Technical How high does your sbc sit in model a frame
Discussion in 'Traditional Hot Rods' started by peter schmidt, Oct 6, 2016.
  1. Mr48chev
    Hambers rig that the engine placement looks just right on.
    With the Model A banger in stock location the pan rail is just about even with the top of the frame rail. I'd think that one would want what ever engine he put in to have the centerline of the crank running pretty much on the same line as the stock crank did. Clearance issues and gotta have that jacked in the air g***er look aside.
    LCGarage likes this.
  2. 1946caddy
    1946caddy
    from washington
  3. geoford41
    geoford41
    from Delaware
    I use SBC side mounts I welded up with standard rubber mounts and used Pete & Jakes frame Dimenson which I believe is 17 3/4" to the forward edge of the SBC frame mount, check their website see attached photos this went doen the to finance the '40 but I planned a 2" channel, 3" chop, reversed A DSC00766.JPG DSC00763.JPG DSC00769.JPG firewall
  4. dan31
    dan31
    My 350 crank pully sits about a 1" lower than the front cross member [model a frame]
  5. pecker head
    pecker head
    D6E3C884-DF94-4C5D-9245-DFF43E6FCC2A.jpeg 9BD54019-9CF5-4502-AAA7-CFC4B9E4A252.jpeg 62E885B2-2D17-4295-BEDD-A276A7086E12.jpeg How’s this? Gonna make permanent soon.
    Shadow Creek likes this.
  6. blvdbill
    blvdbill
    scrap metal 48 and Just Gary like this.
  7. banginona40
    banginona40
    Set up using a Zip's water pump riser
  8. Hotrodmyk
    Hotrodmyk
    An old post from '16 re-popped. I wonder what the OP ended up with.
  9. Deescott
    Deescott
    D406FA76-ED73-48F1-A54A-2DA319315A09.jpeg I’ve done 3 SBC/Model As, and I put my frame engine mounts flush with top of frame, use good flathead type rubber mounts, and a 1 3/4in aluminum spacer all with a hurst type mount. I have to trim stock GM fan 1/4in to keep it from hitting anything. I live in AZ,(114 degrees yesterday) drive everywhere and don’t overheat. And I modify the engine mount to use stock fuel pump. Pic looks horrible but it works
  10. baspinall
    baspinall
    from SE PA
    I'm curious how many of you had to notch the "upper" firewall? My frame is aftermarket and it's looking like the upper firewall will need to be recessed or notched pretty good.
  11. scrap metal 48
    scrap metal 48
    If you set the motor high enough to run a mechanical fan, on 28/29 A's you have to recess the upper part of the fire wall.. You can do this and still use the stock tank if you plan correctly...
  12. scrap metal 48
    scrap metal 48
    Some pics of my old coupe with above done... I did not use original tank in this coupe but it can be done....**clic pic** engine 001.JPG engine 006.JPG
    Shadow Creek and pecker head like this.
  13. scrap metal 48
    scrap metal 48
    One of my other old coupes running stock tank, upper firewall recessed and mechanical fan.. I'm done now... **clic pic** for sale pics II 007.JPG
  14. Deescott
    Deescott
    Without lengthening the frame or moving the body back, there’s no way to avoid altering the firewall on a model A with a SBC
  15. baspinall
    baspinall
    from SE PA
    I don't seem to see many "upper" firewalls changed? Meaning in a 28-29 the front of the gas tank. The lower portions I see recessed. I'll be changing mine just seems like I haven't sen many that needed it.
  16. scrap metal 48
    scrap metal 48
    If you set the motor high enough to run a mechanical fan, you have to recess the top portion of the firewall on a 28/29.. If you run the motor low and use an electric fan, you don't...
  17. 26 T Ford RPU
    26 T Ford RPU
    I don't see many photos that actually show the motor in relation to the top of the frame, just general motor shots.
    And for reference i posted mine on page one.:) JW
    baspinall likes this.
  18. Francis bruno
    Francis bruno
    It looks like yout firwall is not recessed much, did you stretch frame, im trying to mock up my 31 rpu .
  19. 26 T Ford RPU
    26 T Ford RPU
    Its a Model T on an A frame and no. JW
  20. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    For P's and Q's..... my oil filter was almost level with the frame. No stepped frame, no weirdness... Tunnel was fine with pedals, and adequate.... DSCF0100.JPG
    26 T Ford RPU likes this.
