Technical What Speedometer for Hot Rod
Discussion in 'Traditional Hot Rods' started by qmdv, Aug 1, 2019.
  1. alchemy
    alchemy
    Don't they make a mechanical version? Why introduce more electric stuff (sender) than needed. Henry drove his speedos with a cable. You should too.
    kidcampbell71 and 56shoebox like this.
  2. burl
    burl
    from Minnesota
    Keep the old one and run a speedo app off your phone.I have a hall effect sender in one of mine and it does not work very well.Needed to re-teach the thing to much.Gave up and running a speedo app off my phone.
  3. My problem is that i do not have a speedometer. And I have a 3.27 to one in a 36 ford rear end and am not sure where I will end up as far a tire size. Finding the correct speedo drie is a challenge. Maybe I should work towards that though
    Chavezk21 likes this.
  4. 56shoebox
    56shoebox
    Cool! Where do you download this speedo app? I would be interested in that.
  5. burl
    burl
    from Minnesota
    If you have an iphone there are several in their app store.The one I have been using is the 55 app its free and has navigational functions as well.
  6. The phone app is starting to appeal to me
  7. lostone
    lostone
    from kansas
    I've been looking for a speedo too. And I hate the 160 mph ones, really? How many cars need 160 speedo ?
    I want a 100 to 120 old oem one myself but I've been looking at the GPS new style but I may have to check out this app you gents are taking about.
  8. 49ratfink
    49ratfink
    a flathead powered car will not run with new store bought gauges. it disrupts the space-time continueum
  9. Malcolm
    Malcolm
    from Nebraska
    As far as the GPS based speedometer apps, I use the DigiHUD version on my Motorola Droid phone and it works well.
  10. jimmy six
    jimmy six
    U can get an adapter to correct your stock feed from the transmission. I got mine from a instrument place in Texas... Highest gear for my car was a 3.21 and I put in 2.74's. the adapter brought it to perfect.
    46international likes this.
  11. You may be correct.
    some of my instruments are out of a totaled Peterbilt
  12. Texas is a very big state. Can you narrow that down a bit. Do you have a company name
  13. Cliff Ramsdell
    Cliff Ramsdell
    I use an old truck gauge in my hot rod. It’s a 1-1 piece and just swapped Speedometer turtles till I got it honed in. I’m within an MPH at most places on the dial.
    Cliff Ramsdell
  14. dana barlow
    dana barlow
    from Miami Fla.
    So over coming not having a way at the time, to hook up a speed-O in a 1928 "A" dash,to a 1957 Ford ****** on 1949 Olds rearend with 30in. high rear tires,,,Taking you back too how I know what speed I was going in 1959,got a Sun RPM Tach from J.C. Whitney. Made a 1/2in. wide ring alum ring to fit around out side of tach. With my buddy driving his reg car,I followed as he run first 10mph for a block and then 20 the next block an so on,up to 60. I marked the ring at the RPM at each speed in highgear.
    So that made the tach also in too a speed-O. Now days you young spuuuus have GPS on the cell phone to tell what speed an were your lost **** is going too. LOL
  15. Do you always drive with fuel cap off
    Blues4U and Cliff Ramsdell like this.
  16. jimmy six
    jimmy six
    Texas Industrial Electric. In San Antonio.
  17. e1956v
    e1956v
    Alliance Vendor
    I can take care of any calibration issues you would have with the speedometer.
    No problem to get it dialed in and can make up any cable you would need to get it up and running.
    Cliff Ramsdell and Inked Monkey like this.
  18. BrandonB
    BrandonB
    from nor cal
    SW survey speedometer or something else a little different.
    I like how the second one is split between "driving range" and "danger zone."
  19. e1956v
    e1956v
    Alliance Vendor
    How much room do you have?
    A 5-1/4 hole will give you a cool Studebaker speedometer that's 5-1/2 bezel size. Got one here if it will fit. 20190802_080945.jpeg
    Sent from my SAMSUNG-SM-G890A using The H.A.M.B. mobile app
    waxhead likes this.
  20. sloppy jalopies
    sloppy jalopies
    Don't know if it has been tried but there are a bunch of different bike speedometers...
    Found a 4 5/8" speedo at the swapmeet… thought it was bike but looked and fit right...
    $5.00, sold ! …
    Is there a "screw to the back of speedo" converter to let it adjust to work with cars ?
    pix of it set in from the "back" in a modified '38 dash...
    it had the flange that also lets it mount from the front...
    ..... my $0.02...
  21. Blues4U
    Blues4U
    from So Cal
    "We don't need no stinkin' speedometer......"
  22. DDDenny
    Yeh, just use the one that the police car has that's in front of you.:p
    Blues4U likes this.
  23. fleetside66
    fleetside66
    If you don't want a 160 mph job, how about this 65 mph 1915 REO Speedwagon unit? It worked for a 100 years & it's still working. And, it was made in the U.S. & doesn't need a sender....lol.
    shivasdad, BrandonB and e1956v like this.
  24. Harley speedo most likely aftermarket...you can get them new from Harley catalogs but they are 40-50 bucks.
    And they make two versions, one with a 1:1 ratio and another with 2:1.
    Just to brag a bit, I made a speedo drive gear from my lathe and milling machine, used a large screwdriver handle, works fine. I could not get the correct tooth count on a gear that would fit a '57 ford-o-matic trans so I had to make it.
  25. fleetside66
    fleetside66
    Or, a 70 mph Federal? Works like ****er! But on a serious note, it is always a ****shoot to get accuracy with any speedometer (barring non-traditional GPS stuff, etc.) with all of our crazy gearing & tire sizes.
    But, if you get a mechanical one & hook it up, you can quickly get an idea on where you're at in relative terms. I'm running an early 1950's S/W "Wings" 100 mph unit & I really never cared to much about a few MPH increments here or there. Ironically, every time I drive by one of those roadside gizmos that tells you how fast you're going, I find that my speedo is dead on. Go figure.
    shivasdad and Cliff Ramsdell like this.
  26. BrandonB
    BrandonB
    from nor cal
    Or a vintage Harley speedo but those might be a little over done. 0BBC9425-4396-44BE-83AF-6B8DEDED49C4.jpeg I have an early 50’s speedo in the 34, been there since the late 60’s.
    waxhead likes this.
