Sbc new cam and heads won’t start!
Discussion in 'The Hokey Ass Message Board' started by Camp64, Jul 31, 2019.
  1. 2OLD2FAST
    2OLD2FAST
    from illinois
    Is your damper marked at 90° ? I find that much easier than the comp EOIC method...
  2. Camp64
    Camp64
    I have the rotor pointed to number one on the engine and that post is also the number one spark plug wire. Is that what you mean?
  3. OLDSMAN
    OLDSMAN
    Yes that is the way you are supposed to install it your cam timing is off
    Bandit Billy likes this.
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    Biting my tongue to keep from laughing .....
    firstinsteele likes this.
  5. 1946caddy
    1946caddy
    from washington
  6. 2OLD2FAST
    2OLD2FAST
    from illinois
    Wtf is the difference between crank at 12 , cam at 6 and crank at 12, cam at 12 other than #1 or #6 firing position ??
    ffr1222k likes this.
  7. OLDSMAN
    OLDSMAN
    The marks always go together. That’s just the way they are set up
    WB69 and gimpyshotrods like this.
  8. saltflats
    saltflats
    from Missouri
    Small block chevy crank gear at 12 cam at 6 will be tdc firing #6
  9. Camp64
    Camp64
    When on the compression stoke of number 7 the rotor pints at almost the driver seat
  10. Camp64
    Camp64
    I mean when on the compression stroke of number 6 cylinder at tdc it is almost pointed at the driver seat
  11. saltflats
    saltflats
    from Missouri
    Not knowing what this 30- 30 cam is.
    Could be cold natured, do you have a choke, accelerator pump working, set your base timing up more.
  12. 2OLD2FAST
    2OLD2FAST
    from illinois
    What's important is what # wire is it pointing at ....( When the cap is in place )
    Atwater Mike and 1946caddy like this.
  13. 1946caddy
    1946caddy
    from washington
    So you changed the heads, cam,intake and the dist. on a good running engine and now it won't run.
    Any chance the old cam was a hydraulic unit and you're using the old hydraulic lifters on a solid lifter cam ?
  14. 52HardTop
    52HardTop
    The rotor does not want to aim at number 1! The wire going to number one spark plug has to be in the hole where the rotor is pointed when number one is at TDC. . ***uming number one cylinder is actually at TDC.
  15. 2OLD2FAST
    2OLD2FAST
    from illinois
    O. M.... G....
    s55mercury66 likes this.
  16. saltflats
    saltflats
    from Missouri
    On a HEI it should be pointing at the p***enger seat ant TDC firing #6
  17. 1946caddy
    1946caddy
    from washington
    What we need to know is what plug wire in the dist. is it pointing at. It should be pointing at the wire that leads to the number 7 cylinder.
    Atwater Mike likes this.
  18. noboD
    noboD
    Bingo.
    gimpyshotrods and harpo1313 like this.
  19. Camp64
    Camp64
    I wanted note out of the engine and no it’s a new solid cam with new solid lifters
  20. 2OLD2FAST
    2OLD2FAST
    from illinois
    Another one ! Good Lord.,..
    WB69, ffr1222k, gimpyshotrods and 2 others like this.
  21. saltflats
    saltflats
    from Missouri
    Cam turns half the speed of the crank. What happens when you turn the crank one revolution, the cam mark that was at 6 will now be at 12.
    papadaddio, sunbeam, ffr1222k and 4 others like this.
  22. Camp64
    Camp64
    I checked tdc on number 1 again the rotor is pointed just to the left slightly of number 1.
  23. Camp64
    Camp64
    Timing mark on crank at zero
  24. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    A picture of the distributor with the cap off (from the top)would be most helpful. Have the harmonic balancer lined up with the TDC mark on the timing tab. Most of the guys on here can tell you where to go from there.
    In addition to what A****er Mike said, a couple of other scenarios I have seen are wiring the cap in the wrong direction and not allowing for the helix of the distributor gear when installing.
