Technical c4 auto with a newer 302 help
Discussion in 'Traditional Hot Rods' started by stevens2@htva.net, Jul 24, 2019.
  1. stevens2@htva.net
    stevens2@htva.net
    from 14883
    I want to use a c4 because of it's small size but I'm lost as for the right converter. I have to use the 50z flex plate that came with the 302 but the bell housing of the c4 is to deep( 7") to let the converter engage with the pump. Is there a ford bell that is around 6" from engine to trans.? Any ideas are welcome.
  2. 48fordnut
    48fordnut
    I did this several yrs ago. I think it's a special flex plate to use. I used a std c 4 bell.
  3. There is a 'conversion' flexplate to allow a 50 oz motor to be hooked to a C4, that's what you need. Summit, Jegs, others carry them...
    48fordnut likes this.
  4. LM14
    LM14
    from Iowa
    Just went through this myself. I ordered the special TCI small diameter C4 flex plate with 50 oz imbalance to hook the 2 together. Let’s you put a C4 behind a roller 5.0. Also decided to go with a Hughes Street Rod converter. Just a step more stall than stock. Don’t have the numbers with me now but can get them this evening if you want them.
    SPark
  5. squirrel
    might help to know exactly what torque converter you have, and what bellhousing you have. Pictures? part numbers? descriptions?
  6. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    AOD flexplate and starter... done. C4 TC bolts up and works fine
  7. sloppy jalopies
    sloppy jalopies
    there are [2] c4's... pre 72ish had [1] set of pump/bellhousing bolts, 157 flexplate teeth... the later has [2] sets and is bigger, 164 flexplate teeth... different splines on the input shaft...
    bigger one has the starter mounting bolt swung outward for the bigger flex p...
  8. junkyardjeff
    junkyardjeff
    There was a C-5 made in the early 80s that looks like a C-4 but had a lock up converter that could have a deeper bellhousing.
  9. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Yup, forgot that as mine are big bell and 164 tooth (same as AOD). Early case-fill and input complicates it.
  10. JeffB2
    JeffB2
    from Phoenix,AZ
  11. There's been a few reports of issues using the AOD flexplate; it doesn't engage the convertor fully into the trans as there's supposedly about 1/4" difference in convertor location. I know 31Vicky recently had issues trying to go the other way (AOD to a 351) and the C4 flexplate wouldn't work.
    There's a reason the conversion flexplates are offered...
  12. stevens2@htva.net
    stevens2@htva.net
    from 14883
    Thanks a ton, I just went to Jegs and I think a TCI flex plate #529620 will solve my problems.
  13. justpassinthru
    justpassinthru
    What size is the converter? 11" converters use a shorter bellhousing and a 12" converters use a deeper bellhousing.
    Also a 11" converter drain plug is 1/2 way between mounting studs and the 12" converter drain plug is next to one mounting stud.
    Junkyardjeff is also right with the late model C5 bellhousing being even deeper.
    Bill
  14. gallagher
    gallagher
    from califorina
    I just ordered a early style flex plate with the 50 oz. Imbalance used early c4 converter
    Sent from my SM-G955U using The H.A.M.B. mobile app
  15. LM14
    LM14
    from Iowa
    I used TCI-529610 because I needed the earlier 157 tooth flex plate. The TCI-529620 would be correct if you need the larger 164 tooth flex plate in the larger bell.
    SPark
  16. deathrowdave
    deathrowdave
    from NKy
    I have been running as posted for years , not one issue . Only thing different is I used OEM , 6cyl converter , I touch higher stall than v8 . Worked out wonderful with x grind cam
