Technical Little tips and tricks for garage hobbyists.
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 30, 2019.
  1. sloppy jalopies
    sloppy jalopies
    I use a '70s under seat, "seat belt" buzzer as my tester...
    I can look at the contacts in question and not have to look away to see the test light... just listen...
    my 3rd one, the other 2 were so handy that "buddies" had to borrow it, with time I forget who I lent it to and it used to be so easy to find they felt I would just make another... gone !
  2. 1946caddy
    1946caddy
    from washington
    Had a buddy who had a big grease board on his garage wall and he wrote the name, date and what people borrowed from him.
    Pete L., Elcohaulic, whtbaron and 8 others like this.
  3. RMONTY
    RMONTY
    "5 minute build" shelf brackets from s**** 2 x 4's. Sturdy as hell and cheap! You can make a set of 3 or 4 in 10 minutes or so. A 18 ga Brad nailer or crown stapler, drywall screws and some ***ebond. Pre-drill screw holes to keep from splitting the wood. Good to go! I stained these to add character.:rolleyes: 20190731_162230.jpg
    kbgreen, Outback, Elcohaulic and 14 others like this.
  4. winduptoy
    winduptoy
    Totally Awesome...a $1.00 in the trigger sprayer at the Family Dollar. It will turn your whitewalls white again and your black walls black without giving them that goofy Armor All, ugly Tire Black sheen
    The trigger bottle is worth a buck and cleans a lot of other things too...
  5. oldiron 440
    oldiron 440
    If your welding in your garage don't store tires in the same space, it degradates the rubber.
  6. sloppy jalopies
    sloppy jalopies
    When chopping a model A, slide a long piece of the right size brake line with one end cut off down through both halves of all 3 hinges instead of the pins...
    It helps align the hinges / posts for rewelding...
    this one is not my idea,
    but a buddy uses broken, welded or bent running board brackets mounting them upside down as shelving brackets in his garage...
  7. My tip,
    Don't adjust them running..Don't use any foil.;)
  8. sloppy jalopies
    sloppy jalopies
    I use model A bumper to body braces on '30-'31 closed car firewalls,
    as front body to frame mounts...
    .hard to see but they are welded to the lower front of the firewall and bolt to the frame... DSCN3981.JPG
  9. fastcar1953
    fastcar1953
    try to keep your space clean and orginized. things go better when you have room to work and clean space to do it.
    kbgreen, ffr1222k, OLSKOOL32 and 9 others like this.
  10. BamaMav
    BamaMav
    from Berry, AL
    Old refrigerators make good dry places to store welding rods and wire. Doesn’t have to be a large full sized one, you can use an apartment sized one if you are short on room.
  11. Mr48chev
    Cheap pans either aluminum or plastic from Dollar tree work great to lay a carb part that is too big to go in the gallon can of carb cleaner and the little basket. find one just big enough and deep enough to put the part in set the part in and pour the carb cleaner in the pan. Lift the part out with pliers and rinse off and pour the cleaner back in the can.
    Make use of the O'Reilly's and Autozone tool loan programs for those odd tools you only use once in a several year time frame.
    Keep a binder going on each project you have with note pages and page savers. Write down the parts you bought for the project when you put them away so you don't have a brain fart and buy them again when you see them on sale.
    The heavier file cabinets with 4 or 5 drawers that you find at the Habit store on a regular basis make great parts storage cabinets for projects. They also work great for storing and organizing tools that come in their own cases that don't fit in the tool box like tap an die sets and the larger tube bender sets. Usually around 20 bucks for the good ones.
    Every time my decides her stainless baking tray with the 1/2 lip on it is getting too stained up to use I snag the old one when she buys a new one. Same with the HD muffin tin she thew out with a dozen or so cubbies in it. The trays are great to have under a carb on the bench when you take them apart or put them together as the little pieces don't roll off and the mess is a lot easier to clean up when you have the carb apart and in the cleaner.
    kbgreen, wobbles62, pvfjr and 12 others like this.
  12. 31Apickup
    31Apickup
    Just don’t leave an open pan of it with parts soaking in the garage, everything else around it will rust.
  13. sloppy jalopies
    sloppy jalopies
    When adding model A splash aprons and running boards I use about 6" long bolts dropped through the mounting bolt holes, lets you lift the body and not lose mounting block alignment, then replace them with the correct bolts when all is in the right spot...
    This also worked great when aligning the wooden mounting blocks while I was mounting a fenderless coupe body on an A frame...
    this could help line up about anything ...
