Technical What flywheel do I have? Flathead
Discussion in 'Traditional Hot Rods' started by TBone69, Jul 13, 2019.
  1. TBone69
    TBone69
    from NJ
    Hey folks,
    Picked up what I thought was a cut down A/B flywheel setup for a V8 clutch.
    Was just comparing it to a stock A flywheel and the A pilot bearing just drops thru.[​IMG]
    Guessing this is a cut down flathead flywheel
  2. King ford
    King ford
    from 08302
    Sure looks like one , if you measure the bolt circle and center to center on the dowels I can compare to mine tomorrow....also a photo of the back would help...where about are you located in Jersey? I'm down here in ***berland county....
  3. TBone69
    TBone69
    from NJ
    Hey King Ford,
    I’m up in Freehold.
    Top pic is the back with the A pilot bearing just sitting in there on the work bench.
    Looks like qcenter to Center on the dowels is 3 1/2. I think bolt pattern is same as the banger but ring her would not be in the same location.
  4. TBone69
    TBone69
    from NJ
  5. TBone69
    TBone69
    from NJ
    Here’s a shot from the rear comparing to a stock A flywheel. Certainly looks similar, wonder it someone had just opened up the pilot bearing whole ?
  6. modela4shane
    modela4shane
    Looks as though the pilot bearing hole has been opened up for a bigger input shaft bearing.... probably using a different transmission.
  7. TBone69
    TBone69
    from NJ
    It does look like it may have been machines out
    Measures out at 1.846
    Fits the crank and if I had the ring gear on it it seems like it’s in the right place.
    Time to find a pilot bearing that has a 1.845 OD, any ideas ?
