Projects SOUTHEAST GASSERS "BRAND X" BUILD
Discussion in 'Traditional Hot Rods' started by HEMIBERT, Oct 12, 2015.
  1. saltflats
    saltflats
    from Missouri
    Nothin wrong with that.;)
    mad mikey and loudbang like this.
  2. southcross2631
    southcross2631
    They say the way to make a small fortune racing, is to start with a large fortune.
  3. HEMIBERT
    HEMIBERT
    I heard that! What the SEGA has is worth far more than money.
  4. Mike Colemire
    Mike Colemire
  5. mad mikey
    mad mikey
    Good luck HEMIBERT, go get um. That is one bad fish you pilot.;):)
    Quain Stott and loudbang like this.
  6. HEMIBERT
    HEMIBERT
    Well, season 2 is over. Not quite what we hoped for, but ended much better off than when we started. Winding up a consistent top half qualifier with competitive, although not winning, times is what we wanted, but not good enough anymore. I must say though, that the SEGA and everyone associated with them is the very best out there. The family we are and the support we offer to each other is second to none anywhere. Every race is like a family reunion. Our association with Quain Stott and his group has been a life changing experience for both of us. They give respect and loyalty a new meaning you just don't see anymore.
    Enough preaching. We love Quain, what he does and will support him 100%.
    Now. We are going to regroup, re-think, move to A/Gas, build wife a car to run and build a truck so as to get 2 cars there for next year. Have to get busy. I'll post back when I have something to share.
    Thank everyone of you for your support and visits at the track. They means a lot to us and hope to see you next season.
    Thanks again,
    Robert & Rita
    Black & Blue Racing
  7. Quain Stott
    Quain Stott
    Thanks Robert and please let me know if y'all need anything.
  8. catdad49
    catdad49
    Robert, not really a Mopar fan, but it did my heart Good to see the Black and Blue running strong. Love your sentiments on the group and Quain's response pretty much backs it up. I'll be watching for the new build thread, Carp.
  9. HEMIBERT
    HEMIBERT
    For the last race, we had 3 teams loan engines to their competitors so they could make it! I've seen the same with transmissions and just about every other part on the cars. I had Rusty Sampsel stop working on his car and help us change intakes between rounds so I'd be ready to run him. We mean it when we say..We are family.
  10. saltflats
    saltflats
    from Missouri
    That's the drag racing spirit!!! Great Job!!!
  11. Hang'emHigh
    Hang'emHigh
    Let's clarify. That's the SEGA drag racing spirit!!!
  12. saltflats
    saltflats
    from Missouri
    It is....and others ;)
    I'am just saving for a 4 gear.:)
    Hang'emHigh and loudbang like this.
  13. southcross2631
    southcross2631
    Hoping to have my D/Gas car done by April ,but there will be a move in their sometime if my place sells here. Looking for property in the Maryville. Tn. area.
  14. Higgy's Henry
    Higgy's Henry
    Robert, hope your not holding back on updates!!!!
  15. HEMIBERT
    HEMIBERT
    No, not holding back. Plan on starting on wifes new ride this weekend. A lot of moving and shuffling of parts to do!
  16. HEMIBERT
    HEMIBERT
  17. enloe
    enloe
    from east , tn.
    Did I see this car on the back of a trailer in Lebanon Tennessee a couple of weeks ago with the front end mashed??
    We were coming back from Bowling Green.
  18. Dog_Patch
    Dog_Patch
    Yes - he fixed it though.
    loudbang, chryslerfan55 and enloe like this.
  19. HEMIBERT
    HEMIBERT
    Yes. We're working on it as we speak. Blew a tire and ate the guardrail. CRASH2.jpg
    No problem though. I have a welder and an awesome grinder!
    Hombre, Gotgas, racer-x and 10 others like this.
  20. loudbang
    One photo from bangshift coverage
    Scott Mize, Hombre, enloe and 4 others like this.
  21. catdad49
    catdad49
    Robert has the Black and Blue Cuda running pretty good!
    loudbang, Hombre, enloe and 1 other person like this.
  22. HEMIBERT
    HEMIBERT
  23. southcross2631
    southcross2631
    What engine combo are you running now that you are an A/FX car ?
  24. HEMIBERT
    HEMIBERT
    Same thing. 426" low block wedge.. Just changed it to Hilborns on alcohol. I'm sure there are some differences in set ups I could do for alcohol, but the A/G engine was already built when we decided to change. I'd be interested in knowing the differences in the basics for gas vs alcohol, camshaft, timing, etc.
  25. southcross2631
    southcross2631
    When I changed my big block Chevy in an O/T Nova over to alcohol from gas. I raised the compression to 15 to1. Increased the lift and duration on the cam. Removed the radiator and just looped the top and bottom radiator hoses. Installed a pan heater to pre-heat the oil so I could help keep the moisture out of the oil. It never ran hot even when bracket racing and going back to back rounds.
    The car picked up 4 tenths with the changes.
    Hang'emHigh, Hombre, Thor1 and 4 others like this.
  26. HEMIBERT
    HEMIBERT
    That's good. My alcohol dragster didn't even have freeze plugs. I think having the water in it though helps keep the temperatures more even. My compression is in the high 13's and I think that once I get a few other things sorted out, I'll just have Bullet or Erson grind me a new cam. I need the weight on the front, so I'll leave the radiator in for now. Good idea with looping the hoses. I hadn't thought of that yet. Thanks for your input.
    loudbang and enloe like this.
  27. southcross2631
    southcross2631
    That should be fine as far as compression. A custom ground cam for your application will do wonders for your Mopar.
    I know Quain would say no to an EGT , but you could install one to get you close on your tune and then you will be in the ballpark when you go to the SEGA races. The good thing about alcohol is that it doesn't change much as far as temp changes like gasoline.
  28. Brian Penrod
    Brian Penrod
    Awesome build, don't know how I missed it. Hope you guys make it back to Clay City next year!