    OLSKOOL32, WB69, slack and 6 others like this.
  14. OLSKOOL57
    OLSKOOL57
    You got that right!!!!
    48fordnut, loudbang and enloe like this.
  15. bill gruendeman
    bill gruendeman
    My simple trick that took me 40 years of working on cars to figure out . Clean up at the end of the day, put away all the tools and vacuum the floor( better than sweeping it) I used to wait to clean up until the job was done, it could be weeks or months before I cleaned up. what a mess I can’t work like that now.
  16. mtkawboy
    mtkawboy
    Open your tool boxes and take pictures of all of your tools, the boxes and all the stuff hanging on the walls & ceilings. I learned that the hard way after my garage got robbed. You think you will remember what you have but it will be 5 years down the road and you'll be looking for a tool and ....**** forgot about it ! It makes dealing with your insurance company a lot easier too
  17. topher5150
    topher5150
    I super glue washers to nuts to get them into hard to reach places
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  18. jim snow
    jim snow
    Lots of great tips here. Thanks. Snowman
    lothiandon1940 and loudbang like this.
  19. BamaMav
    BamaMav
    from Berry, AL
    That’s what the back yard is for! :)
  20. jetnow1
    jetnow1
    from CT
    When I built my garage and had the electrical inspector out he indicated he needed to go, I said I would open the house for him but he said no, he would just go out back. He was over 90, guess he did not want to walk 100 feet to the house. He also did not inspect the upstairs as he did not want to climb the stairs. He died about 6 months later.
    Outback, enloe and loudbang like this.
  21. paul55
    paul55
    from michigan
    Cleaned the paint on this old Chevy with Softscrub from the wife's kitchen. DSC04726.JPG DSC04732.JPG DSC04736.JPG
    rod1, mario711, Oldsmobucket and 45 others like this.
  22. fordor41
    fordor41
    glue screws to a screwdriver tip in awkward places. can't get a nut on a bolt in a tight place, glue the nut to your finger tip and screw the bolt into the nut or tack weld a piece of metal or wire to the nut. I always use nylock nuts on fenders etc, neverseize all bolts under the car. Don't have a lock nut put a dab of RTV on the threads after tightening. they won't loosen but can be removed.
    rod1, pbr40, zz29 and 10 others like this.
  23. Gizzy
    Gizzy
    from N.W,Ohio
    LOL...I do the same thing with a Styrofoam cup
  24. It’s a man’s God given right to piss outside!
  25. hotrodA
    hotrodA
    The world is my urinal (as long as my wife doesn't see me):eek:
    One of the benefits to living in the country when you're old.:D
  26. 56don
    56don
    Just in case of emergency, I painted a square area on my garage wall where I hang my fire extinguisher Hunter Orange so that even if a stranger unfamiliar with where I keep it can quickly grab an extinguisher by seeing the brightly neon orange area marked "Fire extinguisher".
  27. sloppy jalopies
    sloppy jalopies
    When you can't reach the far end of the nut or bolt, saw a screwdriver slot into the end of the bolt, with thin masking tape a piece of wire onto the end of the slotted bolt... gently feed the wire through, careful when you get to the bolt, feed it through the hole, jam it with a flat screwdriver.... carefully peel off the tape, slide on the flat and lock washers, start the nut, run it in as far as you can, use the screwdriver to hold the bolt and tighten the nut...
  28. Dan in Pasadena
    Dan in Pasadena
    Wait.....OA REMOVES rust from from rusty parts but makes non-rusty parts rusty??!!!
    WTF? I followed the link and was impressed with how the bicycles looked less the rust but with the original paint and decals. I just don't see how it can do that but make something else rusty?
  29. BrandonB
    BrandonB
    from nor cal
    I don't know where that came from. I've done it in the garage and left it out when I was done in case I wanted to do some more parts. Never had a problem with rust in adjoining items. The gentlemen on the Collectors Antique Bicycle Exchange (CABE) use this process all the time and no one has ever mentioned to be cautious concerning rust on surrounding items. It's an organic item found in food, spinach, rhubarb etc. bee keepers use it and it's also found in honey. Another collectors forum, such as collectible cans and such are quite familiar with it and have never read about that caution. Maybe the poster can expound on it.
    48fordnut, enloe and loudbang like this.
  30. BigO
    BigO
    My tip to add: Prior to wiring under the dash, paint it all white under there so when you ever have to work on the wiring as soon as you turn on a light to see what your doing everything is well lit and easy to work on, has worked out well for me. :)
