916.jpeg
  6. 62rebel
    62rebel
    Right side feeds rear brakes, front port feeds front by going to a splitter. Brake light switch on top port. Best I can remember.
    Deuces and Gammz like this.
  7. Gammz
    Gammz
    from Lincoln Ne
    Mines other way round. Pressure sensor is on the bottom. But yeah. One to the rear and a spilt fitting to the front for left and right.
  8. Boulderdash
    Boulderdash
    Thanks guys, that's great. Just wanted to be sure before bending any brake lines
  9. Falcon61wagon
    Falcon61wagon
    from Indiana
    its been ten years... any thoughts on how this mod could be done?
  10. Boulderdash
    Boulderdash
    Next silly question: what size brake unions are these? I’ve discovered they’re not 3/8 - 24 / UNF....
  11. 62rebel
    62rebel
    I would source a second taillight opening and put it on a hinge from a gas door. Mount the taillight on that. Reroute the filler pipe up to the center of the opening. The original quarter panel opening will have to be enlarged but must retain the ring section to maintain its shape. Coming up with a latch is another job
  12. loveoftiki
    loveoftiki
    from Livonia,Mi
    Mines finally on the road…gotta do new leaf springs, frame connectors, and my traction masters…but she’s running well…plenty of power..sounds like a beast…no leaks, runs cool, great oil pressure….only regret…should of put in a mew steering box… 23634C79-6A18-4D84-B7D9-28CB02053899.jpeg DDB67E02-16F5-4D06-B9D7-B3CD5B662BE8.jpeg 22E8599C-2DD9-4B31-A02C-08B7DDDEF129.jpeg 35FC2AC8-71DC-4F90-9CAD-B3DC15BE877A.jpeg 85C11A78-2E94-4AAD-B868-8CD1E1A768B5.jpeg ABC5008D-95A6-49D7-AB00-760D7943FD94.jpeg 9D2C9171-00AA-4B9B-80CB-B0BEB0FE608A.jpeg
  13. loudbang
  14. loveoftiki
    loveoftiki
    from Livonia,Mi
    Thanks…I’m pretty happy with it so far. Still getting used to it…had a ohh Sh****t moment when I thought I was in 3rd gear and wanted to down shift into second…..nope I was in Second…quick chirp of the tires and high Rev of the motor, and my heart coming out of my chest..never upshifted so fast in my life
  15. RmK57
    RmK57
    Most every older Ford is 3/16" inverted flare.
  16. loudbang
  17. loudbang
  18. loveoftiki
    loveoftiki
    from Livonia,Mi
  19. Rootsy and loudbang like this.
  20. downlojoe33
    downlojoe33
    Can’t let this thread die…..my 60 ‘Chero. Just doing a rebuilt 170, 3spd, rebuilt drum brakes, Shelby drop, Mustang uca’s with the good ball joints, cut front coils, 4 lug 15” Ansens, and other rebuilt or new parts as needed. Everything I’ve learned from this thread. Plus some Patina Sauce to purty it up a little. Will be used as my around town daily. IMG_0421.jpeg
  21. Sart156
    Sart156
  22. loveoftiki
    loveoftiki
    from Livonia,Mi
  23. loveoftiki
    loveoftiki
    from Livonia,Mi
  24. 32Tudor
    32Tudor
  25. 32Tudor
    32Tudor
    Helping a friend put a 390 in a 65 Falcon Convertible. We have a Mustang II welded in and motor mounts setup to allow clearance to install the bellhousing, then slide the motor back to allow just enough clearance for the radiator. The area we are currently wrestling with is the steering. The 390 has an aftermarket rear sump oil pan and that works great with the cross member, but we have significant interference with the power rack. We have ordered a manual rack, but I believe that will still require modification to the oil pan. Have other people had issues with clearance for the rack and pinion? Can anyone recommend a header or exhaust manifold that may help with steering clearance on the driver's side. It is going to be very tight with the stock '66 exhaust manifolds.
