Technical Chip Fix in BaseCoat/Clear Coat
Discussion in 'The Hokey Ass Message Board' started by 5window, Jul 20, 2019.
  1. 5window
    5window
    I just noticed a nice5/16" chip in a rear fender-black base coat with clear coat. I did a search but most repair threads involved using an airbrush and repainting. I don't have that equipment or skill level. I'm looking for other suggestions for a"pretty good" repair. Are any of those kits in the car mags, Autoweek,etc. and good at all? Thanks
  2. 1946caddy
    1946caddy
    from washington
    I had a chip in my black Harley tank and I just used 600 about a 1 1/2" area around the chip, put a drop of black paint in the chip and waited a day. 600 the black paint and a few drops of clear over the black paint on the chip and waited another day and 600 followed by 1000. Then used polishing compound and chip disappeared.
  3. s55mercury66
    s55mercury66
    from SW Wyoming
    If you want cheap and easy, try this. A black Sharpie for the basecoat, let it dry, like for a day, then use clear fingernail polish in light coats, letting them dry thoroughly so as to not disturb the "basecoat". It won't be perfect, but it won't be a big chip with primer showing either. You can build the fingernail polish up, with patience.
  4. BigChief
    BigChief
    You can carefully dab it in with black and clear to build up the divot...knock it down with a nib cutter or fine paper...repeat as needed until the chip is at the same level as the paint....wet sand and polish.
    Black is an easy color to fix and the clear is very forgiving.
    YouTube and alot of patience are your friends.
    Sent from my SM-G950U using The H.A.M.B. mobile app
    lothiandon1940 and olscrounger like this.
  5. tb33anda3rd
    tb33anda3rd
    do you have a photo of the chip?
  6. 5window
    5window
    soon. Granddaughter coming for breakfast and it's about 120 inside the car shop.!
  7. Gman0046
    Gman0046
    Go to Youtube and search auto chip repair. Some methods look pretty good.
    Gary
  8. olscrounger
    olscrounger
    What Big Chief and 1946 caddy said. Have done this many times on black cars (have 3). Just be patient. Done right it will not show. Had a nickle sized chip in top of rear fender of wife's 55. Did as they mentioned and it doesn't show. Took a few days but worked well. Have done many chips since.
    Gman0046 and lothiandon1940 like this.
  9. 35WINDOW
    35WINDOW
    For me, at least, I find the biggest challenge of Chip repair (I have a black Car too that is clear coated) is the sanding/finishing after repair-you can easily make a divot in the clear sanding the Paint flat-
    I use the old Razor Blade trick (score one side of a Razor Blade on something Cast Iron that is 'as cast"-I've also scored it on Sandpaper, but it can get very aggressive), put masking Tape on both ends (some people bent the Blade, but I sand the ends round), and carefully cut it down, keeping the Blade flat to the Panel- (or it will dig in)-
    Then it's a matter of carefully sanding the surrounding area flat (if it's on a flat part I'll use a Paint stick or something flat) then use increasing small circles (to keep it uniform)-I finish to 3000 Grit-
    I then use a Milwaukee cordless 3" Buffer with an orange Foam Pad, and, I really like Chemical Guys Compounds (they offer 4 Grits-co**** to fine, and finish with a white Pad (with V38)-
    If you are going to own a black Car, you will learn your preferred method (I've tried many-for me, the Airbrush thing didn't work well, as the Paint had to be reduced too far to spray, causing it to not cover (even with the smallest tip/needle in the Gun)-
    I find that if I use these to put Paint on it doesn't put too much at one time: https://www.ezmix.com/images/thumbs/0000094_dabbers_600.jpeg
    olscrounger likes this.
  10. abe lugo
    abe lugo
    I would recommend just leaving it. It’s part of the road scars you get if you car is actually a driver.
    It also gets glossed over at shows and would be way more obvious if it is a ****py fix.
    If you are trying for points and your car is a show car. Then you should not be driving it as much.
    People will understand if your car actually gets driven then your cars will have chips.
    5window likes this.
  11. pprather
    pprather
    If it has no chips, it's either a trailer queen, or it never gets out of the jewelry box (garage).
    Phil
    Stu D Baker likes this.
  12. joeycarpunk
    joeycarpunk
    from MN,USA
    Chips can be a badge of honor but I have repaired many that were undectable when done. It really depends on where it is and as mentioned patience when building it up and finishing it off.
  13. 5window
    5window
    Thanks for the help. Here's a picture of the chip, rather larger than I intended. chip.jpg
  14. tb33anda3rd
    tb33anda3rd
    looks like more than one? I was hoping to see a photo of it's location, there are different ways to "hide" the repair depending on wether it is on an edge, around a corner, in a divot or in the middle of a flat or curved panel.
    first start by cleaning it really well. do you have any of the original base? or clear?
