Hot Rods THE INDUCTION THREAD
Discussion in 'The Hokey Ass Message Board' started by mad mikey, Dec 9, 2016.
  1. deadbeat
    deadbeat
    What cfm were/are the 3 bbl Holley? Cheers
    Deuces and loudbang like this.
  2. saltflats
    saltflats
    from Missouri
    They made a 950 and a 1000 cfm
    The one with the down leg booster in the secondary is a 950.
  3. '51 Norm
    '51 Norm
    from colorado
    Apparently Speedy Bill had a few flathead intakes.
  4. loner1
    loner1
    from Texas
  5. Deuces
    Deuces
    An Olds 455 cast iron intake....;) Posted by????... I think it was Dago 88 in another thread.....
    TBirdGirl26, loner2, Jet96 and 9 others like this.
  6. Stebo27
    Stebo27
  7. Deuces
    Deuces
    DSCN3157.JPG c29d4b3aac47986720aa94de978b6f87.jpg 20815e15413535ea367ed7fbff6f822c.jpg cfb5b57fab5d5efb009c09aa5d48acae.jpg 9425343ce0d95ac572be042ff98ad1be.jpg A few more Holley 3-bbl pictures....
    I think it was Elco that sold those gear drive setups for the throttle shafts and the pump squirter....
  8. saltflats
    saltflats
    from Missouri
    My 950 has that conversion.
    loudbang, deadbeat and enloe like this.
  9. Deuces
    Deuces
    005_zpsfe609c64.jpg 006_zps622f4c00.jpg 003_zpscd694f7d.jpg 007_zps71e8c289.jpg 001_zps2d670ef4.jpg 004_zps3e549aa0.jpg 002_zps124555ca.jpg
    Super rare Super Duty intake for Ponchos.....
  10. Fordors
    Fordors
    The manifold was cast for the earlier 394 engine, it would be pre-‘65. It was 1965 when Olds introduced the all new 425 which was eventually enlarged to 455.
    loudbang, Bowtie Coupe and Deuces like this.
  11. Deuces
    Deuces
    Carter 3-bbl carb.... Posted by carbking on another thread.... SD3636bottom (1).jpg SD3636top.jpg
    From what Jon sez, there were around????.... 20 of these made.... Maybe even less...
  12. Deuces
    Deuces
    Oops!.... My bad..:oops:
    Guess I'm learnin' something new..... Thanks! :)
  13. carbking
    carbking
    Carter, Holley, and Stromberg all made at least one 3-barrel carburetor.
    My records show the Carter in 1963, the first of 4 or 5 Holleys in 1964, and the Stromberg in 1937.
    All three have been pictured on various threads on these forums.
    There were a number of aftermarket modifications for the Holleys. There were no aftermarket modification for the Stromberg, and I am unaware of any for the Carter.
    The Carters are quite scarce (I only have two of them ;) ). I have a letter from Carter stating only 15~20 were made. This is slightly incorrect, as when I was researching the Pontiac SD carburetors, I found 24 of them.
    The Stromberg was a prototype only, no production. I have the only one produced.
    I do not have any idea of the production numbers on the Holleys, but at one time I had more than a dozen, so am positive there were more produced than the Carters. All of these are now gone.
    Jon
  14. Deuces
    Deuces
    Thanks Jon!.... ;)
  15. AChopped1950ford
    AChopped1950ford
  16. carbking
    carbking
    The Carter 3-barrel was originally designed exclusively for NASCAR racing, and as such, the primary and secondary shafts operated via linkage at almost one to one; which made the carburetor virtually worthless on the street. Guessing that the company that made the aftermarket gear drive for the Holley got the idea from the Carter. Carter used linkage, whereas the Holley was retrofitted with gears to achieve the one to one.
    We did modify a couple of the Carters to have conventional secondary linkage where the secondary was adjustable when it came in. This was done by removing the secondary linkage from the 3-barrel, and replacing this linkage with the complete secondary linkage from one of the Carter 750 CFM Comp series carbs, part number 4760s. By doing this, the carburetor made a dandy "street sleeper" carb.
    Jon.
    Bowtie Coupe, loudbang, enloe and 2 others like this.
  17. Deuces
    Deuces
    Do you have more detailed pictures of those????.. :)
    loudbang and enloe like this.
  18. Deuces
    Deuces
    loudbang, enloe and deadbeat like this.
  19. Hotdoggin DaddyO
    Hotdoggin DaddyO
    from Hays, Ks
    Holy ****, I guess I better take my next vacation in Nebraska.
  20. loner1
    loner1
    from Texas
  21. XXL__
    XXL__
    Just blow on it...
  22. Jalopy Joker
    Jalopy Joker
  23. Stebo27
    Stebo27
  24. loner1
    loner1
    from Texas
  25. loudbang
  26. Deuces
    Deuces
    enloe, 1947knuck and loudbang like this.
  27. loudbang
  28. loudbang
  29. Deuces
    Deuces
    Love that Poncho!!!.... :)
    loudbang, enloe and 1947knuck like this.
  30. loner1
    loner1
    from Texas
