Hot Rods First hot rod build, 26 Roadster Pickup
Discussion in 'The Hokey Ass Message Board' started by Inked Monkey, Dec 11, 2016.
  1. Bandit Billy
    Bandit Billy
    ^^^oops, forgot to type anything
    Take some old leather and a snap kit and make a cool cover for those chains. Like the image shown, heck make one for the wife while you at it.
    brEad and Inked Monkey like this.
  2. brigrat
    brigrat
    from Wa.St.
    Just curious what happened to this nose high '55 in foreground in this pic?
  3. Inked Monkey
    Inked Monkey
    It's my buddy's. "O Highway Flyer" Still tearing up the streets in it, I believe
  4. Inked Monkey
    Inked Monkey
    Just enjoying the **** out of it now. Probably change from cowl steering this winter
    brEad, Lerenzo Rawson, Stogy and 6 others like this.
  5. Tim
    Tim
    from KCMO
    Whats the plan on steering?
  6. Inked Monkey
    Inked Monkey
    @Tim Haven't really decided yet. Purser is hooking me up with some boxs for cross steer and I am going to yank an f1 box out of a buddy's yard art. We'll see which fits best and doesn't look too weird.
    Tim and flatout51 like this.
  7. Tim
    Tim
    from KCMO
    Let me know if you have any questions. I now know more than I ever cared to about these boxes and the parts lol
    Inked Monkey and 26 T Ford RPU like this.
  8. Inked Monkey
    Inked Monkey
    I'm looking for a driver's side sill plate. It's 1927 specific, so the bigger one. The one I have is a little too far gone and I'd like an original. I'll be at the hamb drags and could snag it if you're going. If you have one give me a shout.
    Stogy and kidcampbell71 like this.
  9. Inked Monkey
    Inked Monkey
    Well the cowl steering is out. I drove many miles without issue but it always seemed a little "twitchy". A friend gave me an f1 box so I dove in.
    It took awhile to get the box positioned, but I found the sweet spot. All I did was cut off one of the factory ears on the f1 box and drilled another hole closer to the column.
    I picked up this boat steering wheel during the initial build. Time to bring it down from the rafters.
    Sweet spot ended up being a couple inches behind and lower than factory A location.
    Holes filled.
    Stogy, brEad, Tomcats30 and 3 others like this.
  10. Tim
    Tim
    from KCMO
    Lookin good!
    Inked Monkey likes this.
  11. 26 T Ford RPU
    26 T Ford RPU
  12. DesmoDog
    DesmoDog
    Seeing that makes me feel good... because it's pretty close to where I ended up drilling a new hole for my F1 box to mount! I started with an F1 box that had already been cut up though, so my mounting system is more complicated. I have a spare box that's uncut... I am going to re-evaluate and maybe go this direction instead.
    Stogy, 26 T Ford RPU and Inked Monkey like this.
  13. Inked Monkey
    Inked Monkey
    Just waiting on a new box gasket, some corn head grease and the pitman arm. Then I'll be able to install the box for good and work on the column drop.
    Stogy likes this.
  14. Inked Monkey
    Inked Monkey
    I'm not a small guy and having it mounted here gives me enough room to get in and out. As well as use the clutch pedal. Even able to use this larger diameter wheel.
    Speaking of wheel, this boat one is keyed and the f1 shaft was splined, so I ****ed in a tapered keyed snout. All back together now.
    Stogy, brEad, Lerenzo Rawson and 2 others like this.
  15. Tomcats30
    Tomcats30
    Awesome!...Please take some pics of how you do the column drop.
    Lerenzo Rawson and Inked Monkey like this.
  16. Inked Monkey
    Inked Monkey
    F1 box is in! This steering geometry looks about perfect so it should handle great. Just need to do the column drop now.
    Tim, pecker head, Stogy and 2 others like this.
  17. Inked Monkey
    Inked Monkey
    Pitman arm is an NOS 35-36 arm that I found online for under $20. Just heated it up and bent it to shape. Then I took a triangle file and cut the locating splines so that I could clock it right. I was able to cut down the previous drag link and re-thread the end instead of buying a new one.
