Event Coverage The 2019 Yay-Hoo Cup...May God help us all
Discussion in 'The Hokey Ass Message Board' started by Russco, Jun 26, 2019.
  1. Roadsir
    Roadsir
    Might bring two cars, may be unload the 40 in KC.hmmmm. Wasn't there a hoodless black flamed 40 coupe running last year too?
  2. Russco
    Russco
    from Central IL
    Yes that’s Kenny from the STL area I think he’ll be there probably too.
  3. Russco
    Russco
    from Central IL
    I’ve ran similar with mine too. I don’t think I’ve ran 115 but I think 114 and mid 13’s with a 2.6 or so 60’. I’m running on the Coker Cl***ic bias plies. I literally almost have to leave at an idle off the line.
    chryslerfan55, loudbang and D-Russ like this.
  4. jho
    jho
    from Omaha
    I've been way too busy this past year to give my car the proper attention it needs to go the speeds its capable of. So unfortunately the A-HOLE wont be in joplin this year. Sometimes adulting ****s.
    Sent from my SM-N960U using The H.A.M.B. mobile app
  5. raven
    raven
    Oh no!
    (In my best Mr. Bill impersonation)
    Rats, no Thunder this year....
    r
  6. Blakmerk
    Blakmerk
    from St.Joe MO
  7. Russco
    Russco
    from Central IL
    That’s a bummer I always enjoy watching that ol Ford run. And I’m not even a Ford Powerplant guy but, that one I dig!
  8. Russco
    Russco
    from Central IL
    I just got back from the Glory DaysDrags (formerly the Meltdown Drags) it was soooo HOT. Heat index of 107 and air temp on the track pavement was 114. I did a couple great burnouts. And ran a best of 12.82 and best MPH of 109. I then got to line up against a great ‘40 coupe with a blown Hemi. It should have been a good race. I cut a .041 light and must have forgot how to drive because I just blew the tires off for the first 100 feet or so then missed 2nd gear and went on to embarr*** myself with a mid 14 @102 . It made for a couple good pictures though.
    2EAA76EB-299E-4F0F-B356-59AC5B4ED4C4.jpeg 4D2B7C3F-6BA0-4F5E-892D-05150AA0B683.jpeg
  9. flamedabone
    flamedabone
    What exactly do you have going on with the little Chevvie motor under the hood of that '40? That sum***** moves out.
    -Abone.
    kidcampbell71 and loudbang like this.
  10. lonejacklarry
    lonejacklarry
    According to mr. google, my house is 138.4 miles from the front gate of the dragstrip. If I were to drive around in circles in the pits for a while would that count?
  11. Blakmerk
    Blakmerk
    from St.Joe MO
    One wrong turn and you might be in.
  12. Russco
    Russco
    from Central IL
    I gots a 3/4 cam
  13. Russco
    Russco
    from Central IL
    I’m thinking you’ll be OK
  14. lonejacklarry
    lonejacklarry
    That should not be a problem as I have made many, many wrong turns in my life.
  15. Russco
    Russco
    from Central IL
    Kind of a running joke with my wife and I, we always chuckle and say “well we’ve got the wrong turn out of the way now we can proceed to our destination” because we inevitably will take at least one wrong turn along the way every trip. Especially since the advent of the TomTom.
  16. jho
    jho
    from Omaha
    I appreciate it! I so bad want to run it but something about 130+ mph with worn out king pins and tie rods in the front no roll bar yet and a small list of other things it just ain't going to happen this year. This winter its coming completely apart and will be set on kill for the 2020 season!
    cactus1, loudbang and chryslerfan55 like this.
  17. flamedabone
    flamedabone
    You will still have fun and there will still be lots of beer.
    See you in August, -Abone.
  18. Malcolm
    Malcolm
    from Nebraska
    @jho 's '60 F100 may run ok, too...
    Just slightly better than his 20 second goal.
    chryslerfan55, Russco and loudbang like this.
  19. flamedabone
    flamedabone
    C'mon, spill it. What's under the hood??
    -Abone.
  20. Rocky
    Rocky
    Classified Editor
    Yeah.....I've seen photos of the truck [patina] and it's supposed to have some kinda whiz-bang motor in it.
    chryslerfan55, Tim and loudbang like this.
  21. flamedabone
    flamedabone
    Tank is filled with 90 proof, she's all tuned up and g***ed.
    -Abone.
  22. jho
    jho
    from Omaha
    All I'm going to say is I didnt use one bolt off my old mill for the current supercharged mill in my coupe....
    chryslerfan55, enloe, Tim and 2 others like this.
  23. Russco
    Russco
    from Central IL
    So I’m not the only one that has to roll the fronts up on 2x4’s to get the jack under the chin pan? I better get busy and check mine over too. I may have a pilot bushing going bad on mine , but I most certainly am not pulling the front sheet metal and motor/ trans before the drags so I’m hoping it hangs on for another 1200 miles. See you there.
  24. Tim
    Tim
    from KCMO
    @lonejacklarry don’tcut down three harrisonville, go all the way to the triangle and cut down and meet every one at Pete and Jakes and you’ll have your extra miles ;)
    Just Gary, loudbang and Russco like this.
  25. lonejacklarry
    lonejacklarry
    Thanks, Tim. Why didn't I think of that?
    loudbang and Tim like this.
  26. Rocky
    Rocky
    Classified Editor
    hambdrags4.jpg hambdrags8.jpg I'll be trying for the cup this year too. I pray I don't have a replay of the unfortunate occurrence in 2003 [gulp]
  27. Tim
    Tim
    from KCMO
    Awesome! Make all those Pontiac lovers proud :)
  28. Russco
    Russco
    from Central IL
    Bump 1 week away! All you guys driving you stuff 150 miles or more, you know you want to sign up!
    BTW Y’all in trouble now! I put my high flow induction system on today....
  29. Tim
    Tim
    from KCMO
    Dang he ain’t messin around!
  30. Tim
    Tim
    from KCMO
    Just gave the trophy a quick wipe down, who’s taking it home this year?!
    chryslerfan55 and Russco like this.
