Hot Rods Painting the engine bay
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jul 20, 2019.
  1. HOTRODPRIMER
    HOTRODPRIMER
    This is probably more applicable to the guys that are working on cars with inner fender panels but could also relate to the earlier car firewalls.
    My question is do you normally paint the inner fenders and firewall the body color or do you go with something different?
    I left the firewall body color on the Ranch Wagon although my originally intent was to do all the inner fenders the same green color, when it came time to start putting everything back together the green inner fenders looked like ****, I sand blasted all my the paint of them and started over.
    A nice semi-gloss black really looked correct. HRP
  2. KoolKat-57
    KoolKat-57
    from Dublin, OH
    I have always used Krylon Semi Flat Black, low sheen very close to factory finish.
    KK
  3. 46fatford
    46fatford
    I used duplicolor high temp ceramic semi gloss black on my 46 coupe underhood and it turned out great.
    HOTRODPRIMER and Deuces like this.
  4. bigdog
    bigdog
    Everything body color looks to street rodderish to me. You need a little contrast.
    HOTRODPRIMER, Deuces, Petejoe and 4 others like this.
  5. Sky Six
    Sky Six
    from Arizona
    It depends on the car, modifications, and naturally the color. My '54 F-100 had the inner fenders painted the same color as the body, It was silver metallic mist and was a mild custom. The '57 has gloss black inner fenders as is basically a stock car.
    Not sure if there is a rule.
  6. I really like the look of a painted fire wall
    And semi flat black everything else.
    Draws the eye to the engine
    That engine bay is the cats pyjamas @HRP
  7. 56don
    56don
    On a 50s style car, I like the firewall painted the body color since its a part of the body. And I like to see the inner fenders and radiator surround either a contrasting color or semigloss black. I don't have a good photo of it now but I painted my yellow Chevy's firewall yellow with the car and the inner fenders the same charcoal gray that I painted the frame with.
    Deuces, HOTRODPRIMER and olscrounger like this.
  8. squirrel
    I got accustomed to looking under hoods where everything is the color the factory painted it, and I kind of like that look. Body color firewall, and almost glossy black inner fenders (unless the car has some type of unit construction, and the inner fenders are not removable, then they're painted body color also).
    But the most important thing is to paint the area behind the grille (and the radiator/AC condenser) black, or it looks like poo poo
  9. olscrounger
    olscrounger
    ^^^^ this and what HRP said. Do mine this way as well.
    SEM 39143-144 very closet to orig gm semi flat and lasts well.
    Deuces and HOTRODPRIMER like this.
  10. DDDenny
    I did too, I bought that stuff by the box for years but they changed the formula and it just doesn't seem the same.
  11. 56don
    56don
    If you build a low rider then you have to have it all chrome and gold plated..:eek:
  12. My 56 Chevy is as the general intended, body color fire wall semi gloss black everything else. The 57 vette is a 90’s hold out, gloss black everything. If I ever finish my 48 HEMI plym it will have upper firewall body color and everything else off white/ivory
  13. 911 steve
    911 steve
    from nebraska
    white upper firewall w/pinstripes & wht inner fender panels on my black 40 Ford goodguys 6-29.jpg
  14. 46fatford
    46fatford
  15. 46fatford
    46fatford
  16. Right now the engine compartment on my 55 Chevy is the same as the outside of the car, a custom mix black cherry. I am thinking of pulling the engine and doing some gasket changing and cleaning. While its a blank canvas I am thinking about painting the inner fender aprons and firewall a creamy off white. Maybe a little pin striping etc. Not too much though. I like that early 60's look and think it will be a refreshing change.
  17. paintman27
    paintman27
    from new jersey
    white firewall white inner fenders
    Black_Sheep, scotty t, Deuces and 2 others like this.
  18. southcross2631
    southcross2631
    Depends on the car. Mopar guys like to drop the k member and paint everything body color.
    I paint all my race cars a light gray so you can see at night in the pits and if you get a leak it shows up.
    My customers tell what they want and that's what they get.
  19. Black_Sheep
    Black_Sheep
    Unless it's a black car, painting a muscle car era Mopar engine bay black is a cardinal sin.
    I always liked traditional cars with a white engine compartment so the '58 got the same treatment. Ford HP White with satin clear...
    olscrounger, CGkidd, scotty t and 3 others like this.
  20. primed34
    primed34
    Gloss black firewall and inner fenders on my '55. Stainless cover on the firewall of my '34.
  21. BamaMav
    BamaMav
    from Berry, AL
    Gloss black on the firewall, satin black on the inner fenders and core support.
  22. rosstom
    rosstom
    I used Krylon #1613 Semi Flat Black.
    Deuces, HOTRODPRIMER and barryvanhook like this.
  23. Mirror muffs?
    Should they match the headliner or carpet ?
    Does the carpet have to match the d****s?
  24. squirrel
    as long as her purse matches her shoes, it's all good
  25. Johnny Gee
    Johnny Gee
    from Downey, Ca
    And if she's barefoot?
  26. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Black firewall on a non black car depends on the build and if a parting line that looks good is do able.
  27. HOTRODPRIMER
    HOTRODPRIMER
    What the heck are you talking about? HRP
  28. 56don
    56don
    Then in that case, she is from Alabama...:eek:
  29. Latigo
    Latigo
    I like the natural oil, grease and road grime look. Think it's called patina.
    HOTRODPRIMER likes this.
  30. HOTRODPRIMER
    HOTRODPRIMER
    Or lack of maintenance, which I my case I am guilty with my old beater. :D HRP
    47ragtop likes this.
