Hot Rods Engine turning or Damascening
Discussion in 'The Hokey Ass Message Board' started by lothiandon1940, Sep 14, 2016.
  1. Russ B
    Russ B
    '28 Chrysler in 1929 ford cabriolet
  2. rexrogers
    rexrogers
    Engine turning is one of those projects that is very time consuming to get it done without any messups but when you are done it looks great. I have done a few dash inserts that were chromed and then using an abrasive stick the engine turn pattern was put in. I like using the mill for this operation that way once the part is clamped down it makes getting the spacing a little easier.
    On the Timbs special i cheated and ordered a sheet of engine turned aluminum from FPM metals in Nebraska from there i did the gauge layout and hammer formed the edges.
  3. hotcoupe
    hotcoupe
    FWIW . . . typically chrome plating is about four millionths of an inch thick, you actually look thru the chrome at the nickel. the chrome does add brilliance and a blue cast, but it`s main purpose is to keep the nickel from oxidizing. can you post an image of the piece that was done by Eamonn Keogh? thanx.
    osage orange and lothiandon1940 like this.
  4. Devoz
    Devoz
    Here you go hotcoupe, apologies I for the poor photo quality.
  5. mike bowling
    mike bowling
    I don't have a picture, but will try and get one-- There's a construction company in the next town over that has a 10 wheel dump truck with an aluminum dump body and the WHOLE THING is "turned" or whatever you want to call it. This guy has some beautiful trucks, but this one is over the top!
    Great thread; some real purty stuff!
    (AND I found out what "horology" is!)
  6. lothiandon1940
    lothiandon1940
    ..............................and all this time I thought horology was the study of........well, you know.:eek:
    osage orange and lothianwilly71 like this.
  7. 31Apickup
    31Apickup
  8. Truck64
    Truck64
    from Ioway
    Well it's about time!
    osage orange and ClayMart like this.
  9. ClayMart
    ClayMart
    I see what you did there. ;) And I'm a little jealous. :D
  10. theHIGHLANDER
    theHIGHLANDER
    Obviously the owner of this one was a fan. As seen at the ACD Festival in 2015:
  11. Buz
    Buz
    I did this dash for my 32 five window using a abrasive round in my drill press. It's stainless and stays very fresh looking.
  12. lothiandon1940
    lothiandon1940
    Beautiful job, Buz.:)
  13. Just Gary
    Just Gary
    Mag wheel center cap.
    Not mine- plucked from the HAMB cause I thought it looked cool and traditional, but different.
  14. 402BOSSMAN
    402BOSSMAN
    A few from a set of Hemi Valve Covers I did.
  15. 402BOSSMAN
    402BOSSMAN
    Been doing this to some Hemi Heads lately, looks pretty cool! This is a set of solid Mastodon Heads for Ted Brine's Nitro Fuel Coupe.
    lothiandon1940 and kiwijeff like this.
  16. Wow!
  17. lothiandon1940
    lothiandon1940
    ......WOWx2:)
    lothianwilly71 likes this.
  18. Dan Timberlake
    Dan Timberlake
  19. Burkedore
    Burkedore
    A set of poly valve covers I turned.
  20. lothiandon1940
    lothiandon1940
  21. lothiandon1940
    lothiandon1940
    Anymore examples of your engine-turning work? Post up the pictures.
  22. Runnin shine
    Runnin shine
    Glad you made this post! I had saved this thread for when I completed my dash. I forgot and it was done over a year ago. Well anyway
    Stainless, polished, alder dowels, Clover valve lapping compound, HF drill press, lots of work and it seems worth it once the sting of it all wore off.
    My first attempt using a drill press and a half-inch Cratex on 16 gauge stainless steel. I still have to cut a 3-3/8 inch hole in the middle for the tachometer, and drill small holes for the turn signals, high beam and start/run indicator, but you get the idea. I needed more dash surface than my 29AA provided, so I'm making an overhead panel the length of the front header, where I can also put a light switch, a radio and some speakers. Dang that stainless is tough to cut a hole through.
  24. David Gersic
    David Gersic
    from DeKalb, IL
    Get a carbide tooth cutter from Lenox. Goes through stainless like ****er.
    lothiandon1940 likes this.
  25. David Gersic
    David Gersic
    from DeKalb, IL
  26. nrgwizard
    nrgwizard
    from Minn. uSA
    Dan;
    The '55 Stude speedster, '56 Golden Hawk, & other Hawks ->61 dash over lay was not a decal. Was a piece of AL, but it wasn't actually engine-turned, either. Real good eye-deceiving going on, as it used real small "divots" in the Al sheet to simulate the round circles from the "turning". At least the 3 Speedsters that I have are that way, as was the '56 GH dash. Still neat & eye-catching.
    Marcus...
    kidcampbell71 and lothiandon1940 like this.
  27. David Gersic
    David Gersic
    from DeKalb, IL
    Interesting. Can you post a picture?
    A quick search for images turns up some, but they look turned to me.
    Nice looking dashes. I’m intrigued by this “divot” thing. Next time I see a Stude, I’ll have to check it out more closely.
    72yenkonova and lothiandon1940 like this.
  28. 4tford
    4tford
  29. nochop
    nochop
    from norcal
    What is the original purpose of engine turning? Is it just a finish or is there a reason behind it?.....just asking for a friend
  30. lothiandon1940
    lothiandon1940
    .......Just decorative as far as I know.
    nochop likes this.