    As a retired Autoshop teacher, I have seen many variations on this. The most unexpected one was a student putting the coil wire on #1 and the #1 plug wire to the center of the cap. It actually ran!
  25. 2OLD2FAST
    2OLD2FAST
    from illinois
    And the cam is at either #1 or #6 firing position , THAT depends on the cam manufacturer .IME , cam dot at 12 is #1 firing position , cam dot at 6 is #6 firing position ...
    papadaddio and 427 sleeper like this.
  26. Mr48chev
    The cam and crank gears should have been lined up as shown in the photo below. Still if you had the cam gear at the top it should have lined up at the bottom after one rotation of the crank.
    Lining up the gears like that tells me that you are normally used to working on a different engine that isn't a small block Chevy. Am I correct?
    Firing order is as in the second image with clockwise rotation.
    YOUR only interest is that the rotor points to number 1 on the distributor when you have number 1 cylinder on TDC. You do not give a rip that it may or may not physically point towards the actual cylinder and anyone who told you that is a bul**** artist that needs a kick in the ***.
    One backfire can blow out a power valve but that shouldn't keep it from starting or cause big backfires. small block timng gear lineup.jpg 350 firing order.jpg
    Story on myself, back years ago I had an Olds Cutl*** with a 350R as my daily driver/drag car and was used to tuning it. I built a T bucket with a 283 and it backfired just like your engine is for several nights on end when I was trying to start it. Woke up at 02:30 one night with the revelation that I had wired it counterclockwise to match the Olds pattern rather than clockwise to match the Chevy pattern. Went out in my bathrobe put the wires in the correct firing order, busted it off with open megaphone headers, shut it off an went back in and back to a very sound sleep.
  27. The Mullet
    The Mullet
    If you don't have one, go get a vacuum gauge and connect it to a manifold vacuum port. Let us know what it shows when you crank. The odds are that the carb is not set up properly, you are losing vacuum through the valves, timing or otherwise, or your timing is way off. Just for argument's sake, did you buy new properly sized push rods? I would start there if you don't have adjustable rockers.
    Sent from my XT1650 using The H.A.M.B. mobile app
  28. Camp64
    Camp64
    Put my finger in number 1 work plug hole and it blew my finger off and I spun the motor a little to get it to zero
  29. Guys, I've never seen one run with the distributor 180 deg. out. Have you?
    I'd say it's got something to do with the gasket/ mounting flange for that hunk-a-junk Holley DP or an internal problem with it.
    saltflats likes this.
  30. F-ONE
    F-ONE
    from Alabama
    Let's forget where the rotor is pointing for a moment. It does not matter and it can be reset later. Right now we just want to get it running. It does not matter for this test!
    Forget about timing marks for the moment.:eek: It does not matter for this test! This a bridge that will be crossed later.
    Remember Ford and GM number the cylinders differently..Make sure you are numbering the cylinders correctly!
    Refer to your shop/engine manual for cylinder numbering and firing order.
    The rotor could be pointing to the moon. It does not matter.
    With you finger find number 1 compression again. Note rotorary ****on location.
    Do this twice or thrice more confirming that #1 piston is at the top of it's compression stroke.
    After doing this 3 times......the rotor should be landing in about the same spot.
    This spot where the rotor is pointing now.....Is Number 1.
    It does not matter how the distributor is marked. Where that rotor is pointing now after confirming compression stroke is #1.
    If it's not pointing to marked #1 on the cap....no big deal. You can run your wires from here and it will run.
    Or
    You can pull the distributor and walk it around to marked #1 on the cap.
    Sometimes the oil pump drive will not allow the distributor to drop into the sweet spot....you have to bump the starter or turn the crank to get the distributor to drop in.
    Now....let's look at the timing marks.....you should be close.
    Now let's confirm the order and run the wires.
    Now try to start it.
    You can tweak a little with the advance.....If it's off you may find the distributor is off by a tooth......
    You may have to reset the distributor again.
    Lastly......
    It's good to have a confirmed working carburetor.
    jimgoetz, Hombre and ffr1222k like this.