    Stogy, Atwater Mike and 26 T Ford RPU like this.
  18. Atwater Mike
    Atwater Mike
    You have learned all the tricks, Monkey! The old 'triangle file trick' occurred to me when I was 17, same setup as yours, nearly...Mine was a '32 frame, channeled body, and the F1 steering was dropped to go under the low dash.
    I ended up with the triangle file...
    Glad you're up on your geometry. Steering linkage looks 'ship shape'.
    Stogy, cactus1 and Inked Monkey like this.
  19. jeepster
    jeepster
    from wisconsin
    Cool thread! Thanks for sharing, always liked roadster pick-ups. Yours is good example why I do!
  20. Inked Monkey
    Inked Monkey
    Thanks guys. More to come!
    26 T Ford RPU and Stogy like this.
  21. Stogy
    Stogy
    Thinking of that thread on Cowl Steering...Brings that Geometry Image to mind and yes I believe you have the Center line right through the money there...I have one question about what I see and it could be just the Angle...
    Is there potential for the wishbone to collide with the Steering Arm or Bolt when bouncing through road variations...I have a similar setup and I have some scuffing going on with mine that I have yet to address...and like yourself that entails some heat...
    Obviously the further away from the axle you get, the less the travel will be but again that looks close...​
  22. Inked Monkey
    Inked Monkey
    @Stogy I was concerned about that too. I jumped up and down on the frame and couldn't get it to touch. I'm going to keep an eye on it though.
    Stogy likes this.
  23. Inked Monkey
    Inked Monkey
    After looking at a bunch of different years for the column drop, I decided on 40 truck. It fits great!
    Made this little patch for the dash. Broke the bottom to match the factory bend.
    For the second mounting hole, I used some 3/4 angle welded as a bridge.
    And tacked the face patch in. Everything will get fully welded when I pull the dash.
    slv63, brEad, patmanta and 4 others like this.
  24. Tim
    Tim
    from KCMO
    Looking good!
    Stogy and Inked Monkey like this.
  25. Tim
    Tim
    from KCMO
    Also @Stogy he's basically gorilla sized so I’m gonna guess if it doesn’t hit when he jumps on it that it won’t ever hit
    26 T Ford RPU, Inked Monkey and Stogy like this.
  26. Stogy
    Stogy
    :rolleyes:...:D
    It's interesting Primates aside how much a pothole or more severely rough road, how many pounds are involved in those bounces. It may actually be Three Gorrillas...:eek:
    I have hit a few memorable potential kingpin shearers and aside from thinking of the age of Henry's Finest taking it for all these years and hopefully continuing to do so...:eek:, I think of that pitman to drag link tie rod end contacting the Bones and it's chipped paint and scuffed but not grooved...
    :rolleyes:...Stogy's...sample of discussion of Primates and Hotrods...:D
  27. Tim
    Tim
    from KCMO
    Guess he’ll find out. If it hits I guess he’s got his next project. I think it’s probably so light that most of his suspension is coming from what tire pressure he is running
    Stogy likes this.
  28. Inked Monkey
    Inked Monkey
    My shocks are way too stiff too. They fit the length requirement but are made for a truck or something. Easy enough to reconfigure as problems arise. I was trying to keep from having a crazy S in the pitman arm to clear the bones, but I can always tweak it more.
    Stogy likes this.
  29. Inked Monkey
    Inked Monkey
    Made a new shift knob while I'm changing things up.
    pecker head, slv63, brEad and 2 others like this.
  30. Tim
    Tim
    from KCMO
    I suppose you, @flatout51 and I could jump on it. That’s like two gorillas right?
    in all honestly you’d have to drop that ****er off the Empire State Building loaded down with bricks and have it land on all four tires to get that suspension to compress more than an inch and a half. You’re likely just fine.
    flatout51, Stogy and Inked Monkey like this.
