Technical Y-block PCV
Discussion in 'Traditional Hot Rods' started by coilover, Jul 19, 2019.
  1. coilover
    coilover
    from Texas
    Put this set up on a 57 312 and it's kept the engine bay clean. Has electric fuel pump so with mechanical pump breather would need relocated. 312 PCV system 002.jpg 312 PCV system 001.jpg
    loudbang and 46international like this.
  2. sunbeam
    sunbeam
    That breather is not on the fuel pump hole. The fuel pump is mounted to the timing cover not the block.
  3. Stllrng.
    Stllrng.
    That's exactly how I did mine
  4. A PCV retrofitted on any engine is pretty much a win -win situation.
    mikhett likes this.
  5. Nice, what hole is that in the block that yo are tapped into? Guess it is one that goes into the valley area? did you drill it or is it a stock hole?
  6. sunbeam
    sunbeam
    That is the orginal hole for the road draft tube in early motorshttps://images.search.yahoo.com/search/images?p=y+block+road+draft+tube+images&fr=yfp-t&imgurl=https://cimg6.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/800x598/80-image_f8d188fb861df8c3d40dfa36d7bd06ec19f92e9d.jpg#id=4&iurl=https://cimg6.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/800x598/80-image_f8d188fb861df8c3d40dfa36d7bd06ec19f92e9d.jpg&action=click
  7. If that is plumbed into the back runners of the intake it will run lean on the cylinders they feed. That is not by any means a good set up! The only vacuum that port should be hooked up to is a brake booster, stationary vacuum. JW
    Johnny Gee and Blue One like this.
  8. Blue One
    Blue One
    from Alberta
    Yes that’s correct. The road draft tube location is not a good place for the PCV.
    And it’s especially not good plumbing it into the back of the manifold
    The rear cylinders will definitely be affected.
    Study the diagram of the 60s Ford PCV system and you’ll see the right way to plumb a Y block PCV system.
    Better is the later design that puts the PCV in a baffled hole in the back of the valley pan.
    This is how I did my Y Blocks PCV.
    2EDBFB10-CD9B-424C-BFEE-3FD262FECD7B.jpeg BC0E4983-CE2F-4000-9FDA-9E7BEC508C81.jpeg F9602CA2-681C-4D56-8445-98152500F3F3.jpeg 96BAE764-DD4F-428E-AEE2-74BD7EE7633D.jpeg
  9. sunbeam
    sunbeam
    this would be betterhttps://images.search.yahoo.com/search/images;_ylt=A0geKLm5UjNdJVAA8MdXNyoA;_ylu=X3oDMTEycHBtMWNzBGNvbG8DYmYxBHBvcwMxBHZ0aWQDQjY4MzNfMQRzZWMDc2M-?p=ford+carb+spacer+plate&fr=yfp-t#id=36&iurl=https://cdn.shopify.com/s/files/1/0748/6631/products/IMG_9927_1024x1024.JPG?v=1505334998&action=click
    26 T Ford RPU likes this.
  10. Also the carb or center one on three twos must be metered for a pcv system or it will run like it has an air leak, which is exactly what it has. JW
  11. jimmy six
    jimmy six
    Definatley need a baffling system leading out of any engine. The 61-64 292's had these in the valley cover at the rear like the diagram shows.
    Truck64 likes this.
  12. My draft tube connected on the valley pan not the block, see "blue one" photos.
  13. sunbeam
    sunbeam
    I was mistaken I thought you were talking about the hole that his breather cap was connected too. The late blocks that had the breather on the side of the block cast over were much better less core shift . By sonic testing I found a late 292 block that I ran on the street with a 3.91 bore. It was a 296 inch motor ran a 3.1 inch 239 crank at the time I was into short stroke motors.
    46international and dana barlow like this.
  14. yes you are right thanks
